Bruiser of a 700W
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    Re: Bruiser of a 700W
    I think you meant mm. A 2 meter long PSU would certainly not meet any standards.
    A working TV? How boring!
    • 370forlife
      Large Marge
      • Aug 2008
      • 3112
      Whoops. Yup you're right.
      • Rulycat
        • Apr 2010
        • 724
        What leads does this have? I'm guessing two PCI-E 6 pin?
        • 370forlife
          Large Marge
          • Aug 2008
          • 3112
          1 24pin motherboard connector
          1 4pin P4 power connector
          1 8pin EPS power connector
          2 6pin PCI-E power connectors
          4 Sata power connectors
          7 Molex power connectors
          2 Floppy power connectors
          • Rulycat
            • Apr 2010
            • 724
            Blimey, that's quite a beast. You could use that in a decent gaming PC.
            • i440bx
              Elitebook 820 G3 engineering example: CMOS settings lost despite new cell
              by i440bx
              Hey there,
              I got a HP Elitebook 820 G3 Engineering Sample Laptop and I want to use it. Besides the difficult things at the ES-BIOS I have a big problem by saving the main BIOS settings.
              The laptop does not have a big battery because it was dead, but I already plugged in a new CMOS battery.
              It takes about 5min without power and the BIOS settings are lost. Unfortunatly I dont understand why the BIOS settings are only saved with power connected and this is the reason why I registered here.
              As written above, I plugged in a new CMOS cell and checked...
              08-19-2024, 02:28 PM
            • throwaway327
              by throwaway327
              Model No: RC72LA
              Serial No: SBNVKD001014459
              06-18-2025, 05:52 PM
            • AquaMan Ua
              Problem with PANASONIC CF53 laptop after changing BIOS settings
              by AquaMan Ua
              Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
              05-17-2025, 09:40 AM
            • Billydv1@verizon.net
              Various Asus Motherboards losing bios settings
              by Billydv1@verizon.net
              Trying to track this down. 3 boards all same problem. Rampage IV Extreme, Z87 Pro, Z97 pro. All boot and function correctly but all lose bios and time settings if power is shut off. If power is maintained, sytrms boot and reboot normally. I have verified cmos battery is supplying 3v to board. 8 pin bios chip has continuity to ground but no voltage to vcc pin. I assume that's the pin that maintains the settings with power to bios chip. How do I track this down? What voltage do these bios chips require?
              11-30-2023, 10:27 AM
            • Conste
              Clevo W25CEW doesn't save Bios settings / shutdown issue
              by Conste
              Hello together,
              I have a Clevo W25CEW (Terra 1541) with some strange symptoms:
              1. I cannot save Bios settings by pressing "save settings" in the bios. By pressing "save & exit" it will save the settings.
              2. I can boot normally (UEFI installation), but when I shut the machine down and start it after a few seconds again it will show resume from hibernation and shutdown after POST, just before windows would boot. Then it will go back to factory settings and my UEFI installation will not boot!
              Already changed the CMOS battery...
              09-01-2021, 10:34 AM
