Power supply absurdity
  • pentium
    • Mar 2006
    • 2778
    So I picked up this Cipher 9-track tape drive from the office and dragged it home, only to find out that something was up with the PSU.
    I spent an hour poking at it and the rails. It was giving a voltage of sorts and things were happening in it like the fan was trying to spin and there was a transformer that was buzzing away but other than that, it was not really doing much. This includes when it was disconnected from the other internals of the drive.
    I pulled it out this morning and took it to the office shop to see what I could do but when I plugged the PSU in there, it worked. The fan sprang to life and I was getting more respectable voltages out of it. I let it run all day and it didn't hiccup once.
    Okay, so I thought either I was having a noise issue or the transit reseated something so I took it and a brick-sized line conditioner home and tried again.
    As luck would have it, it's once again back to the same nearly-dead state.
    Okay, so I'll lug it and the whole damn drive back in to work tomorrow but what gives?
    Find Nedry!
    Check the Vending machines!!
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: Power supply absurdity
    i would look for cold/cracked joints first...
    sigpic
    (Insert witty quote here)
    • pentium
      • Mar 2006
      • 2778
      Already checked.
      Find Nedry!
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        As I recall you have shitty or non-existent grounding in your apt.
        Mann-Made Global Warming.
        - Dr Seuss
        • pentium
          • Mar 2006
          • 2778
          Landlord came in and that was fixed.
          I can now connect my UPS and not have it complain about a site wiring fault.
          Find Nedry!
            • 31247
            bad switch/fuseholder in the original housing?
            • iKitsune
              • May 2010
              • 61
              Oooh, oooh! Can I guess? Inverted hot/neutral lines in the apartment. That won't light site wiring fault on a lower-end APC in my experience. Go to whatever they call Home Depot in Canada and get an outlet tester.
