Liteon pa-3271-06mx help!!!!
  • NConstantinou
    • May 2017
    • 354
    • Cyprus
    Dear all,
    i have the above power supply from Microsoft desktop surface.
    fuse was blown and changed.
    On input lines L & N i get a very little ac reading.
    i checked fuse, filter capacitors, coils, main mosfet and main capacitor and nothing is shown as short except the RV001 which i assume is a NTC varistor.
    i removed varistor and applied heat and is decreasing which means works ok.
    i remove bridge rectifier and i measured in diode mode and it looks fine.
    Is the problem on rectifier, it is not suppling ac!
  • CapLeaker
    Leaking Member
    • 8352
    Re: Liteon pa-3271-06mx help!!!!
    If you don’t have any AC coming to the bridge rectifier, the problem lies before it. You should have like 230V AC on the input of the rectifier and about 325VDC on the main filter capacitor. Probably something is open like filter inductor or something. Wouldn’t be the first time. Post a clear, high resolution picture from both sides.
    Do some continuity checks from the plug to the AC input of the bridge rectifier (line and neutral) and see which side is affected and where you loose it.
    • CapLeaker
      Leaking Member
      • 8352
      The AC part of the power supply is simple. I marked up a generic schematic for you. If you do find an open filter inductor, unwind one turn and resolder it to the leg. You need to get full AC power mains to the bridge rectifier. Other than that there is no DC from the bridge rectifier into the main filter capacitor.
        master hoarder
        • May 2008
        • 12175
        • Bulgaria
        If you get no AC, check or re-solder the input connector. Not uncommon to get cracked joints on those and then get nothing to the PCB. If that's not it, check the solder joints of any common-mode chokes on the input. If these two check out, measure voltage on the primary 400V electrolytic cap. Should get close to 340V DC with 230-240V AC input going to the adapter.
        • NConstantinou
          • May 2017
          • 354
          • Cyprus
          Dear CapLeaker,
          Thanks for your reply.
          the L & N lines on board show very little resistance. After the first inductor there is a green part label RV which is NTC SCK018 and is a varistor. that measures a small resistance.
          Now since at the input wires i do not have 220v AC and all solder points seem to be ok
          how i will find the defective part!
          i removed from board filter capacitor, first inductor and are not shown as open or short
          NOTE:
          If i remove RV green varistor then on LN i get 8 MOHMS resistance and increases
          • harp
            • Jun 2022
            • 648
            • Planet Earth
            On input lines L & N i get a very little ac reading. <===> ... it is not suppling ac!
            Is the problem on rectifier, <===> i remove bridge rectifier and i measured in diode mode and it looks fine.
            I dont understand what you mean...
            Maybe cable or wall socket is defective, try another to replace. From mains to bridge rectifier must be continuity on both wires, that is marked blue and green on Capleaker photo. There is no need to test this under voltage, just use continuity mode to confirm connections between checkpoint.
            And one tip: when you do a measurement to inform us, put readings what you actualy have, rather one that you do not have.
              • 31304
              no pictures yet?
              " first inductor and are not shown as open or short"
              inductors are supposed to look like a short - they are usually a coil
              • harp
                • Jun 2022
                • 648
                • Planet Earth
                Something like this
                  • 31304
                  shit pcb layout - plenty of coils to break too.
                  it probably even has active pfc to break shit
                  • CapLeaker
                    Leaking Member
                    • 8352
                    Originally posted by NConstantinou
                    Dear CapLeaker,
                    NOTE:
                    Maybe show us where you measured with the probes on a picture. Just upload the pictures individually in jpg using the same attachment function. Problem is my lil IPAD isn’t having any .rar.
                    Probably you are having an open, before it goes to the bridge rectifier. Maybe start with the power cable itself. Once that is ruled out, put your DMM in beep mode, hold one end at one pin of the power socket, then go with the other end to the bridge rectifiers two AC inputs. Make sure that L and N make it to there (small resistance). You find for example, the line has continuity from the socked to the bridge rectifier and neutral does not, you just have to trace it back.
                    • NConstantinou
                      • May 2017
                      • 354
                      • Cyprus
                      Thanks to harp and the other people for the help BUT specially harp because he had a picture of a power supply and i noticed that i replaced 2 parts in a wrong place RV001 and HS3 green part varistor and black part near main capacitor.
                      i switched them according to harp schematic and now i do have 320vdc on main
                      capacitor.
                      i there any way to test power supply without desktop!
                      if i short green and black cable it should start! Green cable is label 11vsb!
                      Thanks everyone
                      • NConstantinou
                        • May 2017
                        • 354
                        • Cyprus
                        Dear harp,
                        the fuse was blown while i was testing power supply BUT the MOSFET on heatsink was burned. and i can not see the number.
                        is it possible to tell me the number!
                        • harp
                          • Jun 2022
                          • 648
                          • Planet Earth
                          No I cant check... the picture was found on internet. BUT you can locate a driver IC and according to declarated PSU power choose a some similar mosfet who meet IC datasheet specifications.
                          Maybe to search for similar schematics or components like
                          Always use a some kind of bulb current limiter when testing and make note of place and orientation of any desoldered component.
                          • Steph.hen
                            Bridge rectifier identification part number KPB305G
                            by Steph.hen
                            Hi all, a newby question about a bridge rectifier I'm trying to identify.
                            I'm in the midst of reparing a battery charger in work which went pop, The bridge rectifier has shorted and took out a couple of other components. The rectifier in question has a part number KPB305G, and it looks like it's obsolete. Does any one know what I could replace it with?...
                            08-29-2024, 09:52 AM
                          • mpn78
                            Fujitsu Q556, What capacitor for bridge rectifier?
                            by mpn78
                            Hello
                            My Fujitsu Esprimo Q556 motherboards blew up. At least fuse, bridge rectifier and capacitor got damaged. I have changed fuse and bridge rectifier (DF1508S), but I don't know what capacitor it is (picture). I know that capacitors size is 47nF, but I don't know other specs for it. Can you help me to choose right capacitor for my motherboard?
                            There is 240V AC on input side of bridge rectifier and 340V DC as output on capasitors side.
                            Thanks....
                            04-05-2022, 12:31 PM
                          • EasyGoing1
                            Reading input and output of bridge rectifier on the same scope?
                            by EasyGoing1
                            I have a 40 volt AC transformer that I put a bridge rectifier on, and I wanted to see the input signal and the output signal on the same screen on my scope, so I set one channel up with the test lead on one side of the input and the ground lead on the other side of the input, then I used another channel on the scope and clipped the test lead on the positive side of the output then the ground on the negative side of the output.
                            When I connected the transformer to power, the wire that was connected between the ground lead on the second channel and the negative side of the bridge rectifier...
                            06-26-2022, 12:52 AM
                          • nicktasios
                            Macintosh Quadra 840AV PSU
                            by nicktasios
                            I had my Quadra 840AV (which I recapped and had working) plugged in for some time without using it and randomly decided to turn it on today. Unfortunately it did not turn on. After checking the PSU, I found out I was not getting anything from 12V, only from the 5V rail. After a few minutes, I removed the PSU and plugged it back in the electrical outlet and it suddenly started making a weird sound and soon after smoke started coming out. I quickly unplugged it. I opened it up but on first instance I didn't see anything out of the ordinary really. I later turned it back on and one of the MOVs blew...
                            12-22-2024, 05:07 AM
                          • chth96
                            How can I identify varistor which have been blew up?
                            by chth96
                            I mistakely pluged 100v japanese retro game console to 220v outlet.
                            So It seems that glass fuse and varistor have been blew up.
                            I can identify that voltage and ampere value of glass fuse(250V LF 1.6A),but It is impossible to identify varistor type in my sega saturn PSU(YAMAHA 35M07U XR258)
                            Is there any way to identify varistor type in my sega saturn PSU?
                            Any reply would be appreciated.
                            EDIT:
                            It seems that I finally found out what type this black varistor is. It is Panasonic ERZV05D221 “ZNR” Transient/Surge Absorbers (Type D) Varistor Voltage...
                            11-26-2023, 08:52 AM
