Lincoln Electric LE31MP welder not turning on
  • tibimakai
    • Jan 2012
    • 3680
    Re: Lincoln Electric LE31MP welder not turning on
    Good idea, thanks.
    • tibimakai
      • Jan 2012
      • 3680
      I did not find anything that way either.
      It's kind of scarry to work on this, with all those 3 fans spinning at max rpm.
      That 27k big resistor's value start increasing quite fast, so I can't keep it on only for a few seconds at a time.
      If I'm looking at a UC3842 diagram, pin #7 is the Vcc, which is 14.5V for me and the output #6 shows 5.5V.
      At which pin can I check if it's oscillating at the right frequency? At pin #4 I'm getting 55.99Hz and it seems like it is on and off.
      • petehall347
        • Jan 2015
        • 4451
        • United Kingdom
        Depending on the output power, switched mode power supplies (SMPS) operate in the frequency range from about 10 kHz up to the MHz range.
        maybe a shorted diode letting line frequency through
        • tibimakai
          • Jan 2012
          • 3680
          It may very well be, what is happening here, but which one?
          • petehall347
            • Jan 2015
            • 4451
            • United Kingdom
            what chip is it ? need the datasheet .
            • tibimakai
              • Jan 2012
              • 3680
              Uc3842
              • petehall347
                • Jan 2015
                • 4451
                • United Kingdom
                #27
                https://www.ti.com/product/UC3842
                plenty to read through .
                i skip read it and it appears frequency is set with a resistor and capacitor so that needs looking at .
                • tibimakai
                  • Jan 2012
                  • 3680
                  Sorry about not getting back sooner.
                  This IC needs 16V to start oscillating, and I'm getting only 15.5V.
                  Most likely that is the issue.
                  The question is, which component causing this drop.
                  There are 3x56K resistors in series after the diode bridge and from there it is already 15.5V.
                  I'm attaching a generic schematic of the UC3842 IC.
                  Before pin #7 there is a 56K resistor. On my welder I have 3x56K resistors.
                    • Jul 2011
                    • 6070
                    “I'm attaching a generic schematic of the UC3842 IC.”
                    If you can find the right diagram for the welder that you have would help
                    What else does not match the welder circuit that you
                    There components that generate the low voltage to start the circuit I would agree with you that something is keeping it from getting the high voltage to start
                    Take a picture of the board in question so we can see what type of circuit configuration that you have
                    • tibimakai
                      • Jan 2012
                      • 3680
                      Unfortunately I can't find any schematic for this welder.
                      I have posted pictures already.
                      • fuzzy4
                        Swan SP0110N electric tin opener, not turning can.
                        by fuzzy4
                        I have this electric tin opener and the part that moves the can round (1st picture), doesn't move, I can hear the motor turning, but no movement, there's something rattling inside, so presume a piece of plastic has broken, or come loose.
                        Took the bottom plate off, but left with this (3rd picture), any ideas how to get inside?
                        Thanks....
                        07-13-2025, 10:47 AM
                      • Nooy
                        VGA MOSfet permanently shorted and loss of MOSfet pad
                        by Nooy
                        Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
                        I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet...
                        02-14-2024, 02:26 AM
                      • Tomylee
                        HP 15-fc0007ca Charger Cycling On/Off with Hot MOSFET – Need Component Info
                        by Tomylee
                        I have an HP 15-fc0007ca that works normally, but when I plug in the charger while the laptop is powered on, the charging cycles on and off repeatedly—it starts charging, stops, then starts again.
                        Using a thermal camera, I identified a MOSFET that is overheating, along with a small 2R2 resistor next to it that gets even hotter than the MOSFET.
                        I also hear a “zpzpzpzp” type noise, but the noise is not coming from the same area as the hot MOSFET. I will include a photo with the exact spot where the noise is coming from highlighted.
                        Today, 12:24 PM
                      • redbaron1007
                        Help identifying mosfet on Razer Blade RZ09 (CH570_MB_NT)
                        by redbaron1007
                        I have a Razer laptop (RZ09 MB# CH570_MB_NT) that has a shorted mosfet marked BND M03 E067 that I'm unable to find anywhere online. Does anyone either know what the part number is for this mosfet or have a schematic I can find it in?
                        Backstory on the whole thing the laptop was plugged into a lamp at a hotel. The lamp got unplugged while it was charging and now the system won't power on anymore. I found the caps around this mosfet shorted and when I injected voltage into the caps the mosfet got hot and my bench psu was pulling 5A. Pretty sure this is all that's wrong with the laptop...
                        09-09-2025, 11:10 AM
                      • spleenharvester
                        Reverse engineering of DoCreate DHJ567 handheld spot welder
                        by spleenharvester
                        Hello everyone
                        I attach a schematic and teardown photos for the DoCreate DHJ567 handheld spot welder. I bought this welder for temporary use while my supercapacitor welder was waiting for replacement parts. It cost only £24, though there is a screenless version available for £17.
                        Performance: The absolute maximum it can handle appears to be 0.15mm of pure nickel. Reliability was not great - welds were very inconsistent, ranging from weak attachment to burning through the strip. However, I was able to build a 5S2P pack without losing any cells. It's a bit difficult getting...
                        05-08-2025, 02:52 PM
