Delphi 28242585 radio power supply section
  • rddube
    Aspiring Expert
    • Jun 2013
    • 940
    Trying to identify what the chip in the photo is. It is a component in the power supply section of a Delphi radio model 28242585 which is in a Volskwagen Jetta. Pin 1 is measuring 198 ohms to ground so I think I might have to change it.
    Does anyone know what this is ?
    Thank you!
  • R_J
    • 9547
    Re: Delphi 28242585 radio power supply section
    Ltc3827
    • rddube
      Aspiring Expert
      • Jun 2013
      • 940
      Thank you R_J! Is it my understanding that pin 1 is where you have the < sign ?
      • petehall347
        • Jan 2015
        • 4426
        • United Kingdom
        looks like that side to me going off what is connected to pgnd .
          • 31043
          the picture looks like you have solder balls between some of the "pins"
          • rddube
            Aspiring Expert
            • Jun 2013
            • 940
            Hi STJ, no it's just a reflection, checked it out and it is fine.
            I think I might have found where my problem is in the same power supply. Attached is a photo that I am trying to identify the component circled in red. If you look at the resistors around it, they are all giving me in the k ohms readings, while one of them is giving me 321 ohms, which is the reading I am getting from positive to ground on this power rail.
            Any idea what that component in the circle could be and is that resistor value good, or has it semi-shorted?
            Many thanks!!
              • 31043
              R5421N136C lithium ion protection ic
              ?? do you have a lithium cell in there to back the memory up?
              • rddube
                Aspiring Expert
                • Jun 2013
                • 940
                Not that I can see, and I have another 3 other of the same IC and 2 of them don't use that pin where the 321 ohm resistor is but the other one does and it is again a 321 ohm resistor.
                Could they be using this for another type of application, this is a car radio?
                  • 31043
                  probably just another company using the same code - it's a common problem
                    by sam_sam_sam
                    03-31-2024, 02:12 PM
                    by sam_sam_sam
                    07-01-2024, 06:34 AM
                  • JimBanville
                    Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                    by JimBanville
                    The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                    Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                    I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                    I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                    09-13-2023, 07:21 AM
                  • CMCM
                    Russound CA4 Power Supply Repair
                    by CMCM
                    Hello Everybody,
                    Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
                    Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
                    The outputs marked 12v and 20v are all measuring only 1v.
                    The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
                    The capacitors physically look clean (no bludgesor leaks) and...
                    07-03-2025, 01:12 PM
