Ps5 cfi-1215a adp-400fr
  • m4a2t0t
    • Mar 2013
    • 276
    Friend brought me his PS5. Says the outlet killed it and his PC. Upon opening there was no voltage coming out of PSU. Took it apart and could see 2 traces were destroyed. I fixed it with some thin copper.
    The rectifier bridge is bad, j48 and j49 were shorted, R9 is open. There are 3 other transistors and 1 diode that checked ok. Black on drain, red on source, 0.4v. Red on drain, black on source, 0.0v. OL between gate/source.
    You can see in the pic with the 18N60M2 fet it has some gunk on the pins and you can kinda see some liquid in the screw hole on the PSU shell. Not sure where it all came from but its all along the inside of the shell. The fet was covered in the liquid when I opened the PSU.
    Is it fine to use the GBU 1510 in place of the GBU 1508A?
    Any suggestions on what other components I should check to see if they shorted those fets? What wattage does R9 look like? 5W? The body is about the same size as a bic pen.
  • CapLeaker
    Leaking Member
    • 8187
    Re: Ps5 cfi-1215a adp-400fr
    You can always put a "better" diode in with a higher rating. A GBU1510 is 1000V rated vs the GBU1508 800V rating. All other ratings on the full bridge rectifier stayed the same, no problems there. If any of the fets are shorted to the gate, the whole gate drive circuit becomes automatically suspect. That is because the gate drive including the PWM just got dumped full bore voltage from the main filter caps dumped on.
    R9 looks like 2w ought to do with eaz. I don't think you get a 5w in. You can take a size measurement and then determent the wattage rating of the resistor.
    I suggest you build yourself a incandescent "light bulb in series trick", repair all you know what you know is wrong with the PSU, then use that incandescent light bulb tick and fire the PSU up. IF the gate drive (PWM) would be stuck on, the light bulb limits the current to the PS5 and just lights up bright as it can be.
    • m4a2t0t
      • Mar 2013
      • 276
      Ok thanks for the info. Parts wont be here until next week so I'll build the dim bulb tester in the meantime.
      • m4a2t0t
        • Mar 2013
        • 276
        So what should the bulbs do if its good/bad? I have 2 60w bulbs connected.
        The lights turned on then shut off. The main caps now have 390ish volts on them
        Nothing exploded so thats good
        PS5 now working thanks
          • 31055
          the higher the current the brighter the bulb.
          so if the psu has a short the bulb will be full brightnerss instead of the fuse blowing
          if the psu is good the bulb will be dim.
          and if the lamp is pulsing you know the psu is having trouble starting up
          • CapLeaker
            Leaking Member
            • 8187
            The first quick light up of the bulb during start up of the power supply is o.k. As the capacitors needs to charge up (inrush). As more power the PSU uses, as more the lamps will try to limit the current and light up brighter. Unfortunately there is no one bulb fits all approach on this, so just put more bulbs in series. I am using mostly anything between 60W and 200W, because it works for me best.
            If the light comes on and stays bright, you now you got some kind of problem in the primary, unless you used a too small wattage of a light bulb. This trick works very well, but you have to keep potential pitfalls in mind.
            Congrats for the repair! I just did an HDMI repair on a PS5.
            • repair-it
              TOSHIBA DLP 52HM95 How to reset timer module on bulb
              by repair-it
              I replaced the bulb only on my Toshiba DLP The bulb is a TB-25. This is the first time I've done a bulb only replacement. Supposedly there is a timer module that needs to be re-calibrated or reset. I don't know where the module is located. I see some vendors selling the bulb with the housing stating module included which leads me to think the module is located inside the enclosure the bulb mounts in, but I didn't see it. Maybe it's inside the plug attached to the bulb?
              Anyway - I am seeking information on how to reset this so called module so that the lamp will operate. Apparently...
              10-11-2023, 07:18 PM
            • ezenia
              LUMIMAN Smart Bulb IC ID?
              by ezenia
              I have a LUMIMAN Smart Bulb that suddenly stopped lighting one day. The bulb is still detected in the app, but won't light. I've probed around and nothing seems to look off with any of the diodes, caps or resistors. The Bluetooth/Wi-Fi module seems to be working as it's still detected in the app. I even tried deleting and re-pairing the bulb (it didn't light, but I was still able to follow the pairing instructions), it re-paired fine, but still no light.
              In diode mode, the LEDs all light up when probed so I'm guessing this means the LEDs themselves are OK. I was expecting...
              04-28-2025, 05:56 PM
            • Lvsitano
              Asus X532FL 3.2V at source and gate
              by Lvsitano
              I am having some trouble with troubleshooting a Asus X532FL rev 2.0 motherboard, which does not power on. So at the first MOSFET, I am getting 19V at the drain, and then 3.2V on both gate and source (compared with ground). Of course, the 2nd MOSFET's source will have 3.2v at source.
              First MOSFET is a QM3056M6 and 2nd MOSFET is a QM0930M3
              I already checked first MOSFET and source and gate are not shorted (drain with source not shorted either). Also I have 1.7V at the LDO rail (measured at the keyboard connector, as the power button is on the keyboard).
              First...
              06-26-2024, 02:13 PM
            • JimBanville
              Replacing incandescent bulb on Pioneer LD player with led. Need help :)
              by JimBanville
              I have a pioneer dvl-909 LD/dvd player from 1998. It has a light on the front panel that lights up when you play a dvd. I removed the bulb and it appears to be a tiny incandescent bulb. Its measures "open"/dead and the bulb is black like it's blown. The socket it fits into measures 5v. I've looked up the schematics and there's no indication of the amperage. I don't want to spend any money on new parts, but I have a pack of like 100, 3v, 20ma LEDs and I have various resistors.
              Is there a way for me to determine the amperage going to the old dead bulb with my multimeter?
              01-24-2023, 07:49 AM
            • howardc64
              Macbook Dust-Gate Preventive Cleaning
              by howardc64
              Just did this on my 2021 13" MBP M1. Dust-Gate design flaw still present. Depending on cleanliness of the operation environment (often eating while using MB is probably the worst). Periodic cleaning is probably warranted.
              Note this is quite challenging effort. One misstep will damage the LCD flex and render it useless. So take it to someone more experienced if uncertain.
              https://www.ifixit.com/Guide/MacBook...leaning/177920
              10-09-2024, 10:10 AM
