Power supply Termaltake Smart Se 630w any voltage in output
  • labello
    • Mar 2018
    • 278
    • italia
    Re: Power supply Termaltake Smart Se 630w any voltage in output
    What wattage bulb did you use? Did any of the voltage rails come up for a brief period? You may have to put the DMM in a fixed range.
    Hi, sorry for my reply late but I was so busy. Anyway I used 100w for bulb..The voltage on the rails I didn't know how to check 😅
    • labello
      • Mar 2018
      • 278
      • italia
      Hi sorry I'm late 😅 anyway I used bulb with 100w , I didn't check the voltage on the rails because I don't know how to check 😅 thank you
      • labello
        • Mar 2018
        • 278
        • italia
        Originally posted by momaka
        If you have a transistor tester or ESR meter, pull out the big electrolytic cap on the primary and measure it. Also pull all of the small caps on the primary side and measure them. Post what results you get for these. If you don't have a way to measure ESR on caps, best bet is to replace all of the small caps with high-quality Japanese low ESR ones.
        (Hi I checked already with esr meter out of the circuit the big one ( primary side) and a couple of those on the secondary )
        For the dim bulb tester, go straight to a 300-500 Watt heating element or incandescent / halogen lamp. Often times, 100-150W is not enough for APFC circuits, IME. Also put a small load on the PSU's 12V and 5V rail (12V halogen lamps rated 10-20W should be OK... or a bunch of 10-Ohm 3W resistors on the 5V rail and one or two 100-Ohm 2W resistors on the 12V rail), just to make sure the PSU is not turning on due to not having a sufficient load (some ATX PSUs are like that.) You might have to ditch the dim bulb trick for this test, as any load on the output of the PSU would ask for an even larger heating element or light bulb in order for the APFC to work.
        Well here I don't know anything else 🤷
        • labello
          • Mar 2018
          • 278
          • italia
          Hi guys , do you think I'm going to put it in the bin..? Because I don't know what I should do. ��
          • CapLeaker
            Leaking Member
            • Dec 2014
            • 8351
            There are no shots one the primary or secondary? Try plugging the PSU straight into power mains and see what happens.
            • labello
              • Mar 2018
              • 278
              • italia
              #26
              Hi you mean bypass the chassis? I do already Notting happens, I only found one diode rectifier on the secondary
              , and notting more , the situation is the same I have some voltage in output but doesn't start
              • CapLeaker
                Leaking Member
                • Dec 2014
                • 8351
                O.k. So the super visor is disabled and when you plug the psu in the bulb keeps flashing? And if you plug the psu straight to power mains nothing happens?
                There’s got to be either a full short on the secondary or something wrong with the feedback.
                • labello
                  • Mar 2018
                  • 278
                  • italia
                  #28
                  Yes both situations( though the bulb ,and straight to power) nothing happens..I think there's nothing I can do, I can't keep going because I don't have a lot of experience with this kind of problem..🤷‍♀️🙄
                  • Jembang
                    coocaa 50S5G smart tv dropped voltage when connecting power supply to mainboard
                    by Jembang
                    good day hoping someone can lend a hand, im repairing smart tv 50 inch, status when turning on back light is dim but you can see the tv logo then slowly fading out to black, i check the supply to tcon, i only read 5+v, must be 12v, i removed lvds cable and check voltage to mainboard turned on its also 5v, then i remove the cable mainboard to power supply, i read 12v in power supply, thinking that the problem is in the mainboard, coz theres 12v in power supply, i also check while turning on checking volts in main board 12v dropping to 5v, im just new repairing in TV, hope someone see my post t...
                    11-01-2024, 09:55 AM
                  • Tynan Dill
                    by Tynan Dill
                    Assuming...
                    11-22-2024, 01:46 PM
                    Adjustable Boost Power Supply DC-DC Constant Voltage Current Charging Module
                    I want to know if I could hook up a solar panels to this boost converter would I have any issues doing and I would have issues what would they be
                    https://www.ebay.com/itm/116497313155?var=416785404161
                    Here are some of the description from the eBay seller
                    The main parameters:
                    1. Product name: High-power non-isolated DC boost module power supply.
                    2. Product model: 100A2000W.
                    3. Input voltage: DC12V-60V.
                    4. Input current: 100A (maximum)....
                    05-18-2025, 09:45 AM
                    LM358 LM358S-13 Datasheet
                    The LM358 LM358S-13 consists of two independent, high gain, internally frequency compensated operational amplifiers which were designed specifically to operate from a single power supply over a wide range of voltages. Operation from split power supplies is also possible and the low power supply current drain is independent of the magnitude of the power supply voltage.
                    Application areas include transducer amplifiers, dc gain blocks and all the conventional op amp circuits which now can be more easily implemented in single power supply systems. For example, the LM358 series can be directly...
                    10-07-2024, 04:12 AM
                    How to modify a switching power supply that has voltage/current adjustable but powering it from a battery pack
                    I have been pondering this question for a while but now I have see if this doable but I need to answer this question once and for all
                    I would like to know how to safely do this undertaking my first thought is to solder wires to the main filtering capacitors and see
                    what voltage I am getting and seeing if I can build a battery pack with voltage or not and if
                    I can find a BMS balancing protection board at this voltage level and weather or not do I have use more than one BMS balancing protection board...
                    05-11-2025, 05:22 PM
