Re: Antec SL350P worth fixing?
no, it needs a coil, a recap and a pfc fet.
(and maybe the pfc chip - dont know yet)
i can buy most of it, but i didnt rewind the coil because of warnings here about heat effecting the core.
if you write one off, i need a PFC coil.Leave a comment:
Originally posted by Th3_uN1Qu3Btw, *all* the Fuhjjyu caps inside tested good.Leave a comment:
Funny side note, I got hold of an Antec Smartpower earlier in the week.
All Fuhjjyu caps *look* ok, but a teapo and the OST primaries are bulged.
This particular PSU is manufactured "backwards". Antec designed it that way for their 3U rackmount case. Input power, exhaust fan (I hope it is reversed in this unit) and cables all come out of one side, the side that would usually face outwards.Leave a comment:
Well, the bulb prevents large scale destruction when testing, but otherwise it just gets in the way, because it drops a lot of voltage.
Anyway, while taking the caps out i noticed why it wasn't working - the bridge rectifier was missing. But at the state that the board was in, i wasn't keen to put the caps back in and install a bridge.
Well, the L&C PSUs also have a 2-transistor 5vsb circuit (for some reason, though, they do seem to last longer than the Antecs). Just make sure to replace the critical 5vsb cap on those (usually a 22uF or 47uF on the primary side).
Originally posted by Th3_uN1Qu3I use wire like that, actually a bit thicker, when i'm out of fuses.. But if it works for you, then good. You can also just wire a 100W lightbulb in series instead of a fuse - if a short occurs, the light bulb will turn on.
My experience with antec:
https://www.badcaps.net/forum/showthread.php?t=8385
If you want fireworks you can try replacing a 4.7ohm resistor that is used as a "fuse" of sorts in 5vsb circuit. I replaced it and plugged one of my antecs and...BANGLeave a comment:
Okay, then it's disassembly time.
I use wire like that, actually a bit thicker, when i'm out of fuses. And it blows at 5A. If the wire would have been thick enough, in the event of a catastrophic failure one of the primary capacitors would have blown open, which it didn't.Leave a comment:
They are decent power supplies, minus the 5vsb circuit. At least from what I understood when reading a few of Everell's threads on 2-transistor 5vsb circuits is that they are hard to troubleshoot/repair. This is why he normally does his infamous DM311 chip mod. Here's a few similar Antec PSUs he modified:
https://www.badcaps.net/forum/showthread.php?t=8403
Originally posted by Th3_uN1Qu3The "fuse" (which someone replaced with a piece of wire) did not blowLeave a comment:
I've gotten a number of power supplies yesterday, including this one. I was impressed by the amount of caps and inductors they could cram on the secondary and by the full transient filter, however the caps are a huge letdown (all Fuhjyyu), especially the 330uF primary caps. They all look fine but i'll test them on the ESR meter that i built 2 days ago just to make sure.
Anyway, this thing is basically shot to hell. The board is burned in the primary, interestingly not under any transistor. The "fuse" (which someone replaced with a piece of wire) did not blow, the primary switchers test fine, but the standby switcher is toasted. The wire used for a fuse was thin enough, i also have a couple others with intact fuse but blown standby circuit, they all blew up in the same way. It does nothing when i plug it in, which i think is kinda weird for a shorted transistor (no fireworks?), but the others with blown standby switch do the same.
So is this thing worth fixing? I don't really like running stuff with burned PCBs, but this one looks decent otherwise. Alternatively, i think i could "upgrade" three L&C PSUs with what's in this one. I'll post a pic tonight.Tags: None
by momakaI know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
https://www.badcaps.net/filedata/fetch?id=359177... -
by iamwiseHi all, I picked up a liquid damaged Asus TUF Gaming F15, does not power on, model FX506HM-HN004T.
Ive gone as far as removing the case and doing a visual check, there is no visible corrision, upon plugging in the power brick a single led light shows that power is plugged in, but no display or fans, the PCH chipset gets warm/hot to the touch, could this mean its not fixable or do I proceed and remove the motherboard completely and check further for shorts etc, failing that should I just take it to a service centre and go from there
what would you do? my skillset is... -
by momakaNormally, I never post repairs this quick after I do them, because… I am usually very slow.
But today, I’m making an exception here. Why? No idea. Perhaps only because the repair details are still “fresh” in my head… which is ironic, given this is a 16 year old monitor that hardly anyone will care about today. It is new to me, though.
I picked it up last November from someone on my local Craigslist. It wasn’t very close to where I live, but was close to a family friend that I had to go visit anyways. So after watching the posting on Craigslist for a few weeks and seeing it getting...
by ExoticsHere's a video I uploaded to show the problem.
https://youtu.be/MbaZQ7aYMMY?feature=shared
Quality isn't 1080p yet because I just uploaded it. YouTube takes a while to process videos to maximum quality.
I have a multimeter and basically no electrical fixing knowledge.
I came across a post on here describing the same issue if it helps y'all help me. -> https://www.badcaps.net/forum/troubl...500-done-today
please help me diagnose and...-
by madyoyoHi
I have a Samsung QE55Q65B with a seemingly common problem: it turn off and back on after a few seconds, (sometimes more, and in rare instances works for hours). D001 on the left side of the panel is very hot. I may be able to remove it with a very fine iron, but i don't have the equipment to re-solder such small parts.
Is there a risk to run the tv without this diodes diodes? And is it worth to pay someone else to replace it. I read many people who ended up with bad lines after trying to remove/replace them, , or the panel failing in another way, so i want to weight... - Loading...
