Antec SL350P worth fixing?
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    Re: Antec SL350P worth fixing?
    Originally posted by stj
    i found a core the same size in something else - not a psu.
    it may be good for a rebuild but i'm not sure if there is more to cores than dimensions.
    Does it have the same colors? Toroids are color coded, if it's another color, just use the Micrometals calculator to determine if it is suitable and how many turns you have to wind.
    A working TV? How boring!
    • everell
      • Jan 2009
      • 1514
      Th3_uN1Qu3...........did you get your Antec SL350P fixed and working?
      Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
      • shovenose
        Send Doge Memes
        • Aug 2010
        • 6575
        Stj-do you still need the coil? I have one that may be the one youneed nyou can have it free...
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          @ everell: Nope, took it apart entirely. I thought i said already i decided it's not worth fixing.
          • shovenose
            Send Doge Memes
            • Aug 2010
            • 6575
            Hey, i hav a queation for you the_unique (too lazy to put the 3s in there), are any of the components inside a psu suitable for any part of the psu loader?ive got a coil or 2, 2 small resistors, and a bunch of those black things that were screwed to the heatsinks. And of course i Have a few of the salvaged heatsinks. I also have the completely empty case of a hipro atx psu where i could put the stuff into. Would that work??? Thanks!
              • 31304
              the case, the fan and the black things could be used to create a load of some kind.
              • Th3_uN1Qu3
                Believe in
                • Jul 2010
                • 6031
                #27
                You can use multiple of those minimum load resistors in parallel, strap 'em to a heatsink and watercool them (ie toss them into a bucket of water). They don't take more than 10 minutes at a time (then you'll have to change the water), but should be enough to help you figure out a thing or two.
                As for "the black things", the diodes (the ones on the secondary) aren't suitable, the transistors maybe, but they have too low current capability for 12v use, they are designed for mains voltage and relatively low current compared to the output of a typical PC power supply.
                Don't worry, i haven't aborted my load tester project. I'm soon to receive a FREE big heatsink and i already earned bout $80 more, so it should be completed in about a month.
                • c_hegge
                  • Sep 2009
                  • 5219
                  I'm also working on mine. Got a case sorted and the heatsinks, as well as a few of the load resistors. Just got to get the rest of the resistors and some good thermal epoxy to stick 'em to the heatsinks, and some switches so I can turn certain resistors on and off to adjust the load and I should be done.
                  Oh, and about antec smartpowers, I NEVER re-cap them. I just scavenge the heatsinks and fans and whatever else I decide might be usefull and junk them. They always make a really annoying high pitched squeal after the re-cap.
                  • shovenose
                    Send Doge Memes
                    • Aug 2010
                    • 6575
                    why would they do a squeal after recap? has a component be damaged by the bad caps?
                    btw im sort of hating my antec smart power 350w (not recapped yet)...
                    because i decided to touch the primary heatsink while it was on to se if it was getting hot-not exactly a good idea...
                    ill have to be more careful about having psus plugged in and i now know not to touch the heatsinks
                    i didnt fly across the room, it wasnt that dramatic, but it felt RELLY weird
                    also, i have some other resistorsthat i will look at the spcs and see if they will be helpful in this project!
                    will an empty psu case create enough airflow?
                      • 31304
                      tbh i thik smartpower are junk, truepower are the good ones.
                      i have both.
                      the only reason i have not scrapped the smartpower is because it's a modular case and i cant bring myself to scrapping it.
                      that could change - every time i look at the size of the cap-list and the cost of the fet i get the urge to switch the iron on and get the electric screwdriver out!
                      • Th3_uN1Qu3
                        Believe in
                        • Jul 2010
                        • 6031
                        #31
                        The heatsinks are usually connected to ground. Note "usually". A friend has an UPS that says on the board "The heatsinks are not grounded and present risk of electric shock. Test before touching." This is something that you should ALWAYS do on any heatsink in any high voltage device.
                        I've gotten zapped quite a few times myself, and it was always due to carelessness. So watch your fingers mkay?
