AeroCool VP-550 : IC identification issue
  • bendeg
    • Apr 2023
    • 24
    • Belgium
    Hi there,
    A few years ago, my ATX Aerocool VP-550 blew its fuse. I replaced it : it blew again...
    A IC blew as well, and is now showing it guts (see center of the picture).
    After some research, I think it belongs to the STR-A6000 series (Off-Line PWM Controllers with Integrated Power MOSFET).
    I can see its first 2 digits "A6...."
    It has only 7 pins instead of 8 (no pin 6)
    It's located very close to the filter capacitor (180uF, 400V) of the primary stage.
    Does someone know what IC it is exactly ?
    Other components out-of-order (maybe more...) :
    • thermistor SCK-2R56 (2.5 ohms, 6A)
    • Bridge rectifier GBU606 (short)
    • Capacitor (180uF, 400V) shows 5.5uF on digital multimeter
    • unknown IC (STR-A6000 series?)
    • MOSFET MDP13N50 (sits just next to the bridge rectifier on the same heatsink, short)
    Last edited by SMDFlea; 04-03-2023, 09:16 AM. Reason: Added image to badcaps from external link
  • CapLeaker
    Leaking Member
    • 8352
    Re: AeroCool VP-550 : IC identification issue
    Hopefully you were careful opening the case. The rest of the lid of the IC should be floating around the inside of the power supply. I think you are right on it being a Sanken STR-A60xx series. Luckily there aren’t many to choose of. However these very few to choose of have different switching frequency. 67 vs 100khz.
    • bendeg
      • Apr 2023
      • 24
      • Belgium
      Unfortunately, I didn't pay attention while opening the case, and the rest of the IC is lost...
      As for the exact part number, I ordered a few STR-A6059H (the first of the series working at 100kHz), thinking maybe it was related to another IC on the other side of the PCB : a CM6805BG (10-PIN Green-Mode PFC/PWM Combo CONTROLLER), which also works at 100kHz.
      There's certainly a way to determine, or at least narrow down the research, to find which one would fit knowing the other components connected to it but I don't know how and I couldn't find a place where to order a complete STR-A6000 series.
      Probably Vdss MIN(V) and Rds(on) MAX (ohm) of the IC can give some important information to choose wisely...
      Thanks for your reply.
      • CapLeaker
        Leaking Member
        • 8352
        Nope. That’s not how the PSU works. There are 2 parts to it. One part is always on and that’s the part this Sanken offline Switcher does. Then there is the PWM / PFC and that is your main power supply, plus the supervisor IC on the secondary.
        Look up the Powerman IP that I repaired. My bet is that not only this offline Switcher is bad, the main filter cap (400V) is probably toast too. While you are at it, change each cap near a heatsink too.
        • bendeg
          • Apr 2023
          • 24
          • Belgium
          Nope. That's not how the PSU works. There are 2 parts to it. One part is always on and that's the part this Sanken offline Switcher does. Then there is the PWM / PFC and that is your main power supply, plus the supervisor IC on the secondary.
          Oh ok, I thouht these 2 ICs were related. I know now they aren't.
          So, if the STR-A6059H I ordered fits well (fingers crossed...) and replacing the thermistor, the bridge rectifier, the MOSFET and the unique filter capacitor (180uF, 400V, reads only 5.5uF with the multimeter), I should see +5V on PS-ON and +5V on STAND BY, right ?
          (I should probably better try with a bulb in series first...)
          There's indeed another IC on the other side of the PCB which controls PFC : CM6805BG (10 pins, surface mounted). Well, I think that's the one who does this.
          There's indeed also a supervisor IC : HY-510N in the secondary part.
          You mean my PS is bad ? Possible, I'm not a pro...
          Do you mean replacing ALL caps that sits next to a heatsink, even small ones !?!? (I suppose you talk about electrolytic caps only...)
          But I remember seeing a beautiful spark while connecting the 4 pins CPU connector and I think my motherboard has suffered since then...And that any even new PS connected to it suffers...
          I had to buy a third power supply, which also suffered, and I can't use my PC since a few years (I had to manually short the green and black wire to start it, and then push on the start button of my PC, really weird...). In short, a big mess...
          I've seen your post about your Power Man : f... capacitor...
          Well, I already know mine is out : reads 5.5uF instead of 180uF with my DMM
          • bendeg
            • Apr 2023
            • 24
            • Belgium
            What do you think of such fuse holder in a PC power supply ?
            1. Ok, no problem
            2. No way !
            3. At your own risks !
            In fact, I don't really trust that kind of holder : inner springs might be loose over time...
            • CapLeaker
              Leaking Member
              • 8352
              Wrong way of testing things. Make a jig called a dim bulb tester. Works only with incandescent (old style) light bulbs. Get a 60w, a 100W and a 150w or 200w bulb. Otherwise you still risk that you blow parts up that you just put in.
              • bendeg
                • Apr 2023
                • 24
                • Belgium
                Ok, thanks for the advice !
                • bendeg
                  • Apr 2023
                  • 24
                  • Belgium
                  Hopefully you were careful opening the case. The rest of the lid of the IC should be floating around the inside of the power supply. I think you are right on it being a Sanken STR-A60xx series. Luckily there aren't many to choose of. However these very few to choose of have different switching frequency. 67 vs 100khz.
                  I've received the STR-A6059H (working at 100kHz), and ready to be soldered, but I think it may not be a good idea (I've ordered 6 others of the series, mainly those that works at 67kHz, but 2 others that works at 100kHz as well, a bit crazy but I must try...) :
                  Let's suppose the proper IC should work at 67kHz, it such a case it means it also expects modulation feedback that would not match if I put one that works at 100kHz, right ?
                  In a nutshell, in such a case, the "modulation time" of the feedback would be too long with the STR-A6059H and the IC would work almost twice as much time, maybe at 100%, overwhelming the circuit. See what I mean ?
                  It would be the other way round if I put a 67kHz one intead of a chip that should work at 100kHz ?
                  Am I wrong ? Or is the feedback automatically "sensed" ?
                  • CapLeaker
                    Leaking Member
                    • 8352
                    I did some digging (being bored this morning ) and I found one single reference on the AeroCool VP-550 that chip in question being an STR-A6069H.
                    Good luck!
                    • lotas
                      • Jan 2016
                      • 4921
                      • Russia
                      Yes, in these series is STR-A6069H.
                      • bendeg
                        • Apr 2023
                        • 24
                        • Belgium
                        Good luck!
                        As I see in the datasheet A6059H has the same specs (it would probably be a good replacement IC)
                        But how the hell did you find that !?!?
                        Thank you so much !!!
                        • bendeg
                          • Apr 2023
                          • 24
                          • Belgium
                          It's a slightly different configuration (there's a second capacitor near the heatsink and there's no what looks like a yellow capacitor close to pin 3 and 4)
                          But anyway, thank you so much !!!
                          I also plan to install a 8 pins socket so IC can be replaced easily if needed.
                          Keep you all updated once I've got all parts soldered.
                          Fingers crossed...
                          • CapLeaker
                            Leaking Member
                            • 8352
                            By not using Google as a search engine. Yw.!
                            Using a 6069H or a 6059H doesn’t matter. The Difference is the max input voltage handling of the IC.
                            • bendeg
                              • Apr 2023
                              • 24
                              • Belgium
                              Using a 6069H or a 6059H doesn't matter. The Difference is the max input voltage handling of the IC.
                              Indeed, I only tried google search...
                              Oh, ok, it'll be the A6069H or any A606x then (700V max), not the A6059H (650V max).
                              Thank you very much for that info !
                                master hoarder
                                • May 2008
                                • 12175
                                • Bulgaria
                                Don't!
                                The Source and Drain pins on the IC (mostly the Drain pins) are used as a heatsink. If you install on a socket, the chip will likely overheat and die faster.
                                Solder it in, instead.
                                Make sure to also replace that failed primary cap. This is likely the reason the IC blew in the first place. With APFC circuits, if the main cap fails, a nasty high-voltage spike will appear downstream on the primary side. Sometimes it kills nothing and PSU just blows the fuse on the input. Other times, it can kill the APFC MOSFETs, main PS MOSFETs, or even the 5VSB / standby offline switch IC (STR-A6069H in your case.)
                                My personal suggestion is to also put a polypropylene cap in parallel with the mains cap, so in case of a failure of the big cap again, the PP cap can take some of the energy / high-voltage spike and be less likely to end up with other dead components. Use a PP cap between 0.1 to a few uF, rated for 450V minimum (630V better.)
                                Lastly, use a dim bulb tester when testing the 5VSB with the replaced IC. 60-100 Watts incandescent or halogen will do. Once 5VSB function is verified, you can test the PSU with a slightly bigger halogen bulb in series - 200-300 Watts... or hair dryer on the "low" setting.
                                • bendeg
                                  • Apr 2023
                                  • 24
                                  • Belgium
                                  Originally posted by momaka
                                  Don't!
                                  1)
                                  Fortunately, STR-6069H hasn't been delivered yet. Thank you for the advice !
                                  And indeed, as I can read in the datasheet, page 23, for pin 7 (I believe this is what you want to tell me...) :
                                  (7) Thermal Considerations
                                  Because the power MOSFET has a positive thermal
                                  coefficient of R DS(ON) , consider it in thermal design.
                                  Since the copper area under the IC and the D/ST pin
                                  trace act as a heatsink
                                  , its traces should be as wide as
                                  possible.
                                  2)
                                  I already planned to change the main cap (JunFu, 180uF, 400V, 85°, LG, 25mm x 40mm snap-in) : my DMM shows only 5.5uF instead of 180uF...
                                  I have 2 different new caps replacement:
                                  • Nichicon, 180uF, 400V, 105*, PT(M), 18mm x 40mm
                                  • Nichicon, 180uF, 450V, 105°, GG(M), 25mm x 40mm snap-in and fits perfectly (same size as original)
                                  Is this a problem to put the first one (18mm x 40mm) ? Should the size match the original perfectly ?
                                  3)
                                  polypropylene cap : you mean a capacitor that looks like a yellow X2 capacitor or that looks more like a woman handbag, a brown purse like this one :
                                  4)
                                  You mean that if a test with a 60-100W bulb in series pass with the new IC, I should try with 200-300W bulb afterwards or an hair dryer ??? Not sure I understand that part, do you mean connecting a hair dryer on the "low" setting in series with the PSU ?
                                  I don't have a hair dryer but I have a small 500-600W hand mixer (in the kitchen) with a turbo button (a "normal" button and a "turbo" button), that might work as well :-D
                                  I knew for the test with a bulb of about 60-100W, but not more, why is that needed ? To test little by little to make sure nothing wrong happens ?
                                    master hoarder
                                    • May 2008
                                    • 12175
                                    • Bulgaria
                                    1)
                                    possible.
                                    Yes, this is exactly the reason.
                                    2)
                                    Use the 450V cap.
                                    For the primary cap, bigger is always better - both in terms of size and capacity. This is one part where manufacturers save the most money by using parts that are just adequate enough for the power rating of the PSU at the expense of the part not lasting as long.
                                    Since the 450V cap fits perfectly in terms of size, use that. It should last a lot longer than the original.
                                    Better yet, if you can get an bigger cap (say, 220 uF) to fit and if it doesn't cost significantly more, that would be nice too. But don't sweat it too much. Looks like you already found a cap that fits and rated for a higher voltage, which is even better.
                                    I try not to use anything lower than 420V -rated caps for PSUs with APFC circuits. 400V caps just seem to not last in certain APFC circuits.
                                    3)
                                    Use the "woman handbag" one... and LOL! That's actually a pretty accurate visual description, I like it.
                                    Just make sure it is Polypropylene (PP) type. Polyester (PE) can look the same... and for the most part, it's still a film capacitor and will work mostly the same. However, PP has better frequency response and is the one recommended for high-frequency circuits.
                                    I don't know if I can recommend X2, since it's mostly for AC input filter applications, and here on the APFC we are dealing with high-voltage DC (with small HF AC ripple.)
                                    4)
                                    Install new IC and test with 60-100W bulb in series with the PSU, like this:
                                    https://www.badcaps.net/forum/showpo...51&postcount=6
                                    https://www.badcaps.net/forum/showpo...4&postcount=70
                                    The 60-100W bulb is only when you want to test if the PSU outputs 5VSB. Once you want to test the entire PSU (by connecting PS_ON to ground), you will need to replace the 60-100W bulb with something more powerful, because of the APFC circuit. APFC does not like high-impedance paths on it's supply input, which is what the 60-100W will be at the high frequency that the APFC circuit pulses its MOSFETs to primary ground. What will likely happen with the 60-100W bulb if you try to power-on the PSU (PS_ON to ground) is the bulb will likely flash on-and-off very quickly or just stay lit continuously and not let the PSU start.
                                    For this reason, you connect a higher-power linear device, such as hair dryer, toaster, heat gun (non-digital one)... or just 4+ 60-100 Watt incandescent or halogen bulbs in parallel (4x 60W bulbs in parallel = 240 Watts equivalent.)
                                    Mixer probably won't work, since it has a motor inside. You want a device / appliance with some sort of heating element and simple On-Off switch control (i.e. no digital circuits or "soft" push-buttons.)
                                    If you don't have such appliance, just use incandescent or halogen bulbs. I know that in EU it's harder to get these now. If that's the case and you can't find such higher-power bulbs, use 40W incandescent "appliance" type bulbs - these are regular incandescent bulbs, but they work the same. EU can't ban these, because appliances such as your kitchen oven can't use LED or CFL bulbs inside it - they simply won't last. So "appliance" incandescent bulbs are exempt from the incandescent bulb ban.
                                    Pretty much, yes.
                                    60-100W for testing the 5VSB.
                                    200-300W or more for testing whole PSU (PS_ON connected to ground.)
                                    That being said, beware that some PSUs won't work without a small load on the output. You may have to connect an HDD or two or three... or a 12V halogen bulb on the 12V/5V rails. In such case, however, just know that the higher the load you put on the output of the PSU, the bigger the power rating of the series incandescent/halogen bulb will need to be on the input.
                                    IME, the limit is usually around 20-25% of the power of the series bulbs - i.e., if you use a 300W halogen bulb on the input of the PSU, you may be able to pull only about 60-75W of power on the output. This is for PSUs without APFC. With APFC, the dynamic can change a little... but assuming 20-25% again is a pretty safe bet.
                                    • bendeg
                                      • Apr 2023
                                      • 24
                                      • Belgium
                                      Oh, that's a lot of information.
                                      There's more to do now...I'll update this thread when I've got all the components.
                                      Thank you very much !!!
                                      • bendeg
                                        • Apr 2023
                                        • 24
                                        • Belgium
                                        What is the power rate of that 5 bands resistor (1 stage, near the big capacitor) ?
                                        I couldn't find a color code calculator that found the answer using 5 bands.
                                        Looks like it's a 4 bands resistor with a fifth one...
                                        According to its color, BROWN - BLACK - SILVER - GOLD - GREEN...
                                        (correct me if I'm wrong, I'm color blind, I've got problems especially with the greens, I'm a "deuteranope" guy)
                                        ...it's a 4 bands resistor, and it should be a 0.1 Ohm 5% resistor, right ? (and indeed, I can measure it with my DMM).
                                        Then, if it's a 4 bands resistor, what is the meaning of the last green band ?
                                        Also, how can I find the power rating so I could order one if needed (even if it looks in good shape to my eyes) ?
                                        Dimensions : width = ~17mm, diameter = ~6mm
                                        Is it a 5W resistor ? More than 5W ?
                                        • rounin
                                          MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                                          by rounin
                                          🛠 Original Issue
                                          ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                                          04-19-2025, 01:18 AM
                                        • ugamazing
                                          by ugamazing
                                          12-17-2024, 07:05 PM
                                        • shahnld
                                          Lenovo legion 5 pro startup issue
                                          by shahnld
                                          Good day Experts
                                          I have a lenovo Legion pro 5 16ACH6H with AMD RYZEN 7 5800H and RTX3070,.
                                          A weird issue has troubled me. If i power on off the laptop 20 times then only power LED will lit but no fan spin no display. At this stage gpu, vram. DDR voltage. 5v 3.3v 1.8v and the rest are present and cpu core is stuck at 0.84v.
                                          And sometimes lets say the 21st time it will boot perfectly and there is image and everything is working perfectly and at this stage i see cpu core...
                                          08-24-2025, 12:31 PM
                                        • ahmarzo
                                          Acer laptop battery draining issue
                                          by ahmarzo
                                          Have a acer laptop ex215-22 with motherboard part no daz8emb18a0 the issue is the battery gets drain overnight upto 25-30 percent even when switched off / shutdown.even after ssd is removed and laptop off with button the battery keeps draining.i have updated the bios but same issue have tried another new battery and the charging works fine only issue is battery is discharging when connected to motherboard in off condition.
                                          Help me to diagnose this issue as there is no shortage in the inputs MOSFET
                                          08-02-2025, 06:39 AM
                                        • elmark
                                          HP 15-cw1002ua strange keyboard issue
                                          by elmark
                                          HP Pavilion 15-CW1002UA
                                          S/N 5CD0251CBC
                                          P/N 7KE54EA
                                          Hello guys!
                                          I have a strange issue with my laptop keyboard and I'm lost trying to detect what's wrong - the KB9028Q-C or the keyboard itself.
                                          It powers on OK and has no other issues except the following:
                                          • CAPS LOCK does not work at all
                                          • Fn button toggles Flight Mode
                                          • When I press 't' or '5', it produces 't5', and when I press 'y' or '6', it produces 'y6'
                                          • (with SHIFT pressed: 't%' and 'y^' respectively)
                                          I initially thought it was a keyboard malfunction (internal short, etc.),
                                          but when I press and hold...
                                          06-27-2025, 01:10 AM
