Inverter Welder Strangeness
  • Crystaleyes
    • Sep 2021
    • 493
    • Brazil
    Re: Inverter Welder Strangeness
    I'm thinking that the problem is with the PWM controller or circuitry, as having another look, but with a fresh head, reveals that the two outputs of the SG3525 are unequal when measured across to pcb main ground.
    VCC to ground pins, reads only +0.02 volts, when according to the datasheet it should be between +8 and +40 vdc.
    Granted the tester is not a Fluke but it generally gives a good idea
    Anyway, taking an AC voltage measurement on the SG3525, it fluctuates around 2.5 v on both outputs, and the frequencies are around 40KHz on output A, and 35KHz on output B.
    In 'Frequency/Duty Cycle' test mode however, the readings are fluctuating at just over 170KHz on 'A' and just over 160KHz on output B.
    Both outputs float around 61% duty cycle in relation to ground and adjusting the control knob makes no difference at all.
    When measuring between both pwm controller outputs, the duty cycle reads a stable 50% with the frequency also stable at 45KHz regardless of knob position.
    My lack of experience aside, surely in order for this to work, the switching must be in unison?
    So if anyone has any other ideas as to where and what to test, I am all ears.
    • CapLeaker
      Leaking Member
      • 8196
      probably using wrong GND on your measurement.
      • Crystaleyes
        • Sep 2021
        • 493
        • Brazil
        I had thought about that.
        If I use the pwm controller ground then I get no readings at all. Simply zero on the voltage and frequency regardless of the position of the control knob
        Unless anyone has any other suggestions I'm gonna order a new SG3525 and see what happens?
        • CapLeaker
          Leaking Member
          • 8196
          I reread the the thread and it looks like your next logical step is to change the SG3525.
          • Crystaleyes
            • Sep 2021
            • 493
            • Brazil
            It's in the post...
            Thanks for the input. This is a steep learning curve in uncharted waters for me.
            Nice one!
            • Crystaleyes
              • Sep 2021
              • 493
              • Brazil
              #26
              Ok, the parts arrived today. I didn't have the spare money to buy the main caps but have a new controller and IGBT's.
              I'm planning on installing the controller first and connecting up through the dimbulb, but one question is,
              "should I expact to see a variable output on the SG3525AP controller without the IGBT's connected?"
              I can't afford to keep blowing them.
              • CapLeaker
                Leaking Member
                • 8196
                Then leave the IGBTs out. The gate drive failed because the IGBTs went short on all 3 legs, dumping full power to the gate drive. Assuming you got all the parts and these are good parts, you should be at the same step when you fixed the welder first time go around.
                • Crystaleyes
                  • Sep 2021
                  • 493
                  • Brazil
                  #28
                  Cool.
                  Wanna change the large caps too but first want to be sure that the chopper section is ok.
                  • Crystaleyes
                    • Sep 2021
                    • 493
                    • Brazil
                    #29
                    Ok, so installed the replacement controller chip and the welder seems to be doing pretty much the same as before.. perhaps the frequency drift range is wider (between 30 KHz and 145 KHz) but the control button on the front does fuck all. And yes, I have verified that it is working.
                    As I said, I have never looked into (nor even at) one of these inverter welders before, but from what I can see it appears to work using pulse width modulation.
                    Perhaps it only alters the pwm frequency under load?
                    Perhaps I am wrong about it using pwm and that is why I am stuck?
                    I spent some considerable time looking online for topology and functionality explanations, but couldn't find anything in clear English which had anything close to the layout of this circuitry.
                    Why are almost all the online electronic lessons in either unintelligible Hindu or Germanic versions of English?
                    Anyway, testing the A & B outputs of the controller, or testing the Gate signal of the IGBT's reveals nothing consistent nor affected by the amperage control knob on the front of the unit, which leaves me completely stumped as to what to test next.
                    One thing that seems strange is when measuring the A & B Outputs with reference to the controller Ground, output A displays a KHz signal whereas output B just goes to zero. If output B is tested with one lead only (no ground), then it too displays a fluctuating KHz output
                    It's getting to the point that even though the unit is brand new, unless there are any ideas as to what to look for, it might just end up being scrapped for parts and put down to experience.
                    One thing I HAVE learned, is that it is possible to use a bridge rectifier with only one AC input wire.
                    Still don't understand how that one works, but there you go...
                    So shall I just scrap it?
                    • CapLeaker
                      Leaking Member
                      • 8196
                      Scrapping it or not, is totally up to you. Some repairs I made took me multiple attempts too. Sometimes it’s better to put it aside for 4-8 weeks and then get at it with a clear head.
                      So you got PWM back somewhat. Measure the resistance on output a and b against gnd. I wonder if there is something dragging output b down? There has to be an explanation on why output b isn’t doing anything.
                      • Crystaleyes
                        • Sep 2021
                        • 493
                        • Brazil
                        #31
                        Thanks for the suggestion.
                        So, had a few days break and just had a little look again just now.
                        Anyways, there is no short between output 'B' and Gnd. As with Channel 'A' it reads several MΩ.
                        Checking just the voltages in both AC and DC doesn't reveal a lot, other that output A is much less stable than B. Like completely wonky and all over the shop.
                        Really, I should read up as to how these controllers generate their frequencies. Up until now, I had just 'assumed' that it would be somewhat similar to a 555, in that it will use capacitors and resistors to set the output frequency.
                        It's late again here and I am only getting late nights free at the moment, but I'll get back on it after another think,..
                        • CapLeaker
                          Leaking Member
                          • 8196
                          Seems like something might be wrong down the line on output A for some reason. I guess more tracing, drawing a schematic is in order.
                          • Crystaleyes
                            • Sep 2021
                            • 493
                            • Brazil
                            #33
                            Cheers for tthe suggestion.
                            The way the welder is designed is that 'after' the pwm controller, the two controller outputs go through what appears to be some kind of amplifying board (there is a mosfet on each channel) before the two yellow wires supply the IGBT section.
                            Disconnecting this board (and all the output circuitry) didn't resolve the pwm controller output issues, so I had a look at the IC next to the controller.
                            It is an LM358 twin Op-Amp and taking pin voltage readings appear to show that something is not quite right.
                            The pin layout is included below and the pin DC voltages are as follows:
                            1 - 14.7
                            2 - 0.17
                            3 - 10.54
                            4 - 0.041
                            5 - 0.04
                            6 - 0.017
                            7 - 0.083
                            8 - 15.8
                            I'm not quite sure where the Op Amp fits in with the PWM controller and it's too late here to start tracing it back but I'm not giving up just yet
                            Cheers
                            • CapLeaker
                              Leaking Member
                              • 8196
                              See… that’s exactly how I did repair the plasma cutter. Couldn’t really understand what is happening either in the beginning, but after a few attempts you find something that is weird and maybe should not be and build on that.
                              • Crystaleyes
                                • Sep 2021
                                • 493
                                • Brazil
                                #35
                                Well, having a think on it after, I've decided that I'm simply gonna list and test every component.
                                There are only three IC's (the third one being an LNK626), maybe ten transistors, half a dozen diodes, then a total of 70 or 80 resistors or capacitors.
                                All the resistor values are clearly stamped, so it's only the cap values which I won't be able to verify although it will be possible to identify any short or open ones.
                                I've already drawn up most of the component list, and have tested (and noted) perhaps 30.
                                Gonna have a look at, and around, that dual op-amp to see why those readings were so wrong. Maybe remove it and check the inputs?
                                Thanks again for the encouragement
                                • CapLeaker
                                  Leaking Member
                                  • 8196
                                  I would see what that opamp does and how it fits into this puzzle. Then check it out of circuit with an ohm meter. Maybe your lucky and you measure something. Opamps are cheap enough and quickly replaced too.
                                  • Crystaleyes
                                    • Sep 2021
                                    • 493
                                    • Brazil
                                    #37
                                    Ok. My 8 weeks break is up and I'm ready to have another look at this machine.
                                    I've just changed the LM358 and now we actually have even and equal output frequencies on the PWM chip, so woo-fuckin-hoo to that one! About bloody time...
                                    So, now that the pwm circuit seems fine, I think that two new filter caps is in order, so I'll order them and get back to you here.
                                    One other thing which I really want to examine is the input section, for as I said, the bridge rectifier only has one wire going to the AC pins.
                                    How the bejesus that works is like all the covid jab deaths... Baffling!?!?
                                    Anyways, feeling positive that progress has been made and I am definitely learning.. Which is why I bought this broken welder.
                                    • CapLeaker
                                      Leaking Member
                                      • 8196
                                      Sweet, that the PWM works now as it should!
                                      That AC rectifier mystery… can you take a picture? What is on the output of that rectifier? I think there is a broken off AC wire and that circuit doesn’t work. What is the part number on that rectifier?
                                      • Crystaleyes
                                        • Sep 2021
                                        • 493
                                        • Brazil
                                        #39
                                        There is no broken wire or trace going to the rectifier, as I said, the unit appeared brand new when I bought it, and it powers up and seemingly works with this peculiar configuration.
                                        Below are some photos showing the space where the bridge rectifier goes.
                                        It is a GBJ 5010
                                        If you focus on the second hole from the board edge, it can be seen that there is no trace connecting to it on either side...
                                        So how then, with or without LSD, can the current be rectified in this manner?
                                        • Crystaleyes
                                          • Sep 2021
                                          • 493
                                          • Brazil
                                          #40
                                          The welder has 127 volts AC on it's input. The output of the rectifier is a steady 305 VDC - which seems absurdly high!
                                          Measuring across the two input AC pins on the rectifier, gives around 30v. Which I suppose is what happens when you only connect one wire of the AC mains. ????
                                          Looking at these readings however, has revealed that with the main 2200uF caps being rated at 250v... (on a 305v supply).. That the original problem surely has something to do with the caps being underrated, (or perhaps more accurately, 'over-loaded').
                                          Good thing I hadn't ordered the new filter caps yet...
                                          • edugimeno
                                            Repair an inverter welder
                                            by edugimeno
                                            Hi! I got this (see pics) welder which wouldn't work at all at the welding leads. I tested output voltage and got 0v
                                            Opened it and found a diode that was busted (missing resin...). Ref RHRP1560.
                                            I believe this diode protects one of the IGBT's that drive the transformer
                                            His twin diode wasn't physically damaged but measured OL on both polarities so both will be replaced
                                            Now, after watching some videos on welder repairs, it seems that the IGBT's usually fail together with the diodes, is this true? I tested IGBT with multimeter-diode mode, still on board, and got OL on...
                                            07-19-2023, 07:28 AM
                                          • spleenharvester
                                            Reverse engineering of DoCreate DHJ567 handheld spot welder
                                            by spleenharvester
                                            Hello everyone
                                            I attach a schematic and teardown photos for the DoCreate DHJ567 handheld spot welder. I bought this welder for temporary use while my supercapacitor welder was waiting for replacement parts. It cost only £24, though there is a screenless version available for £17.
                                            Performance: The absolute maximum it can handle appears to be 0.15mm of pure nickel. Reliability was not great - welds were very inconsistent, ranging from weak attachment to burning through the strip. However, I was able to build a 5S2P pack without losing any cells. It's a bit difficult getting...
                                            05-08-2025, 02:52 PM
                                          • Ross Kohler
                                            Diagnosing South Bridge (FH82H370) on Asus H370-Pro Gaming Motherboard
                                            by Ross Kohler
                                            I'm learning about motherboard repair and I believe I've traced the issue down for the South Bridge on the particular motherboard I'm working on. My path of concluding that:
                                            - There's no sign of any attempt to power on when pushing the power button.
                                            - No PSON signal is reaching the 24-pin ATX connector.
                                            - The Super IO chip is receiving the PS_SWITCH signal from the power button and is relaying this signal back to the South Bridge.
                                            - The Super IO is not receiving the S_SLPS#_R signal back from the South Bridge
                                            - If I pull the Super IO S_SLPS#_R pin...
                                            04-16-2024, 09:36 AM
                                          • x_orange90_x
                                            by x_orange90_x
                                            01-29-2025, 09:24 PM
                                          • Dannyx
                                            Inverter welder help
                                            by Dannyx
                                            Good day folks. It's been a while since I've actually repaired anything, so today I have something I haven't worked on before: a friend of mine gave me this small inverter welder to look at. It powers on, but doesn't work.
                                            I took the cover off and immediately noticed the problem: two dead G40N60 transistors, along with some SMD resistors in what I think is the gate drive for the trannies. One IGBT is dead-short, the other reads fine, but it's missing a chunk of the casing, plus its SS14 diode is also gone, so it's safe to say we'll be replacing both.
                                            The SMD resistors...
                                            12-11-2020, 04:42 AM
