Here's another Antec that fried. I'm not sure if it was caused by bad caps but it is loaded with fuhjyyu caps. I have since opened every PS and replaced all on the low voltage side with quality caps from Digikey. Voltages when monitored in the BIOS are much more stable now! Should the 22uf 50v caps be replaced as well? Some of the threads on this forum indicate these are also the cause of problems.
Antec PP-303X
Re: Antec PP-303X
how old is that psu? the later ones look better. where is half the components on that pcb heh -
Re: Antec PP-303X
If that's a a 300W P/S, those are very decent sized heatsinks (How often have I said that in a post?). What is that fried daughter card, a temperature-controlled fan O/P?PeteS in CA
****************************Comment
Re: Antec PP-303X
All of the Antecs I've seem to be well designed with beefy heatsinks etc. Their choice of fuhjyyu caps kinda negate the decent engineering however.Originally posted by PeteS in CAIf that's a a 300W P/S, those are very decent sized heatsinks (How often have I said that in a post?). What is that fried daughter card, a temperature-controlled fan O/P?
I think this is the fan control circuit. Not sure what the blown daughter card's function was except scaring my wife when it blew up hehe.Attached Filesif you find these attachements useful please consider making a small donation to the site
Re: Antec PP-303X
I think the fried board is for the +5V standby rail, if I am correct, from the size of this board.My first choice in quality Japanese electrolytics is Nippon Chemi-Con, which has been in business since 1931... the quality of electronics is dependent on the quality of the electrolytics.Comment
by momakaI know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
https://www.badcaps.net/filedata/fetch?id=359177... -
by eryjusHello,
Channel: General Capacitor Questions & Issues
by ajdrenterIn my search for a proper 5v heavy ATX power supply, I selected an old Antec SU-380 that I've had in storage for a long time. Opening the power supply reveals a couple bulged capacitors. I removed all the caps and made a map for myself. I found the datasheet for the PCE TUR series in this thread:
https://www.badcaps.net/forum/showthread.php?t=14159
It says these are general purpose, so I assume I can replace them with any general purpose capacitors, but I don't really know anything about power supply circuits or reading capacitor datasheets. Despite this, I've been shopping for replacements:...-
by Paxman_SwedeHello!
I have studied the board and...-
by captain150I'm trying to repair two old VCRs, they both have bad caps. One has leaky ones, the other would barely run until I subbed in some caps from another power supply I had laying around (though they are the wrong values). This vcr works for an hour or two, but then the power supply starts whining and the picture gets lines in it. I didn't replace all the secondary caps, so another voltage might still be problematic, or the values I used are too far off.
I've been on mouser and digikey but the options are a bit overwhelming. I just need some new ones that will work. They don't need to be top quality,...-
- Loading...
