iPad Air 4th Generation A2316
  • Instafixx
    • Jul 2022
    • 374
    • India
    Hello Everyone, Namaste !1
    Need the boardview schematics for iPad A2316 Air 4th Generation 10.9 Inches.
    Received an iPad for charging issue. Replaced the flex cable but the issue persists. Need schematics to check the board. Would be grateful if anyone has it.
  • mon2
    • Dec 2019
    • 13892
    Re: iPad Air 4th Generation A2316
    Do not see the schematic in my database.
    What is the current draw for your unit ?
    Typically, if the battery is a known good battery -> next step is to replace the TRISTAR chip.
    We are servicing a similar case but iPAD5 A1822. We have a tristar tester which reports the tristar IC is fine. The max current draw is ~467mA which is too low for a normal boot. The iPAD will not get detected by iTUNES. At this stage, the fault is deemed to be a shorted cap but we do not have a thermal camera to locate the part.
    See this video for some ideas:
    https://www.youtube.com/watch?v=4xDV_BvcVFU
    • mferna14
      • Jun 2018
      • 1010
      BTW., where is the location of the TriStar chip in this model?? Do you have the Boardview or Schematics for this model???
      • mferna14
        • Jun 2018
        • 1010
        Upon Research, in this iPad Air model A2316 this chip 343S00394 is used for charging.
        • akuyi
          • Sep 2022
          • 4
          iPad Air 4th, A2316, Boardview Schematic needed
          I need help. I am looking for Schematics or Boardview. An error occurred when changing the display. The display remains dark or the backlight is dim. Most of the time the display is dark. I think the backlight filters or diodes are damaged. Where can you find these?
          • ruzanovroman
            • Nov 2023
            • Россия
            Good afternoon, have you solved the problem of ipad air 4 a2316 there is no image, there is only a backlight? Who has a boardview?
            • akuyi
              • Sep 2022
              • 4
              Currently the problem still exists. Yes, only Backlight ist the Problem.
              • MooonShine
                • Mar 2021
                • 6
                • Austria
                Same problem here
              • mferna14
                • Jun 2018
                • 1010
                Can anyone share the schematics from iPad Air 4th Gen A2316. I accidentally blew out one resistor by mistake & forgot to measure the resistance before removal. Attached is the photo of the missing resistance. It's near the LCD/charge circuit under the shield, next to the charger chip 343S00394-A0.. Hope someone can help me finding this resistance value. Thanks in advance.
                • mon2
                  • Dec 2019
                  • 13892
                  See attached.
                  R1207. This is a pull-up resistor for the local I2C bus - SDA line. Respectively, review the resistance of R1206 which is the other pull-up used by the SCL line. You can use the same resistance here. I2C bus interfacing does not demand the use of a critical value. We have used 4k7 / 10k on our designs without issues. In the end, the # of nodes may not be text book perfect but 2k2 is a value that has been used forever in reference designs.
                  • mferna14
                    • Jun 2018
                    • 1010
                    Thank you mon2... Hoping the value of R1206 might help. & you are right 2.2k might be fine out here. Thanks for the help.
                    • strtcstr
                      • Jul 2024
                      • 3
                      • Austria
                      Hi, gonna hijack your thread
                      It's the same iPad Air 4 LTE with the same charging problems, but I've managed to rip one of the PCB contacts and need to wire it. Given this is the top view, could someone with the schematic tell me where I should lead the wire? Thanks a lot
Name:	Screenshot 2024-07-20 004147.png
                      • mon2
                        • Dec 2019
                        • 13892
                        This connector appears to be J3700 in the boardview file (do not have the schematic for this one).
                        The missing pin is pin # 1. The group of pins here are mated together for pin #1..pin #9.
                        To confirm, remove all power. Meter in diode mode. Then touch the meter probes together and the meter should tone beep.
                        Proceed to touch any of these 9 pads with one probe and touch another pad from this group and the meter should tone beep again.
                        • ejaboz
                          • May 2018
                          • 10
                          • Norway
                          Does anyone have the readings to these 2 resistors? We can name them by number starting from the right. Resistor 1 and 2?
                          • ejaboz
                            • May 2018
                            • 10
                            • Norway
                            managed to makena double post.....
                            • mon2
                              • Dec 2019
                              • 13892
                              So far, only know their function from the BV file.
                              Update - see below. From other ipad schematics the EMI resistors are @ 1M ohm each.
                              Click image for larger version  Name:	r1.png Views:	0 Size:	48.2 KB ID:	3319804
                              Click image for larger version  Name:	r2.png Views:	0 Size:	48.1 KB ID:	3319805
                              • ejaboz
                                • May 2018
                                • 10
                                • Norway
                                thanks! I had one semi intact and it said over 1m but thought maybe it was bad. But this confirms that it in fact is 1m. Appreciate it mate.
                                • strtcstr
                                  • Jul 2024
                                  • 3
                                  • Austria
                                  mon2, thanks a lot. They seem to be connected, but I've ripped the PCB-side contact, not the one on the flex. Could you please check where the PCB pin #1 goes? Thanks a lot.
                                  • wirelesswiz
                                    • Aug 2021
                                    • usa
                                    Hey Mon2, What boardview are you using? I have ZXW and JCDrawings and neither have line data information or resistance readings. I have a no display Air4 and checked the usual areas but no dice.
                                    • Bonzadam
                                      • Apr 2022
                                      • 6
                                      • France
                                      Hi same problem i need help for two resistor, R8900 R8901 I2C SMC SDA 1.8V. Or schematics???
                                      Can someone have specifications of this resistor to replace it? thanks
                                      • GeirAndersen
                                        iPad .pcb file collection
                                        by GeirAndersen
                                        I tried searching the forum for whether this has been uploaded already, but couldn't find them (as a collection).
                                        Here's a dump of a bunch of iPads, I've split into 2 archives to get under file limit
                                        IPAD COLLECTION 1
                                        +---iPad mini1 820-3400(A1432) 820-3243(A1454?A1455)
                                        +---iPad mini2 820-3683(A1489) 820-3684(A1490?A1491)
                                        +---iPad mini3 820-00008(A1599) 820-00002(A1600)
                                        +---iPad mini4 820-00180(A1538) 820-00177(A1550)
                                        +---iPad mini5 820-01591(A2133) 820-01495(A2124?A2125?A2126)
                                        +---iPad Pro 12.9-4-820-01797(A2229) 820-01798(A2069?A2232?A2233)...
                                        12-09-2024, 09:28 AM
                                      • Stephen
                                        iPad 9th generation Battery issue
                                        by Stephen
                                        iPad battery seemed defective, it would charge then once it turned on it wouldn't charge more. After ordering a battery it would charge then drain very quickly (1% drain every 20 seconds) it then wouldn't take a charge then take a charge when it hit a certain level. I'm assuming it is a defective battery, it doesn't turn off when unplugged but seems faulty. Sometimes when I plug it back in it doesn't even take a charge and keeps draining then all of a sudden it charges. Am I missing something?
                                        07-05-2023, 12:16 PM
                                      • cheebster
                                        iPad Pro 12.9 5th Gen Backlight Issue
                                        by cheebster
                                        Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
                                        Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
                                        Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
                                        The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
                                        Anyone...
                                        05-20-2025, 09:17 AM
                                      • Aimbit
                                        Apple iPad Air 2 (A1566) - Seems to be power cycling, no display, new battery/Tristar
                                        by Aimbit
                                        Using an ammeter, original battery was only taking 90mA or so... then down to 0, up to 90mA, down to 0, etc, in a repeatable pattern. This iPad was very old, so first thing I did was swap the battery for a good one, and it came pre-charged. The old battery had negligible voltage.
                                        Now the iPad go up to about 1.5-1.6amps charge, then it drops to 0 after a few seconds... rinse/repeat as before. I tried changing the Tristar chip to see if that would help (and also my first real BGA chip!) but it seems to make no difference. Where should I look next?
                                        I should poke around the...
                                        06-29-2024, 09:51 PM
                                        Apple iPad 4th Generation 820-3249 Boardview and Schematic
                                        Apple iPad 4th Generation 820-3249 Boardview and Schematic...
                                        11-01-2024, 02:45 PM
