Where do you guys get schematics from ? I found and purchased a set for my DV6500 but it has a few discrepancies ( difference in revs I suppose ), could not have identified values of small semi's without them tho.
Anyone reccomend a place to get schematics
Tags: None
Re: Anyone reccomend a place to get schematics
man....that is some weird spam. what are they smoking?
re your question: i usually check eserviceinfo.com, they have quite a huge database. then there are a number of (mostly eastern european) sites like elektrotanya.com .
results may vary, so far i haven't seen a site that covers it all."Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin slitting throats." - H.L. Mencken -
I've had good luck with notebookschematic.com. There I got the schematics for my dead Toshiba M35X Satellite, found a dead FET in the CPU supply, replaced it (thanks, DigiKey!) and it works fine.
Also got the schematic for my two dead Dell D400 Latitudes - they're next to be repaired.
Good luck!Comment
I would recommend notebookschematic.com used them in the past - very helpfull.
Hi Unlockdev - I need a schematic for an Acer TM5330 - trying to fault find missing 3.3V & 5V and I think it's a faulty TPS51125.
Would you have that schematic to hand?
FluvalComment
Acer schematics
Acer Aspire 3600-5500
http://kythuatvitinh.com/forum.php You do have to become a member here, which I did, but then you have to post 10 times to download. I don't post much anywhere as I really don't work on motherboards very often. This has alot of mainboard schematics for laptops and pc's. I found it accidently when I found a ms7207 schematic and this site was printed on it.Comment
Many of those schematics have been posted at http://www.reepair.net (Arabic). The English version, http://www.reepair.net/en , no longer seems to work.http://kythuatvitinh.com/forum.php You do have to become a member here, which I did, but then you have to post 10 times to download. I don't post much anywhere as I really don't work on motherboards very often. This has alot of mainboard schematics for laptops and pc's. I found it accidently when I found a ms7207 schematic and this site was printed on it.Comment
Please can you send me the Dell Latitude C640 Schematic. thank you.... my email is sribandara_nt@yahoo.comLast edited by nbanti; 04-28-2011, 04:41 AM.Comment
Hp NX5000
Attached FilesComment
by PopalwaliHello Everyone,
I will be really grateful if someone shares schematics and if possible the boardview of the old Asus Nexus 7 (2012) Tablet. The motherboard is ME370T Rev. 2.4. Now I can find schematics for the Rev. 1.0 but I could not find the schematics for the Rev 2.4. I tried to look for similarities in the Rev. 1 but there are somethings missing, plus the board i have has nearly no component names printed on it which as a newbie makes pretty hard for me to locate things. Any assistance will be appreciated. Thank you.-
by TechmanxIf anyone needs schematic diagrams for any pro audio gear like what professional musicians use, such as guitar amps, power amplifiers, vintage tube amps, musical gear like keyboards, effects pedals, guitar wiring diagrams and service manuals, check out https://schematics.ca . I'm a road musician and an electronics tech and I got schematics for just about every piece of gear in my band from this site and they are free to download. It's always good to be prepared in case you fry something while on on the road, which always happens it seems. https://schematics-free.com has a lot of free audio schematics...
by Plg_666Hello, comrades. I've encountered the following issue. I live in a small town, and we had a power outage. My girlfriend's MSI claw was unlucky because it was charging at the time and didn't turn on afterward. The local service center suggested replacing the Tps65993bh controller. However, after replacing it, the motherboard still didn't start. The technician believes that the processor might be dead, but he needs the motherboard's schematics to confirm this. Please share the motherboard schematics if you have one for this console or a laptop with a core ultra 5/7 125H/155h processor.
Channel: Schematics and Boardviews
10-28-2025, 01:35 AM -
by mrautom8Schematics for the main board needed please. Sticker on board states BN94-07517A but the silkscreen says BN41-02157B. Cant find here or anywhere on the web.
Backlights work when main boards disconnected. When connected and power button switched, the relay on the PSU board turns on for one second then back off.
While relay is on, all voltage rails are present and steady (scoped) on main board.
I love a good logic puzzle but getting lost without any schematics.
No shorts on ANY capacitor main board.
Thermal camera shows 3.3V inductor getting warm instantly but...-
10-19-2025, 06:32 PM -
by CG_DionysosHello,
I am looking for the boardview file and the matching schematics (PDF) for the following MacBook Pro:- Model: A1707
- 15-inch, Mid 2017
- 3.1 GHz Core i7
- 16 GB RAM
- Radeon Pro 560
- 1 TB SSD
- Board number: 820-00928-A
Thanks in advance!
Greetings from Germany...-
09-16-2025, 06:43 AM - Loading...
