Where do you guys get schematics from ? I found and purchased a set for my DV6500 but it has a few discrepancies ( difference in revs I suppose ), could not have identified values of small semi's without them tho.
Anyone reccomend a place to get schematics
Tags: None
Re: Anyone reccomend a place to get schematics
man....that is some weird spam. what are they smoking?
re your question: i usually check eserviceinfo.com, they have quite a huge database. then there are a number of (mostly eastern european) sites like elektrotanya.com .
results may vary, so far i haven't seen a site that covers it all."Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin slitting throats." - H.L. Mencken -
I've had good luck with notebookschematic.com. There I got the schematics for my dead Toshiba M35X Satellite, found a dead FET in the CPU supply, replaced it (thanks, DigiKey!) and it works fine.
Also got the schematic for my two dead Dell D400 Latitudes - they're next to be repaired.
Good luck!Comment
I would recommend notebookschematic.com used them in the past - very helpfull.
Hi Unlockdev - I need a schematic for an Acer TM5330 - trying to fault find missing 3.3V & 5V and I think it's a faulty TPS51125.
Would you have that schematic to hand?
FluvalComment
Acer schematicsAcer Aspire 3600-5500
http://kythuatvitinh.com/forum.php You do have to become a member here, which I did, but then you have to post 10 times to download. I don't post much anywhere as I really don't work on motherboards very often. This has alot of mainboard schematics for laptops and pc's. I found it accidently when I found a ms7207 schematic and this site was printed on it.Comment
Please can you send me the Dell Latitude C640 Schematic. thank you.... my email is sribandara_nt@yahoo.comLast edited by nbanti; 04-28-2011, 04:41 AM.Comment
Hp NX5000Attached FilesComment
by PopalwaliHello Everyone,
I will be really grateful if someone shares schematics and if possible the boardview of the old Asus Nexus 7 (2012) Tablet. The motherboard is ME370T Rev. 2.4. Now I can find schematics for the Rev. 1.0 but I could not find the schematics for the Rev 2.4. I tried to look for similarities in the Rev. 1 but there are somethings missing, plus the board i have has nearly no component names printed on it which as a newbie makes pretty hard for me to locate things. Any assistance will be appreciated. Thank you.-
Channel: Schematic Requests ONLY!
by TechmanxIf anyone needs schematic diagrams for any pro audio gear like what professional musicians use, such as guitar amps, power amplifiers, vintage tube amps, musical gear like keyboards, effects pedals, guitar wiring diagrams and service manuals, check out https://schematics.ca . I'm a road musician and an electronics tech and I got schematics for just about every piece of gear in my band from this site and they are free to download. It's always good to be prepared in case you fry something while on on the road, which always happens it seems. https://schematics-free.com has a lot of free audio schematics...
by _AcE_I have two of these soundbars, both with the exact same issue. The soundbars were hit by lightning and no longer power on. The PSU does not output any voltage on the DC side. When plugged into mains, the DC output is a stone-cold 0.0 volts. The AC side of the PSU seems to be functioning correctly (as far as I can tell). When checking the plugged-in PSU with my thermal camera, the OB5269CP PWM controller (U1) and the two resistors (R12 and R13) pulse on and off. These run to the positive DC side of the bridge rectifier (among other components along the way).
There's no physical damage... -
by trepachkaI have this Lenovo Slim 7 16IAH7 notebook that is not booting properly. All voltages are there: 5v, 3.3v, 1.8v but it's still a no-go.
I spotted this IC chip with markings "6611c" on it. The coil near this chip measures around 200 Ohms which I think is too low. But without the schematics, it's just a guess.
I wonder if someone has the schematics for this board or perhaps, can help me identify this particular ship. Thanks....-
by jpserver25sI'm trying to explore on fixing things like this GPU I have, it got two resistors missing when I received It. Its for an old PC the seller even told me its r5 240 and seemed its even flashed to show its r5 240 but the PCB says 109-C55357-00_02 V309 OUGA11 please can I get its schematics and Bios Flash? It has 1GB DDR3 memory, and I believe it is based on AMD Oland XT/Pro (HD 8490). thanks in advance!...
08-07-2025, 07:51 PM -
- Loading...
