schematic of asus x456u please
  • kotar
    • Feb 2017
    • 19
    • MYANMAR
  • qonma
    Kuli Solder
    • Jun 2017
    • 184
    • INDONESIA
    Re: Asus a456u-rfa132t bios
    any know the type of ic charging this laptop asus x456uqk
      • 20420
      Re: schematic of asus x456u please
      boardview
      • kodox
        • Jul 2017
        • 322
        • Indonesia
        Thank's...
        • ANDRESINI77
          • Jun 2017
          • colombia
          Thank's...
          • razor_amd
            by razor_amd
            12-15-2020, 07:07 PM
          • throwaway327
            by throwaway327
            Model No: RC72LA
            Serial No: SBNVKD001014459
            06-18-2025, 05:52 PM
          • jbonavita
            by jbonavita
            Some issues
            Things I tried
            04-29-2025, 09:38 PM
          • flat-earther
            ASUS X54H laptop thinks it's always charging even with charger unplugged
            by flat-earther
            The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
            Windows also shows ''Plugged in'' when charger is not connected.
            This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
            Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
            If I let battery run out and say it has 3% Windows will...
            06-24-2025, 09:32 AM
          • DynaxSC
            by DynaxSC
            06-14-2024, 03:49 PM
