MSI GT70 - MS-1763 Schematic
  • bhcomputadores
    • Jun 2017
    • 25
    • Brazil
    please someone has the layout of this board? short circuit in the 19 volt line.
  • aaronkatrini
    Help me find the short circuit on this WORKING Nvidia GTX1650
    by aaronkatrini
    Recently picked up this GTX1650 at a local flea market for a low price and wanted to use it on my secondary PC. I first tested the card and saw the fan spin for a split second and then nothing. Immediately I thought of a short circuit. Disassembled and found a shorted SMD capacitor, injected voltage into it (1V/4A) and two Mosfets got hot immediately (QN3103 & QN3107). Desoldered these Mosfets and the card turned back to life.
    Bought replacements from Aliexpress and replaced them afterwards. Tried the card but still the saw the fan spin for a split second...
    04-18-2024, 03:15 PM
  • Geeker007
    9th Gen Dell Optiplex Micro PC motherboard repair: Short Circuit?
    by Geeker007
    Hi All, I have a 9th Gen Dell Optiplex micro PC motherboard which doesn't power on. When I connect the motherboard with power adapter, it goes into safe mode and turns off. So from info I have gathered online, it looks like there is a short circuit on the motherboard. So can you guys help me with figuring out the issue?
    I am new to electronics repair, so my queries could be naive but I am ready to learn.
    So I have a multimeter and a solder with me. But I can try to get a variable voltage power supply with a thermal camera as well. From what I seen online, best way is...
    01-28-2025, 03:31 PM
  • Tarot Superstars
    Short Circuit tester
    by Tarot Superstars
    Hello.
    I have seen a short circuit tester made with 3 * 9V batteries, a voltage limiter component and a resistor connected to the probes of a multimeter.
    The theory is that the meter becomes sensitive enough to read very low resistances and the lowest resistance to ground on a circuit is likely to be a short circuit in that area.
    Link
    The Amazing $1 Short Finder Upgraded! Convert ... - YouTube
    https://www.youtube.com/watch?v=0eixDdCpiO4
    My multimeter isn't normally sensitive to very small resistance, but when I put a 1 mega ohm resistor...
    09-25-2023, 09:11 AM
  • fab13
    Nintendo Switch lite charging chip heats up and does not short circuit
    by fab13
    Hello everyone
    Small technical problem on a Nintendo Switch lite
    Here's what I noticed: the USB port has been damaged internally, with a short circuit on the power supply line to the small fuse.
    After replacing the USB connector, the short circuit went away and I can't see any other short circuit in the whole motherboard.
    When I charge the console, it seems to be charging: I get 15 volts and an amperage of 0.450 A.
    Then, after a while, the amperage increases to 1.1 A and the BQ24193 charging chip starts to heat up, as evidenced...
    09-16-2023, 04:59 AM
  • rumpumpel1
    Fault source of a short circuit
    by rumpumpel1
    I have a mainboard with a short circuit (approx. 0 Ohm) on the 3.3V rail. As usual, I injected current and observed the mainboard with the thermal camera. Instead of individual components becoming warm, I observed that an area of several square centimeters became evenly warm from approx. 2A.
    Has anyone ever seen anything like this? Is it possible that there is a short circuit between two layers of the mainboard? The visual inspection of the mainboard did not reveal any abnormalities....
    10-21-2025, 01:38 AM
