Required schematic sony vpcsb mbx-237
  • sanehdeep2012
    • Oct 2013
    • 139
    • india
    DEAR ALL FRIENDS
    THANKS FOR YOUR SUPPORT
    I HAVE REQUIRED SCHEMATIC OF SONY VPCSB
    LAPTOP HAVING TWO BOARD MOTHER BOARD AND daughter BOARD
    MODEL IS: PCG-41216W
    WRITTEN ON BOARD:
    HD5
    V032_MP_1 0L _HDI_MB
    MBX-237 REV: 1.2
    FOR DOCKING BOARD ALSO
    V030_MP_DOCKING_DB
    REV: 1.2
    CNX-458
    pl help on this regards soon,
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    Re: Required schematic sony vpcsb mbx-237
    try this
    Im Back... sort of...
    • lefos
      • Nov 2013
      • 321
      • Greece
      What is the problem of the laptop?
      • sanehdeep2012
        • Oct 2013
        • 139
        • india
        There was capacitor short at 19v power line
        that is normal but now no power up and sn608098 having no voltage at any pin,after checking with schematic i will be back soon
        • sanehdeep2012
          • Oct 2013
          • 139
          • india
          Thanks ala_borbe for your support and providing the manuals,
          thanks fery much
          • sanehdeep2012
            • Oct 2013
            • 139
            • india
            IHAVE GO THROUGH SCHEMATIC AND FOUND THAT 19V AVAILABLE AT MOTHER BOARD AT PIN NO 3 OF PQ 27 BUT PIN NO 6 OF PU121 SN0608098 IS MISSING , I AM UNABLE TO find the track on motherboard pin no 6 not going any way to 19v pl help any body,
            • dj_ricoh
              • 2073
              post the voltage from PU121
              • Agent24
                I see dead caps
                • Oct 2007
                • 4951
                • New Zealand
                I can't help with your laptop problem, but some advice: you don't need to write everyting in capitals, unless you are trying to give us all a headache.
                -David VanHorn
                • sanehdeep2012
                  • Oct 2013
                  • 139
                  • india
                  i check the voltage and found
                  1. pin no 6 of PU121 having no voltage at all check 2.2E fuseable resistance and its ok,
                  2.+3VALW is showing short
                  *PQ16 drain also showing shorting remove PQ16 even then shorting
                  PU121 all pin pin no voltage all 0v
                  Agent24 sorry for everyting in capitals i will take care in next time thanks for responce
                  • inspirim
                    • May 2013
                    • 282
                    • Italy
                    Sony VPCSB1X9E MBX-237 i need schematic
                    I need schematic model: VPCSB1X9E
                    motherboard: MBX-237
                    defect: the keyboard does not work after falling
                    thanks to all
                    • hansie55
                      • Dec 2013
                      • 254
                      • Netherlands
                      Re: Sony VPCSB1X9E i need schematic
                      Here you go.
                      • inspirim
                        • May 2013
                        • 282
                        • Italy
                        • mangtomas
                          • Jun 2014
                          • 63
                          • philippines
                          i have the same problem,im shorted in dcbatout as labled in schematic diagram,my problem is the motherboard that im fixing has no lable and its hard for me to trace the parts,is anyone out there can give me a boardview with lable?
                          • Th3_uN1Qu3
                            Believe in
                            • Jul 2010
                            • 6031
                            • Romania
                            Had one of those shorted on DCBATOUT too, ended up being a ceramic capacitor. Found it using a large 3.7v lithium battery and feeling around for anything hot.
                            A working TV? How boring!
                            • aninms
                              • Feb 2017
                              • indonesia
                              thank i m join this forum i have enjoy and sharring experience
                              • aninms
                                • Feb 2017
                                • indonesia
                                ok thank for your solution
                                • Nadeem Amin
                                  • 33
                                  • pakistan
                                  • Younso
                                    • Sep 2018
                                    • Syria
                                    Re: Sony Vaio VPC-SB26FG cannot power on
                                    I need board view file for mbx-237 any one can be help... I need it to make JETAG for I/O MEC1609 to programme it
                                    • m1ch43lzm
                                      by m1ch43lzm
                                      05-12-2025, 08:37 PM
                                    • jb_Bak
                                      by jb_Bak
                                      CN6401
                                      Pin 01 NC
                                      Pin 02 NC
                                      Pin 03 "BL_ON": 0V
                                      Pin 04 "N/C"
                                      Pin 05 "STBY 3.3V": 3.5V
                                      Pin 06 "GND": N/C
                                      Pin 07 "AC_OFF"...
                                      09-27-2021, 04:52 PM
                                    • howardc64
                                      by howardc64
                                      07-24-2025, 05:17 PM
                                    • delpiero3
                                      Sony Vaio SVS MBX-261 board failure
                                      by delpiero3
                                      Hi everyone, newcomer in this forum, i watched tons of video from Sorin, i like the way i calmly explain things, i did quite some console repair, i am not that bad at micro-soldering, but troubleshooting where the issue is, is definitely where i still have progress to make. Usually i was able to fix the console because the failure was obvious, or because i was able to find someone with similar measures on the board and was pinpointing what to replace that way.
                                      Nevertheless, let's say, i don't come as a total beginner.
                                      I have this old laptop, which suit perfectly my needs, with the...
                                      10-29-2024, 06:16 AM
