DELL G15 5510 GDL55 LA-K661P bios
  • ibrahim03
    • Oct 2015
    • 143
    • egypt
    bios errors service tage has not been programmed
    Service Tag is : C54Y3G3
    alert : TPM device is not detected
    and i need clear me
    thank you advance
    bios Attachment
  • hardware1
    • Sep 2021
    • 2949
    • N/A
    Re: DELL G15 5510 GDL55 LA-K661P bios
    and i need clear me
    thank you advance
    bios Attachment
    What was your main problem? is that file is your original backup or it's for another device? what's your device service tag?
    all donations are welcome,
    • hardware1
      • Sep 2021
      • 2949
      • N/A
      and i need clear me
      thank you advance
      bios Attachment
      Here's your new bios file, try it and let me know.
      In the first boot go to bios menu, write your service tag, disable Absolute, save and restart then press (Alt+F) to exit the TPM.
      • ibrahim03
        • Oct 2015
        • 143
        • egypt
        the bios for another device
        problem is
        1- service tage has not been programmed
        my Service Tag is : C54Y3G3
        2- alert : TPM device is not detected
        3- i need clear me
        thank you advance
        • hoaca388
          Badcaps
          • Jan 2022
          • 12423
          problem is
          3- i need clear me
          thank you advance
          Try this files.
          • ibrahim03
            • Oct 2015
            • 143
            • egypt
            Originally posted by hoaca388
            Try this files.
            power on no data
            • ibrahim03
              • Oct 2015
              • 143
              • egypt
              no power
              • ibrahim03
                • Oct 2015
                • 143
                • egypt
                and i need clear me
                thank you advance
                bios Attachment
                can you fix file one ?
                  • 22157
                  do you have the original bios backup, where is the bios at post #1 from,is it a random one you found somewhere
                  • ibrahim03
                    • Oct 2015
                    • 143
                    • egypt
                    i don't have the original bios backup
                    but the file working power and data
                    • ibrahim03
                      • Oct 2015
                      • 143
                      • egypt
                      and i need clear me
                      thank you advance
                      bios Attachment
                      i need fix
                      and i need clear me
                        • 22157
                        Use a much older bios region update and the TPM error should be fixed
                        • ibrahim03
                          • Oct 2015
                          • 143
                          • egypt
                          Indeed, I did a BIOS update, but the same problem is also a problem with a delay in showing the data, after about 25 seconds.
                            • 22157
                            Well the ME firmware needs cleaning as well. You can try that yourself sometime, we have some guides for that https://www.badcaps.net/forum/showpo...41&postcount=3
                            • ibrahim03
                              • Oct 2015
                              • 143
                              • egypt
                              There is another problem
                              • hardware1
                                • Sep 2021
                                • 2949
                                • N/A
                                Try this older version.
                                • ibrahim03
                                  • Oct 2015
                                  • 143
                                  • egypt
                                  no power
                                  • beast4ever
                                    • Feb 2015
                                    • 174
                                    • egypt
                                    Dell G15 5510
                                    Service Tag: 7BWW0H3
                                    Express Service Code: 15957845607
                                    I need a 32mb file. 2mb. There is no backup because the old IC is damaged.
                                    The existing version is 2MB. Thanks to my friends.
                                    • beast4ever
                                      • Feb 2015
                                      • 174
                                      • egypt
                                      Originally posted by beast4ever
                                      Dell G15 5510
                                      I need your help, friends. I tried the files in the topic, but it did not give an image.
                                      • bbanana
                                        Father Land
                                        • Oct 2021
                                        • 164
                                        • Vietnam
                                        hard to help, no orignal BIOS some model cant boot, Logo frezee or turn off after write servicetag, cant detect TPM device,...
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
                                        • mikeybass
                                          by mikeybass
                                          04-23-2025, 04:30 PM
                                        • capoplays
                                          Help with BIOS update on Dell G15 5515 after chip replacement
                                          by capoplays
                                          Hey everyone,
                                          I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
                                          The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
                                          When I check the BIOS using the F12 menu Flash...
                                          10-24-2025, 06:53 AM
                                        • Akhlz001
                                          by Akhlz001
                                          09-20-2025, 07:15 PM
                                        • Sathsul
                                          Dell Latitude 5431 issues with dumping bios
                                          by Sathsul
                                          So, i kinda spend significant ammount of the last couple of days trying to flash a new bios, and or unlocking the current bios password with little to no results.
                                          The whole thing started with it being the 8fc8 bios, i found the tools to unlock that but i needed a bios dump. So i pursued that, im at a point where i dessoudered the chip, and succesfully soudered it to the ch341, dumped whatever was on it.
                                          However, the tools supposed to unlock the 8fc8 say that there is no 8fc8 hex inside. And when i followed diffrent tutorials to just flash a new bios onto the chip i got stuck on the...
                                          10-28-2025, 07:49 AM
