Very strange failure in Asus Taichi 21.
  • MICHAEL_2013
    • Feb 2016
    • 62
    • Colombia
    Gentlemen of great wisdom, I come to your help with the following case: An Asus Taichi 21 arrives and the laboratory source stops at 490mA. I make measurements and determine damage in corrupted bios. I have downloaded all the bios dumps that I have found on the Internet and with most of them it turns me on but does not detect NVME. in Taichi21 NVME has a different socket and I don't have a way to test another NVME. But I don't see the logic that the NVME is damaged by a corrupt bios. Any idea why it doesn't detect NVME in bios? I attach my corrupt bios and any help thank you very much.
  • MICHAEL_2013
    • Feb 2016
    • 62
    • Colombia
    Re: Very strange failure in Asus Taichi 21.
    My BAD Bios Dump
    • hoaca388
      Badcaps
      • Jan 2022
      • 12441
      Originally posted by MICHAEL_2013
      My BAD Bios Dump
      The bios area is recoverable but the ME region is badly damaged and the ME version cannot be determined and cannot be restored.
        • 22276
        https://www.badcaps.net/forum/showthread.php?t=97380
        extract and copy over the ME region using UEFITool and hxd,or just swap bios region
        • razor_amd
          by razor_amd
          12-15-2020, 07:07 PM
        • pirati
          by pirati
          10-27-2025, 04:20 PM
        • grimacelord
          by grimacelord
          07-10-2025, 02:52 PM
        • jbonavita
          by jbonavita
          Some issues
          Things I tried
          04-29-2025, 09:38 PM
        • throwaway327
          by throwaway327
          Model No: RC72LA
          Serial No: SBNVKD001014459
          06-18-2025, 05:52 PM
