Gentlemen of great wisdom, I come to your help with the following case: An Asus Taichi 21 arrives and the laboratory source stops at 490mA. I make measurements and determine damage in corrupted bios. I have downloaded all the bios dumps that I have found on the Internet and with most of them it turns me on but does not detect NVME. in Taichi21 NVME has a different socket and I don't have a way to test another NVME. But I don't see the logic that the NVME is damaged by a corrupt bios. Any idea why it doesn't detect NVME in bios? I attach my corrupt bios and any help thank you very much.
Very strange failure in Asus Taichi 21.
Tags: None
Re: Very strange failure in Asus Taichi 21.
My BAD Bios DumpAttached Filesif you find these attachements useful please consider making a small donation to the site
https://www.badcaps.net/donateComment
https://www.badcaps.net/forum/showthread.php?t=97380
extract and copy over the ME region using UEFITool and hxd,or just swap bios regionComment
by razor_amdWith ASUS, not everything is quite so simple. I will show you my way. It may be longer or harder but it is the right way to do it in my humble opinion.
This is the picture of 3 similar ASUS motherboards, all of them being X555LD...-
Channel: BIOS Requests ONLY!
by piratiHello everyone,
by grimacelordHello,
Anyway, I took dumps of both chips and then downloaded the latest update for this motherboard from ASUS's website...-
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
by throwaway327ASUS ROG Ally X - (Handheld Gaming PC)
Model No: RC72LA
Serial No: SBNVKD001014459
I used a tool called 'Smokeless-UMAF' to access usually hidden settings in the bios. I tweaked one or two 'safe' things but made the mistake of tweaking a lot of settings under 'USB/Thunderbolt Configurations' when I didn't know what they did. For...-
- Loading...
