Dell 5420 - XMC 25RH256CXIQ Can't read bios
  • jblow2210
    • Oct 2022
    • 8
    Hi All,
    Looking for from help/guidance.
    I have a CH341a (3.3v modified) trying to read bios from a Dell Latitude 5420 with a XMC 25RH256CXIQ bios chip.
    I have read many articles in this forum including
    https://www.badcaps.net/forum/showthread.php?p=1140467
    but nothing seems to be working.
    When connecting the clip to the chip, the ch341a indicates chip is not detected. The chip is on the board and I have disconnected power and the battery.
    Any other thoughts on what I could try?
    • 21197
    Re: Dell 5420 - XMC 25RH256CXIQ Can't read bios
    Originally posted by jblow2210
    Hi All,
    The bios chip is a WSON8 package.What clip do you have,is it a SOP8 clip,if so it will not work,you will damage the chip.You can get a WSON8 pogo pin adapter on aliexpress,amazon,ebay
    • jblow2210
      • Oct 2022
      • 8
      Thanks SMDFlea for the response, I will look into that.
      • jblow2210
        • Oct 2022
        • 8
        After getting my WSON8 probe, I was able to read the BIOS chip. One concern I have is that each time I read the BIOS and run the command "certutil -hashfile filename.bin MD5", I get a different checksum as a result. Does that indicate an issue?
        My BIOS chip is a XMC 25RH256CXIQ PPE46700 01 2121U in a Dell 5420 with the motherboard info as:
        Motherboard info:
        GDF40 LA-K491P
        Rev: 3.0(A02)
        2021-04-28
        Copyright 2020
        Rev: A02
        PWB:67X1G
        In reading the BIOS chip, I used a CH341a programmer, V1.7 (with the voltage switch), a WSON8 probe and NeoProgrammer v2.2.0.10. Since it does not have the XMC BIOS chip in its DB, I selected the MX25L25635E chip as the base. Does that seem like it would work?
        On the off chance this is not an issue, I have added the dump file from the first read of the BIOS. If someone could help me remove the admin password, it would be greatly appreciated.
        • hoaca388
          Badcaps
          • Jan 2022
          • 11899
          Motherboard info:
          GDF40 LA-K491P
          Rev: 3.0(A02)
          2021-04-28
          Copyright 2020
          Rev: A02
          PWB:67X1G
          Backup fault.
          • jblow2210
            • Oct 2022
            • 8
            Thanks for the response. I'm not sure what "Backup Fault" is and how to correct it. If you could elaborate some on this, it would be much appreciated.
            • hoaca388
              Badcaps
              • Jan 2022
              • 11899
              Your backup file is not good, the problem is still from your programmer, in general it gave out a junk file.
              • jblow2210
                • Oct 2022
                • 8
                Here is a second attempt. Can the admin password be removed from this file?
                • hardware1
                  • Sep 2021
                  • 2940
                  • N/A
                  Here's your Unlocked file.
                  all donations are welcome,
                  • jblow2210
                    • Oct 2022
                    • 8
                    Thanks hardware1, much appreciate. I will give it a try,
                    • Aditya11ttt
                      Adi
                      • Feb 2019
                      • 184
                      • India
                      25RH256CXIQ
                      this chip detects in ch341a but can't write any help ?
                      • zenius
                        by zenius
                        12-08-2024, 06:13 AM
                      • mikeybass
                        by mikeybass
                        04-23-2025, 04:30 PM
                      • jhanra
                        by jhanra
                        in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...
                        11-02-2024, 04:19 AM
                      • gizaha
                        by gizaha
                        02-13-2024, 07:18 AM
                      • mrrubik
                        Dell Optiplex 7010 micro bad BIOS flash?
                        by mrrubik
                        Hi folks,
                        I got a Dell Optiplex 7010 micro PC (Exact Model) with 8FC8 BIOS and locked out admin password. I attempted to remove the password by patching the BIOS via info from this thread: https://www.badcaps.net/forum/troubl...ssword-patcher
                        After flashing the patched the BIOS, the PC is unresponsive with a solid AMBER power LED (not documented in manual anywhere)
                        Steps I took:
                        1. Read BIOS with CH341a, verified hash twice
                        2. Patched
                        12-23-2024, 04:11 PM
