Dell 5420 - XMC 25RH256CXIQ Can't read bios
  • jblow2210
    • Oct 2022
    • 8
    Hi All,
    Looking for from help/guidance.
    I have a CH341a (3.3v modified) trying to read bios from a Dell Latitude 5420 with a XMC 25RH256CXIQ bios chip.
    I have read many articles in this forum including
    https://www.badcaps.net/forum/showthread.php?p=1140467
    but nothing seems to be working.
    When connecting the clip to the chip, the ch341a indicates chip is not detected. The chip is on the board and I have disconnected power and the battery.
    Any other thoughts on what I could try?
    • 22279
    Re: Dell 5420 - XMC 25RH256CXIQ Can't read bios
    Originally posted by jblow2210
    Hi All,
    The bios chip is a WSON8 package.What clip do you have,is it a SOP8 clip,if so it will not work,you will damage the chip.You can get a WSON8 pogo pin adapter on aliexpress,amazon,ebay
    • jblow2210
      • Oct 2022
      • 8
      Thanks SMDFlea for the response, I will look into that.
      • jblow2210
        • Oct 2022
        • 8
        After getting my WSON8 probe, I was able to read the BIOS chip. One concern I have is that each time I read the BIOS and run the command "certutil -hashfile filename.bin MD5", I get a different checksum as a result. Does that indicate an issue?
        My BIOS chip is a XMC 25RH256CXIQ PPE46700 01 2121U in a Dell 5420 with the motherboard info as:
        Motherboard info:
        GDF40 LA-K491P
        Rev: 3.0(A02)
        2021-04-28
        Copyright 2020
        Rev: A02
        PWB:67X1G
        In reading the BIOS chip, I used a CH341a programmer, V1.7 (with the voltage switch), a WSON8 probe and NeoProgrammer v2.2.0.10. Since it does not have the XMC BIOS chip in its DB, I selected the MX25L25635E chip as the base. Does that seem like it would work?
        On the off chance this is not an issue, I have added the dump file from the first read of the BIOS. If someone could help me remove the admin password, it would be greatly appreciated.
        • hoaca388
          Badcaps
          • Jan 2022
          • 12441
          Motherboard info:
          GDF40 LA-K491P
          Rev: 3.0(A02)
          2021-04-28
          Copyright 2020
          Rev: A02
          PWB:67X1G
          Backup fault.
          ​https://www.badcaps.net/donate
          • jblow2210
            • Oct 2022
            • 8
            Thanks for the response. I'm not sure what "Backup Fault" is and how to correct it. If you could elaborate some on this, it would be much appreciated.
            • hoaca388
              Badcaps
              • Jan 2022
              • 12441
              Your backup file is not good, the problem is still from your programmer, in general it gave out a junk file.
              • jblow2210
                • Oct 2022
                • 8
                Here is a second attempt. Can the admin password be removed from this file?
                • hardware1
                  • Sep 2021
                  • 2949
                  • N/A
                  Here's your Unlocked file.
                  all donations are welcome,
                  • jblow2210
                    • Oct 2022
                    • 8
                    Thanks hardware1, much appreciate. I will give it a try,
                    • Aditya11ttt
                      Adi
                      • Feb 2019
                      • 192
                      • India
                      25RH256CXIQ
                      this chip detects in ch341a but can't write any help ?
                      • zenius
                        by zenius
                        12-08-2024, 06:13 AM
                      • mikeybass
                        by mikeybass
                        04-23-2025, 04:30 PM
                      • capoplays
                        Help with BIOS update on Dell G15 5515 after chip replacement
                        by capoplays
                        Hey everyone,
                        I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
                        The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
                        When I check the BIOS using the F12 menu Flash...
                        10-24-2025, 06:53 AM
                      • Akhlz001
                        by Akhlz001
                        09-20-2025, 07:15 PM
                      • Sathsul
                        Dell Latitude 5431 issues with dumping bios
                        by Sathsul
                        So, i kinda spend significant ammount of the last couple of days trying to flash a new bios, and or unlocking the current bios password with little to no results.
                        The whole thing started with it being the 8fc8 bios, i found the tools to unlock that but i needed a bios dump. So i pursued that, im at a point where i dessoudered the chip, and succesfully soudered it to the ch341, dumped whatever was on it.
                        However, the tools supposed to unlock the 8fc8 say that there is no 8fc8 hex inside. And when i followed diffrent tutorials to just flash a new bios onto the chip i got stuck on the...
                        10-28-2025, 07:49 AM
