Lenovo v15-ada bios needed
  • adamski1952
    • Oct 2021
    • 94
    • england
    Hi all.
    Looking for a clean bios for Lenovo va15-ada. Model 82C7.
    Thanks in advance.
  • hardware1
    • Sep 2021
    • 2943
    • N/A
    Re: Lenovo va15-ada bios needed
    Originally posted by adamski1952
    Hi all.
    Thanks in advance.
    Upload your original bios file and write your device serial number.
    all donations are welcome,
    • adamski1952
      • Oct 2021
      • 94
      • england
      Apologies. It should have read V15-ADA SERIAL #PF28JF07. My bad!! thats prob why no search result.
      • hardware1
        • Sep 2021
        • 2943
        • N/A
        Latest Bios version from Lenovo, hope it works fine.
        • ubik77
          • Sep 2022
          • 3
          • Poland
          Hello
          I Have broken bios file
          Coud anybody can repair it?
          Lenovo V15 ADA
          model 82c7
          SN PF296FZS
          MTM 82C7000TPB
          thank you
            • 21457
            Originally posted by ubik77
            Hello
            Lenovo V15 ADA
            model 82c7
            SN PF296FZS
            MTM 82C7000TPB
            thank you
            Virgin bios https://www.badcaps.net/forum/troubl...21#post1712421
            Add DMI from your backup, read post 1 https://www.badcaps.net/forum/troubl...15-ada-bios​
            • Ierobo
              • May 2025
              • 6
              • Corigliano
              if possible, could you help me with finding the BIOS of Lenovo V15-adamod. 82c7 s/n PF2J760Y, factory ID: JVHFC1, marked on the board GV51 GV551\NMd151 rev.1. Thanks anyway
              • peste
                • Dec 2016
                • 13199
                • ROMANIA
                post, full name and model, etc.
                post the contents of the bios chip even if it is corrupted..
                • Ierobo
                  • May 2025
                  • 6
                  • Corigliano
                  Thanks Peste I'll send you the corrupted file
                  • Ierobo
                    • May 2025
                    • 6
                    • Corigliano
                    oops, I resent the original corrupt file
                    • peste
                      • Dec 2016
                      • 13199
                      • ROMANIA
                      you have everything you need at post 204
                      https://www.badcaps.net/forum/troubl...da-bios/page11
                      • Ierobo
                        • May 2025
                        • 6
                        • Corigliano
                        Thank you so much Peste
                        • nickojean22
                          • Aug 2018
                          • 15
                          • philippines
                          hello anyone can help fix may corrupt bios
                          V15-ADA Laptop (Lenovo) - Type 82C7
                          Serial Number
                          PC24NBYT
                          Machine Type Model
                          82C700LAPH
                          • peste
                            • Dec 2016
                            • 13199
                            • ROMANIA
                            Serial Number
                            PC24NBYT
                            Machine Type Model
                            82C700LAPH
                            Bios extracted from Lenovo website update for IdeaPad 3 14ADA05, IdeaPad 3 15ADA05, IdeaPad 3 17ADA05, V14-ADA, V15-ADA
                            DMI 1000 - 2FFF Attached Files
                            • nickojean22
                              • Aug 2018
                              • 15
                              • philippines
                              thanks its work 100%
                              • NM17
                                • Aug 2025
                                • 5
                                • Deutschland
                                Unfortunately, I have been having problems with my V15-ADA since the last BIOS update. During normal operation, it freezes with red stripes on the display and can only be made usable again by restarting it.
                                I tried installing the latest BIOS from the Lenovo website, but that didn't help.
                                Can anyone customize a BIOS file for me so that I can install it with the CH341a?
                                Attached are the technical data and a backup of the BIOS.
                                V15-ADA
                                Serial number: PF1AZXFR
                                Type: 82C7
                                Chip: W25Q64JW
                                • peste
                                  • Dec 2016
                                  • 13199
                                  • ROMANIA
                                  V15-ADA
                                  Type: 82C7
                                  Chip: W25Q64JW
                                  try post #14...
                                  • NM17
                                    • Aug 2025
                                    • 5
                                    • Deutschland
                                    I tested the BIOS version. Unfortunately, the same error occurred. Does anyone have an older BIOS version?
                                      • 21457
                                      There are many older bios versions on the forum https://www.badcaps.net/forum/troubl...87#post3579887
                                      If you want older executable updates edit the number in the link. The latest is 41 so try 40,39,38 etc. https://download.lenovo.com/consumer...s/e8cn41ww.exe
                                      • qayyum786
                                        • Aug 2018
                                        • 1955
                                        • INDIA
                                        Bios is not the always issue. Possible onboard ram could be failure
                                        upload error image
                                        • lucaszmn
                                          by lucaszmn
                                          Problem:
                                          Initial Findings:
                                          • I concluded that the
                                          08-12-2025, 03:01 PM
                                        • Wahaz
                                          by Wahaz
                                          10-30-2023, 08:42 PM
                                        • grimacelord
                                          Lenovo Legion T5-26AMR5 Desktop - Corrupt BIOS
                                          by grimacelord
                                          Hello there.
                                          I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
                                          History:
                                          1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
                                          I searched for this error online and discovered...
                                          03-15-2023, 03:29 PM
                                        • cyber16
                                          Lenovo P1 g1 Type 20MD-002PUS "BIOS Help Needed"
                                          by cyber16
                                          Please I need help.
                                          Quick rundown long story shorter, but still long winded.
                                          I received this Lenovo P1 GEN 1 about a year ago from a business.
                                          It was pretty much dead hit the power button and the LED on the power light would come on as would the keyboard back light a couple times and just shut off or go into high speed fan mode without life other than the power button led.
                                          At that time it was still under warranty, I spoke to Lenovo and I was going to send it in to have them repair it.
                                          Then late last fall my father-in-law suffered...
                                          09-08-2022, 07:32 AM
                                        • Joluvillas
                                          Lenovo ThinkPad L15 Gen 1 i7 (20U4) Bios and EC dump needed
                                          by Joluvillas
                                          Hi all! I was reading on tutorials how to flash a bios to remove password from a bios, and I ended up reading the EC chip instead of the main bios chip, it only gave me a .bin file of 1,024kb, I learned later that that is the EC chip not the main bios chip (I should have read the tutorials here instead before attempting anything, my bad), I went to flash the original backup, the 1,024kb size file into the same chip and laptop is not powering up anymore. I may have screwed the chip or even the motherboard (Hopefully not), I am trying to see if there is a fix before I discard it. I had a couple...
                                          06-18-2024, 10:35 PM
