Lenovo v15-ada bios needed
  • adamski1952
    • Oct 2021
    • 94
    • england
    Hi all.
    Looking for a clean bios for Lenovo va15-ada. Model 82C7.
    Thanks in advance.
  • hardware1
    • Sep 2021
    • 2949
    • N/A
    Re: Lenovo va15-ada bios needed
    Originally posted by adamski1952
    Hi all.
    Thanks in advance.
    Upload your original bios file and write your device serial number.
    all donations are welcome,
    • adamski1952
      • Oct 2021
      • 94
      • england
      Apologies. It should have read V15-ADA SERIAL #PF28JF07. My bad!! thats prob why no search result.
      • hardware1
        • Sep 2021
        • 2949
        • N/A
        Latest Bios version from Lenovo, hope it works fine.
        • ubik77
          • Sep 2022
          • Poland
          Hello
          I Have broken bios file
          Coud anybody can repair it?
          Lenovo V15 ADA
          model 82c7
          SN PF296FZS
          MTM 82C7000TPB
          thank you
            • 22275
            Originally posted by ubik77
            Hello
            Lenovo V15 ADA
            model 82c7
            SN PF296FZS
            MTM 82C7000TPB
            thank you
            Virgin bios https://www.badcaps.net/forum/troubl...21#post1712421
            Add DMI from your backup, read post 1 https://www.badcaps.net/forum/troubl...15-ada-bios​
            • Ierobo
              • May 2025
              • 6
              • Corigliano
              if possible, could you help me with finding the BIOS of Lenovo V15-adamod. 82c7 s/n PF2J760Y, factory ID: JVHFC1, marked on the board GV51 GV551\NMd151 rev.1. Thanks anyway
              • peste
                • 13915
                • ROMANIA
                post, full name and model, etc.
                post the contents of the bios chip even if it is corrupted..
                • Ierobo
                  • May 2025
                  • 6
                  • Corigliano
                  Thanks Peste I'll send you the corrupted file
                  • Ierobo
                    • May 2025
                    • 6
                    • Corigliano
                    oops, I resent the original corrupt file
                    • peste
                      • 13915
                      • ROMANIA
                      you have everything you need at post 204
                      https://www.badcaps.net/forum/troubl...da-bios/page11
                      • Ierobo
                        • May 2025
                        • 6
                        • Corigliano
                        Thank you so much Peste
                        • nickojean22
                          • Aug 2018
                          • 19
                          • philippines
                          hello anyone can help fix may corrupt bios
                          V15-ADA Laptop (Lenovo) - Type 82C7
                          Serial Number
                          PC24NBYT
                          Machine Type Model
                          82C700LAPH
                          • peste
                            • 13915
                            • ROMANIA
                            Serial Number
                            PC24NBYT
                            Machine Type Model
                            82C700LAPH
                            Bios extracted from Lenovo website update for IdeaPad 3 14ADA05, IdeaPad 3 15ADA05, IdeaPad 3 17ADA05, V14-ADA, V15-ADA
                            DMI 1000 - 2FFF Attached Files
                            • nickojean22
                              • Aug 2018
                              • 19
                              • philippines
                              thanks its work 100%
                              • NM17
                                • Aug 2025
                                • 5
                                • Deutschland
                                Unfortunately, I have been having problems with my V15-ADA since the last BIOS update. During normal operation, it freezes with red stripes on the display and can only be made usable again by restarting it.
                                I tried installing the latest BIOS from the Lenovo website, but that didn't help.
                                Can anyone customize a BIOS file for me so that I can install it with the CH341a?
                                Attached are the technical data and a backup of the BIOS.
                                V15-ADA
                                Serial number: PF1AZXFR
                                Type: 82C7
                                Chip: W25Q64JW
                                • peste
                                  • 13915
                                  • ROMANIA
                                  V15-ADA
                                  Type: 82C7
                                  Chip: W25Q64JW
                                  try post #14...
                                  • NM17
                                    • Aug 2025
                                    • 5
                                    • Deutschland
                                    I tested the BIOS version. Unfortunately, the same error occurred. Does anyone have an older BIOS version?
                                      • 22275
                                      There are many older bios versions on the forum https://www.badcaps.net/forum/troubl...87#post3579887
                                      If you want older executable updates edit the number in the link. The latest is 41 so try 40,39,38 etc. https://download.lenovo.com/consumer...s/e8cn41ww.exe
                                      • qayyum786
                                        • Aug 2018
                                        • 1959
                                        • INDIA
                                        Bios is not the always issue. Possible onboard ram could be failure
                                        upload error image
                                        • lucaszmn
                                          by lucaszmn
                                          Problem:
                                          Initial Findings:
                                          • I concluded that the
                                          08-12-2025, 03:01 PM
                                        • Wahaz
                                          by Wahaz
                                          10-30-2023, 08:42 PM
                                        • grimacelord
                                          by grimacelord
                                          Hello there.
                                          History:
                                          03-15-2023, 03:29 PM
                                        • to5it0
                                          by to5it0
                                          10-24-2025, 01:35 AM
                                        • mkdj
                                          Lenovo IdeaPad 3 - Hard Disk not recognized in BIOS
                                          by mkdj
                                          Dear all,
                                          I have recently fixed a Lenovo IdeaPad 3 15 ALC6 that was not booting due to a BIOS issue. After flashing the BIOS, the laptop boots up, but hard disk is not recognized in BIOS. Is says "Hard Disk : Not Installed". I have tried with 2 different drives (one that I know is working on another laptop) but I get the same result. I do not know if disks were recognized before I got the laptop and fix it, but I don't see any reason why not. I can boot on USB though.
                                          Here the steps I have taken to fix the laptop:
                                          - downloaded latest BIOS from Lenovo Website...
                                          10-18-2025, 03:43 AM
