Elitebook 840 G8 bios corrupted?
  • lleg0
    tuzbiosu'ma-tii
    • Jul 2022
    • 17
    • Romania
    After unsuccessfully trying to unlock password on 840 G8, i ordered from ebay new chips from ******** user
    1. He sent me first set of chips, correctly soldered them and laptop would not turn on.
    2. i backed up my original chips (laptop would boot but bios locked) using CH341A, chips still soldered down on motherboard (maybe first mistake);
    3. I was unsuccessfull trying to unlock with RC Unlocker (Wrong chip, try reading and unlocking 16MB chip)
    4. Same chip provider told me to try write ''unlocked data'' to OEM chips >> no luck
    5. Tried to write again original data on original chips >> no luck
    6. Sent me replacement chips >> Caps lock blink 7 times
    ps: waiting for ezp2023 programmer to arrive
    What can i do now?
    Thanks!
  • hoaca388
    Badcaps
    • Jan 2022
    • 12441
    Re: Elitebook 840 G8 bios corrupted?
    You have wasted your money in vain, the Ec filemiansh621 sent you is ok, it can completely unlock your bios.
    The problem as I speculate, when using the clamp you carelessly damaged a few components around the pins of the SPI chip, they are very small.
    • lleg0
      tuzbiosu'ma-tii
      • Jul 2022
      • 17
      • Romania
      I haven't used clamp as it is not possible here, we soldered jump wires to each pin initially; Then we used heat gun to remove and replace; All components are there;
      In the end, are both chips needed to be patched or just the one placed at 45 degrees on back? (EC i guess)
      • hoaca388
        Badcaps
        • Jan 2022
        • 12441
        Just EC chip. Change a new blank chip and try again. The heat gun can also blow away small components on the motherboard.
        • lleg0
          tuzbiosu'ma-tii
          • Jul 2022
          • 17
          • Romania
          i will try again with original chip rewritten with miansh621 file and then with send chip. I'll update this thread;
          Thing is now, it may be that even my Bios data is corrupted but i am not sure of that. Is he 7 blinks any hint if bios is ok or not?
          • lleg0
            tuzbiosu'ma-tii
            • Jul 2022
            • 17
            • Romania
            Sorry for the double post but as promised here's my update:
            I have eventually successfully bring this bad boy back to life;
            Tips for other newbies like me:
            * Get/borrow a hot air soldering station;
            * you can use CH341A to read both bios and EC rom, however to write on it you have to desolder it. At least in my case it seems other components interfere with writing
            * A better sollution is to get an EZP2023+ programmer (20$) + WSON8 adapter from aliexpress (5$);
            * Backup EC ROM. Backup again. Make sure both backups have same checksum
            * Wipe EC rom, write back the new unlocked EC ROM.
            * Enjoy
            • Wutru
              HP Elitebook 820 G4 BIOS repair assistance required
              by Wutru
              Hi guys,
              If someone would be able to provide some expertise, I'd be very grateful.
              BIOS Corruption - Cause
              So I managed to corrupt my machine by installing linux and enrolling custom secure boot keys. I did choose to enroll the Microsoft keys as well, to prevent any potential bricking due to 3rd party drivers from HP being signed with those keys.
              After doing that, and rebooting(it did boot, powerLED, fanspin etc.), the laptop did not give any video output on the LCD or video connectors. I think I was able to get in BIOS and trigger the beeper by pressing ESC....
              09-06-2025, 10:32 AM
            • FalconPunch
              Surface Pro X 1876 Bios corrupted
              by FalconPunch
              Hello everyone, I happen to have a Microsoft Surface Pro X 1876 in my hands. It was brought to me by a friends which happen to have taken off the bios chip to test another motherboard. Upon putting back the bios chip on the original motherboard, The PC is stucked on Windows logo and won t boot to bios or anything. I suspect that the changes of bios chip somehow corrupted the firmware inside. Is the hypothesis correct?
              Also i extracted the bios inside the chip which was on Winbond 25R128JWPQ you can find the file attached if you can fix it (if possible, I would like some insight on...
              08-09-2025, 03:56 AM
            • zlr8r
              Hp Zbook Firefly 14 G10 - corrupted Bios's ? - please check
              by zlr8r
              Greetings
              I am hoping someone could have a check of my Hp Zbook Firefly 14 G10 , 2 x 32MB Bios files... (powers on / black screen).
              Serial Number: 5CG3202C16
              Product #/SKU: 739P0AV
              CT Number: PRTUE00WBI30YX
              Description: HP ZBook Firefly 14 inch G10
              BuildID: 23WWWGAZ602#SABU#DABU
              Feature Byte: 476J6S6b7B7M7Q7U7W7m7saBaEapaqauawbUbhcAfPgSguhKj4jhk8mEn7nVngpDpVpWpnpqprqMqkqz.G3
              MAC address not found.
              • I extracted both 32mb bios files (Main + EC). But when i run the main 32mb bios through MFIT.exe , it produces this error; ie:,
              10-28-2025, 01:56 PM
            • macabook
              by macabook
              🧩 Initial Issue
              07-24-2025, 02:17 PM
            • TylerHyde21
              Lenovo TD350 ThinkServer BIOS v505 Corrupted BIOS,
              by TylerHyde21
              Hello, the bios on my Lenovo TD350 ThinkServer got corrupted during a bios update, the bios restore function killed the Server.
              I need to flash the bios inside the MX25L12835F SOP8, i have already desolder the chip and solder it into my SOP8 adapter and read it with a ROM programmer.
              I use the innoextract 1.9 software to extract the bios file from the .exe file that i download from lenovo website, can you help me edit the Hex file (removing the Index part and resize the file)?
              This guy claim to have done it https://forums.lenovo.com/t5/ThinkSe...doesnt-Start-u...
              06-29-2024, 10:38 AM
