The Mystery of 'Manufacturing Mode' - Dell Motherboards
  • CapThatBrass
    • Oct 2021
    • 46
    Firstly sorry if this is the wrong forum for posting this question - please recategorize or move to another part of the forum if necessary.
    I've been doing alot of research recently into the world of BIOS editing and building of images, out of curiosity mainly.
    Lots of Youtube videos as well as threads in this forum (as well as others) mention the term 'unlocked' bios which generally means the removal of BIOS passwords from a dumped image to allow full access to the BIOS/UEFI menu. However, a handful mention that a prompt for the Service Tag will appear upon boot - this function is brought on by the enabling of 'Manufacturing Mode'.
    It would be interesting to know what Manufacturing Mode actually is - is it something specific to Dell or is it a universal property provided by the likes of Intel to allow all laptop manufacturing brands to test their equipment?
    Is there a way to invoke or enable Manufacturing Mode within a dumped BIN image, which can then be written back to the chip to be booted from?
    Any advise or guidance would be great.
  • CapThatBrass
    • Oct 2021
    • 46
    Re: The Mystery of 'Manufacturing Mode' - Dell Motherboards
    Can anyone help out?
    • volinakis
      • Jan 2021
      • 2741
      • N/A
      wow, so you need to learn how to use a search engine on internet, It took 2s ...
      "Manufacturing mode is a special BIOS mode designed to decrease the time systems spend on the assembly line. This is done by skipping nonessential boot functions/tests and by prioritizing removable media boot devices over internal hard drive controllers in the boot order. In combination, these changes decrease the boot time significantly which allows more systems to complete the factory processes in less time. When a system successfully completes the factory processes, it is taken out of Manufacturing mode. It is very unlikely a customer would receive a system in Manufacturing mode out of the box. Manufacturing mode is more likely to be seen when a system board is replaced."
      Modifying bios to enter in manufacturing mode allows to reset bios to factory defaults, hence removal of passwords, computrace, boot order or removed devices from boot order.
      • CapThatBrass
        • Oct 2021
        • 46
        Thanks for copying and pasting the first paragraph that Google chucks out Volinakis.....
        • diif
          • Feb 2014
          • 6978
          • England
          It's a Dell thing. https://www.dell.com/support/kbdoc/e...facturing-mode
          • volinakis
            • Jan 2021
            • 2741
            • N/A
            you are welcome! don't tell me that you need translation from English to English ... otherwise I don't understand why did you ask what is " Manufacturing Mode" and what it wants from you ...
            • Ali5914
              • Dec 2020
              • 48
              • India
              Hello Friend, absolutely this is possible to UNLOCK Manufacturing Mode in DELL machines. But there is some limitations. You can not unlock for all models. But whichever models completely rely on bios not on EC bios (Super IO), you can unlock those models by simply replacing EC region of the bios with STOCK EC RGN from downloaded EXE.
              • CapThatBrass
                • Oct 2021
                • 46
                Thanks for the explanation Ali5914, this would make sense, I didn't realise that replacing the machines EC region with stock from an extracted BIOS image would cause the machine to boot into Manufacturing Mode.
                • Ali5914
                  • Dec 2020
                  • 48
                  • India
                  You're Welcome.... Try doing it... If it is not happening then let me know. I will guide you on this.
                  • vbpablo
                    • Feb 2023
                    • 3
                    • Chile
                    Hi everyone!
                    May I can find here the help that I need
                    I have a Dell G3 15 3500 that failed due to a short circuit (also with an expired guaranty), and the guys from the service did awful work, so I had to buy a 2nd-hand motherboard.
                    Once installed the MB, the notebook didn't turn on. So after we tried unsuccessfully to reprogram the BIOS, we opted to change the BIOS chips with the ones in the old MB (that looked ok and were recognized by the reprogrammed). The notebook turned on again, and we were even able to boot to windows... but as you can expect, it booted in manufacturing mode, and it's annoying (and maybe unsafe) to work with the notebook in that mode.
                    We found this post googling about the manufacturing mode, but as the notebook is dual BIOS, we don't know where and how we should edit the EC region data.
                    Also, we found a post on another website (https://winraid.level1techs.com/t/gu...lization/31277) that talk about a conflict involving intel engine (cs)me/cs(txe) regions data. That makes us think that the information contained within the EC chip could be related to the problem, but we're not entirely sure about that.
                    What do you suggest to fix the issue??
                    A friend is doing the BIOS magic; I'm just translating him, so feel free to correct me on anything you consider wrong.
                    • Vusal
                      Senior Tech
                      • Feb 2016
                      • 41
                      • Azerbaycan
                      I replaced EC region with the other one but I did not get any results.
                      • qayyum786
                        • Aug 2018
                        • 1933
                        • INDIA
                        post your backup file
                        • Ghost18_07
                          Zakaria
                          • Mar 2018
                          • 78
                          • Algeria
                          Great thread, this a mystery as you said, and you are right, i have the same problem, i have this manufacturer mode sentence and it says to just click Alt+F to stop it, but it won't even if i ty to enter the service tag, because the service tag gone after i save the changes .
                          So if anyone has a solution for this ? or i just need to try to fi the BIOS file again ?
                          • Argento7
                            • Jan 2010
                            • 27
                            Adding some information
                            • Ghost18_07
                              Zakaria
                              • Mar 2018
                              • 78
                              • Algeria
                              I found a solution, but not me, someone edit my bios file again and it worked just fine. So the problem is related to a BIOS fix, I don't know where exactly but that's the only way to fix it.
                              Will be back if any new information collected.
                              • eenee
                                • Aug 2022
                                • 48
                                • Mongolia
                                Can you post both your old and new bios, so we can compare the changes
                                • jlxxxx
                                  Dell 9310 (2-in-1) bios to fore manufacturing mode
                                  by jlxxxx
                                  I have read the FAQ, and other reference here to changing the EC region of the flash image to force entering manufacturing mode.
                                  How would I modify the dell 9310 firmware in order to force entering manufacturing mode? The goal is to have the computer ask me to enter the service tag after changing the motherboard.
                                  Can this be completed using the boot-up USB restore method that Dell supports in order to reduce risk of damaging the hardware further? (Ctrl+Esc keys while holding the power button)
                                  Dell provides this bios here: https://www.dell.com/support/home/en-us/drivers/dri...
                                  09-25-2024, 02:38 PM
                                • The_Memory_Guy
                                  Dell T7820 stuck in Bios Recovery Mode
                                  by The_Memory_Guy
                                  HI,
                                  I have a Dell T7820 stuck in Bios recovery mode. I never get Dell Boot screen or anything visible on screen. The system just gives me 3 white lights and 3 orange lights indicating Bios recovery mode.
                                  What I have tried to get to recover the Bios, there seems to be some conflicting advice about recovering the system.
                                  All of them say to download the latest bios from the dell website which is a .exe file. I have done that
                                  https://www.dell.com/support/product...BUT090/drivers
                                  Some...
                                  07-07-2025, 06:52 AM
                                • electronica
                                  dell 5502 manufacturing mode - HELP -
                                  by electronica
                                  hello friends i have 2 dell laptops 15 5502 with admin password . i unlocked the first one but for the second one i lost the original bios file so i used the file from the first one (after cleaning the me) the laptop start normally in manufacturing mode so i press fn key + f or x and enter the service TAG
                                  and when i reboot everything is gone the laptop return to the manufacturing mode with an empty service tag field. i tested so many bioss and versions with no luck . if someone had same problem or a solution . thank you
                                  08-21-2022, 03:10 PM
                                • Bowline
                                  by Bowline
                                  06-11-2025, 10:13 AM
                                • CapThatBrass
                                  Dell Latitude 3420 BIOS - Manufacturing Mode Required
                                  by CapThatBrass
                                  I'm having some issues with a Dell Latitude 3420 laptop I'm working with. The chip itself is an XMC25RH256CXIQ but I've not been able to find the exact settings for this chip using NeoProgrammer.
                                  Instead, I've made a dump of the image using the following three chip settings within the software:
                                  - XC25QW256C
                                  - W25Q256BV
                                  - MX25L25635E
                                  All three images have been uploaded. Oddly enough all three images aren't identical, but I'm guessing that the XMC XC25QW256C version might be the closest match.
                                  If someone...
                                  06-11-2022, 03:48 PM
