The Mystery of 'Manufacturing Mode' - Dell Motherboards
  • CapThatBrass
    • Oct 2021
    • 46
    Firstly sorry if this is the wrong forum for posting this question - please recategorize or move to another part of the forum if necessary.
    I've been doing alot of research recently into the world of BIOS editing and building of images, out of curiosity mainly.
    Lots of Youtube videos as well as threads in this forum (as well as others) mention the term 'unlocked' bios which generally means the removal of BIOS passwords from a dumped image to allow full access to the BIOS/UEFI menu. However, a handful mention that a prompt for the Service Tag will appear upon boot - this function is brought on by the enabling of 'Manufacturing Mode'.
    It would be interesting to know what Manufacturing Mode actually is - is it something specific to Dell or is it a universal property provided by the likes of Intel to allow all laptop manufacturing brands to test their equipment?
    Is there a way to invoke or enable Manufacturing Mode within a dumped BIN image, which can then be written back to the chip to be booted from?
    Any advise or guidance would be great.
  • CapThatBrass
    • Oct 2021
    • 46
    Re: The Mystery of 'Manufacturing Mode' - Dell Motherboards
    Can anyone help out?
    • volinakis
      • Jan 2021
      • 3238
      • N/A
      wow, so you need to learn how to use a search engine on internet, It took 2s ...
      "Manufacturing mode is a special BIOS mode designed to decrease the time systems spend on the assembly line. This is done by skipping nonessential boot functions/tests and by prioritizing removable media boot devices over internal hard drive controllers in the boot order. In combination, these changes decrease the boot time significantly which allows more systems to complete the factory processes in less time. When a system successfully completes the factory processes, it is taken out of Manufacturing mode. It is very unlikely a customer would receive a system in Manufacturing mode out of the box. Manufacturing mode is more likely to be seen when a system board is replaced."
      Modifying bios to enter in manufacturing mode allows to reset bios to factory defaults, hence removal of passwords, computrace, boot order or removed devices from boot order.
      please support this forum
      • CapThatBrass
        • Oct 2021
        • 46
        Thanks for copying and pasting the first paragraph that Google chucks out Volinakis.....
        • diif
          • Feb 2014
          • 6978
          • England
          It's a Dell thing. https://www.dell.com/support/kbdoc/e...facturing-mode
          • volinakis
            • Jan 2021
            • 3238
            • N/A
            you are welcome! don't tell me that you need translation from English to English ... otherwise I don't understand why did you ask what is " Manufacturing Mode" and what it wants from you ...
            • Ali5914
              • Dec 2020
              • 48
              • India
              Hello Friend, absolutely this is possible to UNLOCK Manufacturing Mode in DELL machines. But there is some limitations. You can not unlock for all models. But whichever models completely rely on bios not on EC bios (Super IO), you can unlock those models by simply replacing EC region of the bios with STOCK EC RGN from downloaded EXE.
              • CapThatBrass
                • Oct 2021
                • 46
                Thanks for the explanation Ali5914, this would make sense, I didn't realise that replacing the machines EC region with stock from an extracted BIOS image would cause the machine to boot into Manufacturing Mode.
                • Ali5914
                  • Dec 2020
                  • 48
                  • India
                  You're Welcome.... Try doing it... If it is not happening then let me know. I will guide you on this.
                  • vbpablo
                    • Feb 2023
                    • Chile
                    Hi everyone!
                    May I can find here the help that I need
                    I have a Dell G3 15 3500 that failed due to a short circuit (also with an expired guaranty), and the guys from the service did awful work, so I had to buy a 2nd-hand motherboard.
                    Once installed the MB, the notebook didn't turn on. So after we tried unsuccessfully to reprogram the BIOS, we opted to change the BIOS chips with the ones in the old MB (that looked ok and were recognized by the reprogrammed). The notebook turned on again, and we were even able to boot to windows... but as you can expect, it booted in manufacturing mode, and it's annoying (and maybe unsafe) to work with the notebook in that mode.
                    We found this post googling about the manufacturing mode, but as the notebook is dual BIOS, we don't know where and how we should edit the EC region data.
                    Also, we found a post on another website (https://winraid.level1techs.com/t/gu...lization/31277) that talk about a conflict involving intel engine (cs)me/cs(txe) regions data. That makes us think that the information contained within the EC chip could be related to the problem, but we're not entirely sure about that.
                    What do you suggest to fix the issue??
                    A friend is doing the BIOS magic; I'm just translating him, so feel free to correct me on anything you consider wrong.
                    • Vusal
                      Senior Tech.
                      • Feb 2016
                      • 72
                      • Azerbaijan
                      • I do different projects with metal and wood.
                      I replaced EC region with the other one but I did not get any results.
                      • qayyum786
                        • Aug 2018
                        • 1959
                        • INDIA
                        post your backup file
                        • Ghost18_07
                          • Mar 2018
                          • 87
                          • Algeria
                          Great thread, this a mystery as you said, and you are right, i have the same problem, i have this manufacturer mode sentence and it says to just click Alt+F to stop it, but it won't even if i ty to enter the service tag, because the service tag gone after i save the changes .
                          So if anyone has a solution for this ? or i just need to try to fi the BIOS file again ?
                          • Argento7
                            • Jan 2010
                            • 27
                            • Electronics, Computer, Car security
                            Adding some information
                            • Ghost18_07
                              • Mar 2018
                              • 87
                              • Algeria
                              I found a solution, but not me, someone edit my bios file again and it worked just fine. So the problem is related to a BIOS fix, I don't know where exactly but that's the only way to fix it.
                              Will be back if any new information collected.
                              • eenee
                                • Aug 2022
                                • 50
                                • Mongolia
                                • gg
                                Can you post both your old and new bios, so we can compare the changes
                                • geethmadu
                                  • Mar 2023
                                  • 55
                                  • united kingdom
                                  Hi All,
                                  I have a dell Ins 3501 with Service tag : 192DSD3. I flashed both 8MB and 16MB bins. I even put the correct service tag on to the BIOS. But " Manufacture Mode Active" message still appears on the post. Can someone advice what to do next? it has been a headache.
                                  Thank you very much
                                  • Tesla
                                    • Jul 2011
                                    • 152
                                    How about some pics?
                                    These are from a Dell XPS-15 I am working on. It's been dead for a while, but it's looking better now.
                                    I'm in the USA, and disabling the ME did not sound correct, so I just left the options on these defaults.
                                    Click image for larger version  Name:	mfg-mode-1.jpg Views:	0 Size:	242.0 KB ID:	3849143
                                    Click image for larger version  Name:	mfg-mode-2.jpg Views:	0 Size:	172.5 KB ID:	3849144
                                    • Tesla
                                      Tesla commented
                                      Editing a comment
                                      I entered the Service-Tag and it exited Manufacturing Mode properly. The laptop is working fine.
                                  • kodinabeel
                                    • Sep 2014
                                    • 82
                                    • saudi arabia
                                    i have an issue dell optiplex 5480aio (GLTQ073) cant save serial number manufaturing mode doesnt dissappire. orginal bios lost i downloaded from internet any solution ?
                                    • Tesla
                                      • Jul 2011
                                      • 152
                                      Seems to do some self-checks before it releases. Read screen carefully. Did you re-connect CMOS battery?
                                      • adiko93
                                        Dell 5540 no boot after exiting manufacturing mode
                                        by adiko93
                                        Hey, im stuck with troubleshooting my Dell 5540 i7 vPro with 203032-1 motherboard. Every time i try to leave manufacturing mode it stops booting. I've tried clean ME Region clean BIOS but nothing really helps. Any help would be much appriciated
                                        Both chip dumps in attachments aswell as logs from MEInfo. I can't get the originnal bios to work, im only able to boot with clean BIOS
                                        I've tried to update the BIOS via Dell Update (it skipped ME Region saying it's up to date) with /forceit flag, that didn't help and im suspecting the issue might be somewhere else
                                        03-02-2026, 04:55 PM
                                      • chrome_dome
                                        Looking for information on flashing BIOS on Dell Windows laptops, so user can enter service tag at boot
                                        by chrome_dome
                                        Hello all,
                                        I am looking into flashing the BIOS on Dell Windows laptops.
                                        The customers want these to boot to the dialog box that prompts the user to enter the Service Tag. On a new device, this would happen on the first boot.
                                        On older models, we could use a hex editor to blank out the old service tag and this would work. But modern Dell laptops do not allow this.
                                        We have BIOS from brand new boards, that we thought we could overwrite old BIOS with this fresh copy but that doesn't seem to work.
                                        Any advice would be greatly appreciated....
                                        04-20-2026, 08:52 AM
                                      • Bowline
                                        by Bowline
                                        06-11-2025, 10:13 AM
                                      • mamado mosa
                                        Slow boot dell latitude 5410 laptop issues
                                        by mamado mosa
                                        So i had this laptop dell latitude 5410 10th gen, good condition and new ssd and 16 gb ram .
                                        The problem is it takes more than a minute to boot ..
                                        The boot sequence starting with a 30 sec black screen and the the dell logo for 20 and when the windows start loading it takes like 7 sec .
                                        Can someone suggest something to fix
                                        06-19-2025, 06:55 AM
                                      • estabilito
                                        Swapped CPU from Fujitsu to Dell - boot guard?
                                        by estabilito
                                        Hello, i just swapped CPU(i5-8350u) from fujitsu lifebook e548 to Dell Latitude E7490 Board, all resistances are fine, laptop wants to boot but after 1 second draw of 0,3A its turning off, after pressing power on button same situation. I've cleaned ME region and same situation. Is it boot guard problem - and if it is, is it any chance to bypass this or this cpu just can't be used in Dell.
                                        05-27-2025, 05:26 PM
