Try our *UPDATED* boardview, bios, & schematic search. Over 2.3 million files for download!
The Mystery of 'Manufacturing Mode' - Dell Motherboards
we can enter any letters or word but its not saved after restarting it ask manufacturing mode active -
Entering all CAPS? Is that a zero or letter? I wonder if there is a check-digit/hash on serial? If you just want it to go away (don't care what serial number is) you could try 1234567 ... because I've seen evaluation-units come to me that way before.Leave a comment:
Seems to do some self-checks before it releases. Read screen carefully. Did you re-connect CMOS battery?Leave a comment:
i have an issue dell optiplex 5480aio (GLTQ073) cant save serial number manufaturing mode doesnt dissappire. orginal bios lost i downloaded from internet any solution ?Leave a comment:
Hi All,
I have a dell Ins 3501 with Service tag : 192DSD3. I flashed both 8MB and 16MB bins. I even put the correct service tag on to the BIOS. But " Manufacture Mode Active" message still appears on the post. Can someone advice what to do next? it has been a headache.
Thank you very much
Can you post both your old and new bios, so we can compare the changes
I found a solution, but not me, someone edit my bios file again and it worked just fine. So the problem is related to a BIOS fix, I don't know where exactly but that's the only way to fix it.Great thread, this a mystery as you said, and you are right, i have the same problem, i have this manufacturer mode sentence and it says to just click Alt+F to stop it, but it won't even if i ty to enter the service tag, because the service tag gone after i save the changes .
So if anyone has a solution for this ? or i just need to try to fi the BIOS file again ?
Will be back if any new information collected.Leave a comment:
So if anyone has a solution for this ? or i just need to try to fi the BIOS file again ?Leave a comment:
I replaced EC region with the other one but I did not get any results.Leave a comment:
Re: The Mystery of 'Manufacturing Mode' - Dell Motherboards
Hi everyone!
May I can find here the help that I need
I have a Dell G3 15 3500 that failed due to a short circuit (also with an expired guaranty), and the guys from the service did awful work, so I had to buy a 2nd-hand motherboard.
Once installed the MB, the notebook didn't turn on. So after we tried unsuccessfully to reprogram the BIOS, we opted to change the BIOS chips with the ones in the old MB (that looked ok and were recognized by the reprogrammed). The notebook turned on again, and we were even able to boot to windows... but as you can expect, it booted in manufacturing mode, and it's annoying (and maybe unsafe) to work with the notebook in that mode.
We found this post googling about the manufacturing mode, but as the notebook is dual BIOS, we don't know where and how we should edit the EC region data.
Also, we found a post on another website (https://winraid.level1techs.com/t/gu...lization/31277) that talk about a conflict involving intel engine (cs)me/cs(txe) regions data. That makes us think that the information contained within the EC chip could be related to the problem, but we're not entirely sure about that.
What do you suggest to fix the issue??
A friend is doing the BIOS magic; I'm just translating him, so feel free to correct me on anything you consider wrong.Leave a comment:
You're Welcome.... Try doing it... If it is not happening then let me know. I will guide you on this.Leave a comment:
Thanks for the explanation Ali5914, this would make sense, I didn't realise that replacing the machines EC region with stock from an extracted BIOS image would cause the machine to boot into Manufacturing Mode.Leave a comment:
Hello Friend, absolutely this is possible to UNLOCK Manufacturing Mode in DELL machines. But there is some limitations. You can not unlock for all models. But whichever models completely rely on bios not on EC bios (Super IO), you can unlock those models by simply replacing EC region of the bios with STOCK EC RGN from downloaded EXE.Leave a comment:
you are welcome! don't tell me that you need translation from English to English ...
otherwise I don't understand why did you ask what is " Manufacturing Mode" and what it wants from you ...
It's a Dell thing. https://www.dell.com/support/kbdoc/e...facturing-modeLeave a comment:
Thanks for copying and pasting the first paragraph that Google chucks out Volinakis.....Leave a comment:
by adiko93Hey, im stuck with troubleshooting my Dell 5540 i7 vPro with 203032-1 motherboard. Every time i try to leave manufacturing mode it stops booting. I've tried clean ME Region clean BIOS but nothing really helps. Any help would be much appriciated
Both chip dumps in attachments aswell as logs from MEInfo. I can't get the originnal bios to work, im only able to boot with clean BIOS
I've tried to update the BIOS via Dell Update (it skipped ME Region saying it's up to date) with /forceit flag, that didn't help and im suspecting the issue might be somewhere else
by chrome_domeHello all,
I am looking into flashing the BIOS on Dell Windows laptops.
The customers want these to boot to the dialog box that prompts the user to enter the Service Tag. On a new device, this would happen on the first boot.
On older models, we could use a hex editor to blank out the old service tag and this would work. But modern Dell laptops do not allow this.
We have BIOS from brand new boards, that we thought we could overwrite old BIOS with this fresh copy but that doesn't seem to work.
Any advice would be greatly appreciated.... -
by BowlineMy question pertains to understanding the control circuity inside a Dell PT434 type battery used in Dell E6400, E6410 and other Dell notebooks?
I have tried multiple different Dell power adapters. My Dell... -
by mamado mosaSo i had this laptop dell latitude 5410 10th gen, good condition and new ssd and 16 gb ram .
The problem is it takes more than a minute to boot ..
The boot sequence starting with a 30 sec black screen and the the dell logo for 20 and when the windows start loading it takes like 7 sec .
Can someone suggest something to fix -
by estabilitoHello, i just swapped CPU(i5-8350u) from fujitsu lifebook e548 to Dell Latitude E7490 Board, all resistances are fine, laptop wants to boot but after 1 second draw of 0,3A its turning off, after pressing power on button same situation. I've cleaned ME region and same situation. Is it boot guard problem - and if it is, is it any chance to bypass this or this cpu just can't be used in Dell.
- Loading...
