HP 650 g1 power button light only
  • greenBlue
    • Oct 2022
    Hi!
    need help about reflashing bios at MX25L12873F .
    Laptop is HP 650 G1.
    I have original flash with passworld. flashroom and raspberry pi used for this task...but not for rw.
    When i try to put unloched bios (with hpunlook) somthing wrong hapend.
    Programer EZP2019 and chipset MX25L12805D only apropiat chipset with manual settings (see with this programmer) was last task..
    Now HP 650 G1 laptop have power button with led liht and that is all..
    Please help me with step by step instruction and default flash without bios passworld.
    Regards!
  • themosttogain
    HP Envy 13-BA1565na with intermittent power button
    by themosttogain
    Hope someone can give me some suggestions on this because i'm at my wits end with it...
    I have an Envy 13-BA1565na here with an Intel Core i7 i7-1165G7 CPU (board is a LA-J475P Rev 1.0) which has an intermittent power button issue. The power button is integrated into the keyboard, and I have ruled out the keyboard, BIOS and battery as being the issue.
    Basically, on mains power, the power button works fairly well. The first time you come to it after leving it sitting (either on charge or not on charge), it might take 2 or 3 presses of the button, but then the laptop boots...
    07-12-2024, 03:03 AM
  • pni
    Samsun ue49ku6450 blinking red light only when press the power button
    by pni
    Hi guys I have this tv Samsung eu49ku6450 that have a problem. When I plug in the power cord the standby led starts to blink but nothing happen. Then the standby led disappear. If I push the power button I see the standby led blinking but nothing happens and if I stop to press the button I don’t have the standby led red…nothing . I don’t understand if there is a problem in the main board or in the power board or it s a firmware problem. I tried to disconnect the main board from the power board, and I know the led should turn on when the main is unplugged but nothing happen…..so could be...
    11-28-2025, 02:18 PM
  • Andreasbest
    Dell Latitude 7410 dead and amber light as long power button is pressed.
    by Andreasbest
    Hello.
    I received a bios locked 7410 with 25Q256JVEQ ,i dump the bios, unlocked it and flash it back, since then the laptop has no life signs at all except amber led on for as long the power button is pressed, nothing else.
    Fact #1 i was unaware that 25Q256JVEQ is 3.3v and i used a 5v CH341A to program it, not sure if the chip got damaged but since then i can read it and write it normally, doesn't seem dead.
    Fact #2 i modded the CH341A to 3.3v, same results with programming though, nothing changed.
    Fact #3 i tried hard reset with cmos/main battery disconnected and power...
    12-21-2024, 02:02 PM
  • zwect
    Dell Latitude 5420 / GDF40 LA-K491P REV 3.0 / Amber / Orange light when power button is pressed
    by zwect
    I have this Dell Latitude 5420 with ST: CMF62F3, board GDF40 LA-K491P REV 3.0 that does not power on, i already searched for some clues about this problem that happens on mine but no BIOS i downloaded and flashed did anything.
    Only when the power brick is connected, when pressing the power button an amber light lights up at the front and slight decreases its brightness, the RAM and the CPU seem to heat up if the laptop is left connected but nothing else, other than USB devices getting powered.
    Here is the original BIOS dump from the 25R256JVEN chip.
    09-11-2024, 05:54 PM
    Lithonia Lighting versus Light of America Compact Fluorescent product quality
    I have a Lithonia Lighting 65-Watt Gray Hardwired Compact Fluorescent
    I also have back when Light of America had these light bulbs available for yard lights
    The issue with Light of America was the blast boards had all most certain board failure while bulbs hardly ever fail
    While the Lithonia lighting fixture has all most certain bulb failure
    So I have modified the Lithonia lighting fixture to accept the Light of America light bulb and see how long this will last
    I have only had this light fixture for not more than a year if it...
    07-02-2023, 03:45 PM
