Hi guys I have this tv Samsung eu49ku6450 that have a problem. When I plug in the power cord the standby led starts to blink but nothing happen. Then the standby led disappear. If I push the power button I see the standby led blinking but nothing happens and if I stop to press the button I don’t have the standby led red…nothing . I don’t understand if there is a problem in the main board or in the power board or it s a firmware problem. I tried to disconnect the main board from the power board, and I know the led should turn on when the main is unplugged but nothing happen…..so could be also a backlight problem? How you can see I need your help haha
Samsun ue49ku6450 blinking red light only when press the power button
by mecha1166I am working on a QN750Q8FNBFXZA. Dead except the standby light. It blinks what appears to be 1 3 1 2. 1 long blink, pause, 3 short, pause, 1 long, pause, 2 short, pause, repeat. A service manual would be very helpful, or if anyone knows these error codes. Thanks!
by WoodsworthI have a post on psx-place for this but thought I'd try here as well in case anyone has experience or the schematics or any kind of help. Here's the original post from psx-place:
START
Hi, so I bought a YLOD Fat PS3 as I wanted a repair project and thought it would be a good way to get experience. I was able to solder to the RX, TX and Diag pads on the COK-002 motherboard and was able to get external access and retrieved the codes. I haven't powered it on beforehand so these should be the last ones. I did try to get internal access immediately after but kept getting scopen response... -
by YasaChHello...
my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
i opened the back cover no sign of damage on the powery suply or motherboard
when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites2 Photos -
by brithepi2kHi,
I’ve got a Sony KD-65XE8596 here that has no standby light coming on. I’ve tested the power board with the test meter, the TV needs 3.4 for the standby but only getting 2.4. Anything that I can change/check on the board to get it working? Pictures of the board are included.
cheers...5 Photos -
by AleMontiHi everyone,
I'm trying to troubleshoot and repair this old LG OLED curved TV, model 55EG910V.
I did some basic troubleshooting and reviewed most related posts here, but I wasn't able to isolate the issue.
The TV shut itself off during playback and never came back to life - the standby light remains off. My dad claims that it has happened a few times in the past but the issue resolved itself after some time. Not this one.
After checking the basics I did the following:- I measured all voltages and as expected the only active supply is the 3.5V standby. It
- Loading...
