Need unlocked bios for Getac S410 G2
  • thaochua1982
    • Feb 2021
    • 25
    • ho chi minh
    already unlocked my seft.thanks alot
    • it_podval_812
      • Mar 2024
      • 5
      • russia
      Can you help me unlock bios pass Getac s410 g2 i7-8550 s\n RJ903S0172
      • thaochua1982
        • Feb 2021
        • 25
        • ho chi minh
        try this
        • bernhard95
          • Jan 2025
          • 5
          • Austria
          Please help me remove the BIOS password from my Getac S410 G2.
          I have found two SPI flash chips next to the memory slots. One is a Winbond chip, which seems to be an 8MB flash. I can't read from this chip, it seems to be protected.
          The other is a Macronix MX25L12873F 16MB flash. I have successfully dumped this flash and hope this is the right one.
          Model: GETAC S410 G2 INTEL I7 8650U
          SN: RK603S2602
          MOTHERBOARD: TF1-TH-PCB PWA-S410G2 ASSY.411886200134-k
          • shiyab
            • Sep 2023
            • 1459
            • india
            SN: RK603S2602
            hi try
            • bernhard95
              • Jan 2025
              • 5
              • Austria
              #26
              Is it possible to dump the GETAC S410 G2 BIOS in-circuit, or do I need to desolder the chip?
              I have now done 3 in-circuit dumps and compared them. Each time, there are significant differences.
              I want to be sure I have a valid dump of the chip before flashing the unlocked binary.
              Maybe my CH341A is defective.
              I have ordered a new one, the Geieold Programmer CH341A​, I will try again with this programmer..
              • peste
                • Dec 2016
                • 12792
                • ROMANIA
                #27
                I have ordered a new one, the Geieold Programmer CH341A, I will try again with this programmer..
                The bios chip must be unsoldered from the board before writing or reading..
                do not use the clip, you may have errors..if you do not have anything to unsolder it with,
                solder wires between the programmer and the bios chip..​
                • bernhard95
                  • Jan 2025
                  • 5
                  • Austria
                  #28
                  Thanks for your reply.
                  Normally, I work on a Lenovo, where the clip works fine.
                  Could someone please confirm which is the right chip?
                  The left one, Winbond,
                  or
                  The right one, Macronix?
                  • bernhard95
                    • Jan 2025
                    • 5
                    • Austria
                    #29
                    With my new CH341A V1.7 programmer, I was able to get a valid dump of the Macronix MX25L12873F. The clip works fine for dumping in-circuit.
                    Please help me remove the BIOS password from this file.
                    The PC data is still the same:
                    SN: RK603S2602
                    THANKS
                    • shiyab
                      • Sep 2023
                      • 1459
                      • india
                      #30
                      SN: RK603S2602
                      THANKS
                      POST 25 try
                      • volinakis
                        • Jan 2021
                        • 2733
                        • N/A
                        #31
                        SN: RK603S2602
                        THANKS
                        try. Using clips and CH341 is better to read chipset 3-4 times and compare results, when you have 2 identical dumps you can be sure you have a correct bios dump.
                        • bernhard95
                          • Jan 2025
                          • 5
                          • Austria
                          #32
                          Thanks, I was able to remove the BIOS password using your file! (without the need for desoldering the chip)
                          • volinakis
                            • Jan 2021
                            • 2733
                            • N/A
                            #33
                            you are welcome
                            • jinsoo kang
                              • Jul 2025
                              • Republic of Korea
                              #34
                              I lost my cimos password. Is there a way to retrieve it?
                              getac s410 g2
                              s/n
                              RKAXXS1242
                                SMDFlea commented
                                Editing a comment
                                Thread merged.
                            • peste
                              • Dec 2016
                              • 12792
                              • ROMANIA
                              #35
                              getac s410 g2
                              s/n
                              RKAXXS1242
                              post the original contents of the bios chip..
                              • andrecus
                                • Jul 2025
                                • 3
                                • Kazakhstan
                                #36
                                Need unlocke bios of Getac S410 G2 CPU i5-8250U
                                Serial Number: RJA03S0852
                                BIOS Properties:
                                Vendor INSYDE Corp.
                                Version R1.31.070520
                                Release Date 12/13/2023
                                System BIOS Version 1.31
                                Embedded Controller Firmware Version 1.10
                                Thank you in advance.​
                                • shiyab
                                  • Sep 2023
                                  • 1459
                                  • india
                                  #37
                                  BIOS Properties:
                                  Vendor INSYDE Corp.
                                  post backup bios
                                  • andrecus
                                    • Jul 2025
                                    • 3
                                    • Kazakhstan
                                    #38
                                    Originally posted by shiyab
                                    post backup bios
                                    Good afternoon. No, not after copying. I just want to open the hidden BIOS settings. Can you help me with that?
                                    • andrecus
                                      • Jul 2025
                                      • 3
                                      • Kazakhstan
                                      #39
                                      Can anyone tell me how to open the hidden settings in the BIOS of the Getac S410G2 laptop, what key combinations need to be pressed.
                                      • Citymin
                                        by Citymin
                                        S/N : 5RNK9FFT70...
                                        Today, 05:12 AM
                                      • Forest79
                                        by Forest79
                                        However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
                                        07-23-2023, 07:39 AM
                                      • maanee11
                                        Help to get Lenovo BIOS bin file for Thinkpad T560
                                        by maanee11
                                        Hello Everyone,
                                        I have Thinkpad T560 Which has corrupted BIOS. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need a bin file for the BIOS. I was able to extract the .exe file of BIOS from Lenovo given here in this link:
                                        https://pcsupport.lenovo.com/au/en/p...me=BIOS%2FUEFI
                                        In the extracted files, I see that BIOS containing file has extension .FL1 and I need to extract or convert it...
                                        05-15-2022, 11:59 AM
                                      • Sebastian Codrean
                                        BIOS file for ASUS F542UN laptop
                                        by Sebastian Codrean
                                        Hello to all of you! I need help with a BIOS file.
                                        The BIOS chip is fried on my Asus F542UN laptop, and I bought a new chip that needs programming. I have a CH341a programmer but I need a .bin BIOS file. On Asus support page the firmware has another extension, .310 and from reading on this forum I understand that that file is not complete BIOS.
                                        So, in short I need the "complete" BIOS .bin file to flash on the new chip. Another issue is that on back of the case the label says F542UN but on the sticker on the motherboard it's X542UN.
                                        02-20-2025, 10:25 AM
                                      • Fr33man
                                        BIOS file (.BIN) for semi-Bricked IdeaPad 3-14ALC6
                                        by Fr33man
                                        I soft BRICKED my Lenovo IdeaPad laptop (black screen with led lights on, responsive keyboard backlight, fans spinning) after messing about with a Github tool called Smokeless. I am now attempting to reflash the bios through USB, but I am not sure if I extracted the correct BIOS ROM file to flash, and I also could not find the correct file name to rename it to (GLCrisis.bin, GLCN.bin, Currom.bin??). In addition to attempting to reflash the Bios with a USB, I have also performed the following activities:
                                        *Novo button power on
                                        *Disconnected internal battery...
                                        09-23-2024, 01:16 PM
