Need unlocked bios file for a Getac s410 G2. Please and thank you!
Need unlocked bios for Getac S410 G2
Tags: None
Re: Need unlocked bios for Getac S410 G2
is this the right chip and bios dump
?Attached Filesif you find these attachements useful please consider making a small donation to the site
That's it.
Try this file.Attached Filesif you find these attachements useful please consider making a small donation to the site
https://www.badcaps.net/donateComment
Thank you I tried the file. but no change. Maybe i'm writing it wrong? when i tried it a message that says something about protect might be enabled and to check my settings....Comment
nevermind i selected the wrong chip. going to try again later on. Ill update with resultsComment
TryAttached Filesif you find these attachements useful please consider making a small donation to the site
That you worked. But now wont boot right says smbios fails when I run diag. i notice that there is no serial number now...Comment
This one has a serial number.Originally posted by gzljwThis one has a serial number. Please feed back the resultAttached Filesif you find these attachements useful please consider making a small donation to the site
Hi, I need unlock BIOS for GETAC S410 G2, chip W25Q80DVS, thank you very muchAttached Filesif you find these attachements useful please consider making a small donation to the site
read..https://www.badcaps.net/forum/troubl...before-posting
Post the full name and model, motherboard model, S/N, etc...
Send to youAttached Filesif you find these attachements useful please consider making a small donation to the site
need unlocke bios of Getac S410
Every donation made will go towards server fees and maintenance costs.Comment
try..Attached Filesif you find these attachements useful please consider making a small donation to the site
by CityminHi all,
S/N : 5RNK9FFT70...-
Channel: BIOS Requests ONLY!
by maanee11Hello Everyone,
I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
In the website, you can only see specs etc.
I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...1 Photo-
by m1ch43lzmHi everyone
There's also an extra OTP Secu.R...-
by Forest79Hello,
However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...-
I have Thinkpad T560 Which has corrupted BIOS. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need a bin file for the BIOS. I was able to extract the .exe file of BIOS from Lenovo given here in this link:
https://pcsupport.lenovo.com/au/en/p...me=BIOS%2FUEFI
In the extracted files, I see that BIOS containing file has extension .FL1 and I need to extract or convert it...-
- Loading...
