already unlocked my seft.thanks alot
Need unlocked bios for Getac S410 G2
Can you help me unlock bios pass Getac s410 g2 i7-8550 s\n RJ903S0172Attached FilesComment
Please help me remove the BIOS password from my Getac S410 G2.
I have found two SPI flash chips next to the memory slots. One is a Winbond chip, which seems to be an 8MB flash. I can't read from this chip, it seems to be protected.
The other is a Macronix MX25L12873F 16MB flash. I have successfully dumped this flash and hope this is the right one.
Model: GETAC S410 G2 INTEL I7 8650U
SN: RK603S2602
MOTHERBOARD: TF1-TH-PCB PWA-S410G2 ASSY.411886200134-kAttached FilesComment
SN: RK603S2602
Is it possible to dump the GETAC S410 G2 BIOS in-circuit, or do I need to desolder the chip?
I have now done 3 in-circuit dumps and compared them. Each time, there are significant differences.
I want to be sure I have a valid dump of the chip before flashing the unlocked binary.
Maybe my CH341A is defective.
I have ordered a new one, the Geieold Programmer CH341A​, I will try again with this programmer..
I have ordered a new one, the Geieold Programmer CH341A, I will try again with this programmer..
do not use the clip, you may have errors..if you do not have anything to unsolder it with,
solder wires between the programmer and the bios chip..​Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
Normally, I work on a Lenovo, where the clip works fine.
Could someone please confirm which is the right chip?
The left one, Winbond,
or
The right one, Macronix?
​1 PhotoComment
With my new CH341A V1.7 programmer, I was able to get a valid dump of the Macronix MX25L12873F. The clip works fine for dumping in-circuit.
Please help me remove the BIOS password from this file.
The PC data is still the same:
SN: RK603S2602
THANKSAttached FilesComment
SN: RK603S2602
THANKSComment
SN: RK603S2602
THANKSAttached FilesLast edited by volinakis; 01-17-2025, 02:26 AM.----------------------------------------------------------------------------------------------------------------------------------------------------------------------
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
Thanks, I was able to remove the BIOS password using your file! (without the need for desoldering the chip)Comment
Need unlocke bios of Getac S410 G2 CPU i5-8250U
Serial Number: RJA03S0852
BIOS Properties:
Vendor INSYDE Corp.
Version R1.31.070520
Release Date 12/13/2023
System BIOS Version 1.31
Embedded Controller Firmware Version 1.10
Thank you in advance.​Comment
Can you help me unlock bios pass Getac S410G2 i5-8250U Serial Number: RJA03S0852Attached FilesComment
by CityminHi all,
S/N : 5RNK9FFT70...-
Channel: BIOS Requests ONLY!
by m1ch43lzmHi everyone
I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
Programmer models: XGecu TL866II Plus / T48 / T56 / T76
Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
There's also an extra OTP Secu.R...-
by Forest79Hello,
However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...-
by maanee11Hello Everyone,
I have Thinkpad T560 Which has corrupted BIOS. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need a bin file for the BIOS. I was able to extract the .exe file of BIOS from Lenovo given here in this link:
https://pcsupport.lenovo.com/au/en/p...me=BIOS%2FUEFI
In the extracted files, I see that BIOS containing file has extension .FL1 and I need to extract or convert it...-
Hello to all of you! I need help with a BIOS file.
The BIOS chip is fried on my Asus F542UN laptop, and I bought a new chip that needs programming. I have a CH341a programmer but I need a .bin BIOS file. On Asus support page the firmware has another extension, .310 and from reading on this forum I understand that that file is not complete BIOS.
So, in short I need the "complete" BIOS .bin file to flash on the new chip. Another issue is that on back of the case the label says F542UN but on the sticker on the motherboard it's X542UN.-
- Loading...
