Dell Latitude 5430, LA-L591P Computrace setting unlock
  • babydoll8867
    • Nov 2014
    • 91
    • romania
    #61
    Re: Dell Latitude 5430, LA-L591P Computrace setting unlock
    Originally posted by biniu1978
    Chip is connected directly to programmer without any adapter ( wire connection )
    hey, how did you made it through? how did you manage to read it correctly, i have the same programmer, used adapter and has the same checksum every time i read it
    • hardware1
      • Sep 2021
      • 2916
      • N/A
      #62
      Originally posted by babydoll8867
      i re-read it 2 times with the same programmer and 2 times with another programmer.. it is 25Q256JV and it has the same checksum..
      This file isn't good, I advise you not to erase the Chip before you got the Right file, otherwise your device will not work at all.
      Check your Connections, your Programmer settings and read the Chip again.
      all donations are welcome,
      • babydoll8867
        • Nov 2014
        • 91
        • romania
        #63
        desoldered it from the adapter, used a clip adapter, again, same checksum....
        • babydoll8867
          • Nov 2014
          • 91
          • romania
          #64
          i used MEAnalyzer to decompile my file and indeed the file is said to have no engine, but also tried a diffrent file from the forum that was correctly read and also gives the error. "File does not contain Intel Engine/Graphics Firmware". is this the reason you told me it is read incorrectly?
          • babydoll8867
            • Nov 2014
            • 91
            • romania
            #65
            checked, ME and other stuff is in the other, 16mb flash
            • hardware1
              • Sep 2021
              • 2916
              • N/A
              #66
              Yes, that's because your Device has an Intel 12th Gen CPU.
              Here's your Unlocked BIOS, hope it works fine.
              • JAVIERBS
                • Oct 2022
                • 8
                • spain
                #67
                Hi here is bios with admin lock of Dell Latitude 5430. Please can you unlock?.
                Thanks.
                • lapfix
                  • Mar 2020
                  • 2654
                  • my workshop
                  #68
                  Thanks.
                  >>>>> click on this link to donate via PayPal. <<<<<
                  1st boot, press F2, write service tag, disable Absolute, save, restart. 2nd boot press Alt+F to exit manufacturing mode.
                  • janpatirkckaram1992
                    • Sep 2020
                    • 9
                    • Philippines
                    #69
                    hdb42 la-l591p rev 1.0 (a00)
                    admin lock
                    ST: BB9GKR3
                    • anhbanxoi
                      • Sep 2021
                      • 169
                      • VN
                      #70
                      admin lock
                      ST: BB9GKR3
                      Flash this file
                      • DarkMooon
                        • Apr 2021
                        • 11
                        • UA
                        #71
                        Hi can anyone assist in removing password on this ?
                        • Vesko356
                          VIP Moderator
                          • Aug 2018
                          • 4386
                          • Bulgaria 🇧🇬
                          #72
                          Become a Badcaps supporter
                          Thanks to all supporters.​
                          • DarkMooon
                            • Apr 2021
                            • 11
                            • UA
                            #73
                            Thank you, it worked
                            • vidijus
                              • Oct 2017
                              • 17
                              • lietuva
                              #74
                              Hello please remove password
                              • Vesko356
                                VIP Moderator
                                • Aug 2018
                                • 4386
                                • Bulgaria 🇧🇬
                                #75
                                • vidijus
                                  • Oct 2017
                                  • 17
                                  • lietuva
                                  #76
                                  Thank you ))
                                  • Vesko356
                                    VIP Moderator
                                    • Aug 2018
                                    • 4386
                                    • Bulgaria 🇧🇬
                                    #77
                                    Thank you ))
                                    You're welcome!
                                    You can return the favor by clicking on the link below and donating an amount of your choice to support the forum!
                                    • JAVIERBS
                                      • Oct 2022
                                      • 8
                                      • spain
                                      #78
                                      Many thanks !!! It worked.
                                      • Arrow16
                                        • Apr 2022
                                        • 229
                                        • Philippines
                                        #79
                                        Dell 5430 absolute enable need to disaable, tnx
                                        • Arrow16
                                          • Apr 2022
                                          • 229
                                          • Philippines
                                          #80
                                          Nneed help i already remove admin password but absolute is not
                                          • kaput
                                            Lenovo Thinkcentre M720q, disable activated Computrace
                                            by kaput
                                            Not a BIOS request per se, but closely related. Please bear with me
                                            A while ago I found an old Lenovo Thinkcentre M720q in pieces in the electronics scrap bin at work. There was only some minor damage to the case, so collected everything and brought it home to let it dry and see if it still worked. It did
                                            Unfortunately Computrace has been activated on it. Since I'm using it as an emulation console with Lakka now, it's no big deal, but would be nice to get rid of the annoying message popping up when entering the UEFI setup, and also learn something along the way....
                                            06-28-2024, 09:36 AM
                                            HP xw6600 Intel Xeon Quad Core 5430 2.66GHz 2GB/250GB No Graphics DVD+/-RW WVST Bus Workstation E5430 Specification for Upgrade or Repair
                                            This specification for the HP xw6600 Intel Xeon Quad Core 5430 2.66GHz 2GB/250GB No Graphics DVD+/-RW WVST Bus Workstation can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the xw6600 Intel Xeon Quad Core 5430 2.66GHz 2GB/250GB No Graphics DVD+/-RW WVST Bus Workstation boardview and xw6600 Intel Xeon Quad Core 5430 2.66GHz 2GB/250GB No Graphics DVD+/-RW WVST Bus Workstation schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated...
                                            09-12-2024, 03:36 PM
                                            DELL Latitude 5430 Notebook 5000 Specification for Upgrade or Repair
                                            This specification for the DELL Latitude 5430 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5430 boardview and 5430 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 5430...
                                            09-07-2024, 06:31 AM
                                          • Syseng
                                            Lenovo P14s Gen 5 SVP unlock
                                            by Syseng
                                            This sums up discussion related to Lenovo P14s Gen5 in this thread. Credits go to Sbaro and especially Maxpower3. The locked dump is attached.
                                            The device is based on NM-F871 motherboard with Nuvoton NPCK397 series controller. The motherboard also contains three BIOS chips: two different Winbond chips for main BIOS and external EC flash, and also a Gigadevice chip which purpose I do not know. The password information is contained directly in controller and thus can be manipulated by reprogramming it, so reprogramming BIOS chips is technically not required, however you may wish to make...
                                            06-22-2025, 07:44 AM
