Dell Latitude 5430, LA-L591P bios
  • volinakis
    • Jan 2021
    • 2887
    • N/A
    Re: Dell Latitude 5430, LA-L591P Computrace setting unlock
    Originally posted by Fixit2022
    here is the correctly bios
    try. 1st boot press F2, write Service Tag, disable Absolute, save, restart. 2nd boot press alt+F to exit manufacturing mode.
    • Fixit2022
      • Nov 2022
      • 16
      • Deutschland
      I accidentally soldered the chip the wrong way around and now the notebook no longer starts no light nothing I just broke the chip or is the whole notebook defective.
      • peste
        • 14052
        • ROMANIA
        it happens again...put it back correctly and see what happens..maybe you'll be lucky...
        • Fixit2022
          • Nov 2022
          • 16
          • Deutschland
          Unfortunately not. When I press the power button, the orange light lights up very briefly and nothing else happens. Is it possible to solder in another BIOS chip?
          • Fixit2022
            • Nov 2022
            • 16
            • Deutschland
            Can I install this chip W25Q256JVEQ Flash IC or does it have to be exactly the W25Q256JVEN that is installed?
            • volinakis
              • Jan 2021
              • 2887
              • N/A
              #26
              yep, it's ok.
              • Moh.Jr.Boudali
                • Nov 2018
                • 33
                • Algeria
                #27
                hello, me too, i need help for:
                laptop / DELL LATITUDE 5430 /
                motherboard / HDB42 LA-L591P Rev:1.0(A00) /
                cpu / INTEL 12TH GEN /
                service tag / #9X9BRQ3-8FC8
                spi chip / WINBOND 32MB@WSON8
                thanks.
                • volinakis
                  • Jan 2021
                  • 2887
                  • N/A
                  #28
                  thanks.
                  • Wasabilera
                    • Feb 2023
                    • US
                    #29
                    Hello! I've got a locked Dell Latitude 5430 as well.
                    Admin password and Dell SafeBIOS enabled
                    Latitude 5430 / LA-L591P
                    Winbond 25Q256JVEN flash
                    Locked dump is attached. Thanks!
                    • hardware1
                      • Sep 2021
                      • 2951
                      • N/A
                      #30
                      Here's your Unlocked Bios, hope it works fine.
                      all donations are welcome,
                      • Wasabilera
                        • Feb 2023
                        • US
                        #31
                        Hi, thanks for the file. With the new file flashed, I'm getting no power on the laptop and only an amber light when the button is held. I double checked the orientation of the SPI flash chip when resoldering it.
                        I only see 4 bytes of difference between the original and new files. Is that expected for this model?
                        Thanks!
                        • aldopc
                          • Jul 2017
                          • 485
                          • Chilito
                          #32
                          Thanks!
                          check well the soldering bin that the hardware friend gave you is correct, check if you blew any resistor or capacitor near the bios... if you are not sure upload an image of the bios chip and its surrounding components
                          • Wasabilera
                            • Feb 2023
                            • US
                            #33
                            Got it. Turns out I didn't have the wson-8 SPI chip aligned quite right. I removed and resoldered the IC on, and now the laptop is functioning great!
                            Thanks for the help!
                            • biniu1978
                              • May 2022
                              • 26
                              #34
                              bios with admin lock , Please Unlock
                              Dell Latitude 5430
                              8FC8
                              Thank You
                              • hardware1
                                • Sep 2021
                                • 2951
                                • N/A
                                #35
                                Dell Latitude 5430
                                8FC8
                                Thank You
                                Your Backup is not good, try to read it again correctly.
                                • biniu1978
                                  • May 2022
                                  • 26
                                  #36
                                  Please try now. Thank You
                                  • hardware1
                                    • Sep 2021
                                    • 2951
                                    • N/A
                                    #37
                                    It's the same file.
                                    Which programmer do you use? Are you using a clip or de-soldering the Chip?
                                    • biniu1978
                                      • May 2022
                                      • 26
                                      #38
                                      de-soldering chip. try reading a few times and same result
                                      programmer is TL866 II Plus
                                      • hardware1
                                        • Sep 2021
                                        • 2951
                                        • N/A
                                        #39
                                        Attach a clear image for your Chip or what is written on it. Did you choose the same name of the Chip when you try to read it or auto detect?
                                        • biniu1978
                                          • May 2022
                                          • 26
                                          #40
                                          my chip is - 25Q256JVEN
                                          and my programmer have only that option - reading all same.
                                          see picture
                                            DELL Latitude 5430 Notebook 5000 Specification for Upgrade or Repair
                                            This specification for the DELL Latitude 5430 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5430 boardview and 5430 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 5430...
                                            09-07-2024, 06:31 AM
                                          • diamon
                                            Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
                                            by diamon
                                            I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
                                            Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
                                            Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
                                            Pictures of these boards:
                                            Dell Latitude 5520 https://www.ebay.com/itm/256052956663
                                            Dell Latitude 5530 https://www.ebay.com/itm/125844181534
                                            Dell...
                                            02-28-2024, 12:51 PM
                                          • F R 2568
                                            Dell Latitude 5420 does not start (no post) need help to find the reason why
                                            by F R 2568
                                            Hello all,
                                            this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
                                            I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
                                            If the laptop is only connected to the AC adapter (battery removed):
                                            When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
                                            The power/battery...
                                            01-08-2025, 05:45 AM
                                          • dell_sadness
                                            Dell Latitude 3440 - Service tag ending in 0001 - Locked!
                                            by dell_sadness
                                            BIOS password locked Dell Latitude 3440 (Service tag B4HNJX3)
                                            Have extracted the BIN and want to know how to rebuild a clean BIOS
                                            I have come across the 8F8C patcher but not sure if that would work in my case as the service tag ends in 0001.
                                            I tried it and although the log states it patched several mentions of 8F8C in the BIN, I haven't flashed it yet in case such a patch wouldn't work.
                                            Have also tried to extract a clean BIN file from Dell's .exe BIOS updates using 'Dell PFS Extractor', but not confidently; Ended up with a 25MB file instead of the same 32MB...
                                            11-12-2025, 02:54 PM
