Dell Latitude 5430, LA-L591P bios
  • babydoll8867
    • Nov 2014
    • 96
    • romania
    #61
    Re: Dell Latitude 5430, LA-L591P Computrace setting unlock
    Originally posted by biniu1978
    Chip is connected directly to programmer without any adapter ( wire connection )
    hey, how did you made it through? how did you manage to read it correctly, i have the same programmer, used adapter and has the same checksum every time i read it
    • hardware1
      • Sep 2021
      • 2951
      • N/A
      #62
      Originally posted by babydoll8867
      i re-read it 2 times with the same programmer and 2 times with another programmer.. it is 25Q256JV and it has the same checksum..
      This file isn't good, I advise you not to erase the Chip before you got the Right file, otherwise your device will not work at all.
      Check your Connections, your Programmer settings and read the Chip again.
      all donations are welcome,
      • babydoll8867
        • Nov 2014
        • 96
        • romania
        #63
        desoldered it from the adapter, used a clip adapter, again, same checksum....
        • babydoll8867
          • Nov 2014
          • 96
          • romania
          #64
          i used MEAnalyzer to decompile my file and indeed the file is said to have no engine, but also tried a diffrent file from the forum that was correctly read and also gives the error. "File does not contain Intel Engine/Graphics Firmware". is this the reason you told me it is read incorrectly?
          • babydoll8867
            • Nov 2014
            • 96
            • romania
            #65
            checked, ME and other stuff is in the other, 16mb flash
            • hardware1
              • Sep 2021
              • 2951
              • N/A
              #66
              Yes, that's because your Device has an Intel 12th Gen CPU.
              Here's your Unlocked BIOS, hope it works fine.
              • JAVIERBS
                • Oct 2022
                • 8
                • spain
                #67
                Hi here is bios with admin lock of Dell Latitude 5430. Please can you unlock?.
                Thanks.
                • lapfix
                  • Mar 2020
                  • 2764
                  • my workshop
                  #68
                  Thanks.
                  >>>>> click on this link to donate via PayPal. <<<<<
                  1st boot, press F2, write service tag, disable Absolute, save, restart. 2nd boot press Alt+F to exit manufacturing mode.
                  • janpatirkckaram1992
                    • Sep 2020
                    • 9
                    • Philippines
                    #69
                    hdb42 la-l591p rev 1.0 (a00)
                    admin lock
                    ST: BB9GKR3
                    • anhbanxoi
                      • Sep 2021
                      • 180
                      • VN
                      #70
                      admin lock
                      ST: BB9GKR3
                      Flash this file
                      • DarkMooon
                        • Apr 2021
                        • 11
                        • UA
                        #71
                        Hi can anyone assist in removing password on this ?
                          VIP Moderator
                          • Aug 2018
                          • 4386
                          • Bulgaria 🇧🇬
                          #72
                          Become a Badcaps supporter
                          Thanks to all supporters.​
                          • DarkMooon
                            • Apr 2021
                            • 11
                            • UA
                            #73
                            Thank you, it worked
                            • vidijus
                              • Oct 2017
                              • 17
                              • lietuva
                              #74
                              Hello please remove password
                                VIP Moderator
                                • Aug 2018
                                • 4386
                                • Bulgaria 🇧🇬
                                #75
                                • vidijus
                                  • Oct 2017
                                  • 17
                                  • lietuva
                                  #76
                                  Thank you ))
                                    VIP Moderator
                                    • Aug 2018
                                    • 4386
                                    • Bulgaria 🇧🇬
                                    #77
                                    Thank you ))
                                    You're welcome!
                                    You can return the favor by clicking on the link below and donating an amount of your choice to support the forum!
                                    • JAVIERBS
                                      • Oct 2022
                                      • 8
                                      • spain
                                      #78
                                      Many thanks !!! It worked.
                                      • Arrow16
                                        • Apr 2022
                                        • 229
                                        • Philippines
                                        #79
                                        Dell 5430 absolute enable need to disaable, tnx
                                        • Arrow16
                                          • Apr 2022
                                          • 229
                                          • Philippines
                                          #80
                                          Nneed help i already remove admin password but absolute is not
                                            DELL Latitude 5430 Notebook 5000 Specification for Upgrade or Repair
                                            This specification for the DELL Latitude 5430 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5430 boardview and 5430 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 5430...
                                            09-07-2024, 06:31 AM
                                          • diamon
                                            Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
                                            by diamon
                                            I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
                                            Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
                                            Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
                                            Pictures of these boards:
                                            Dell Latitude 5520 https://www.ebay.com/itm/256052956663
                                            Dell Latitude 5530 https://www.ebay.com/itm/125844181534
                                            Dell...
                                            02-28-2024, 12:51 PM
                                          • F R 2568
                                            Dell Latitude 5420 does not start (no post) need help to find the reason why
                                            by F R 2568
                                            Hello all,
                                            this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
                                            I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
                                            If the laptop is only connected to the AC adapter (battery removed):
                                            When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
                                            The power/battery...
                                            01-08-2025, 05:45 AM
                                          • dell_sadness
                                            Dell Latitude 3440 - Service tag ending in 0001 - Locked!
                                            by dell_sadness
                                            BIOS password locked Dell Latitude 3440 (Service tag B4HNJX3)
                                            Have extracted the BIN and want to know how to rebuild a clean BIOS
                                            I have come across the 8F8C patcher but not sure if that would work in my case as the service tag ends in 0001.
                                            I tried it and although the log states it patched several mentions of 8F8C in the BIN, I haven't flashed it yet in case such a patch wouldn't work.
                                            Have also tried to extract a clean BIN file from Dell's .exe BIOS updates using 'Dell PFS Extractor', but not confidently; Ended up with a 25MB file instead of the same 32MB...
                                            11-12-2025, 02:54 PM
