Dell Latitude 5430, LA-L591P bios
  • rex98
    • Feb 2023
    • 1293
    • Mandaue CEBU, Philippines
    #321
    Originally posted by juanespty
    Hi. I'm having problems unlocking the BIOS/Computrace for this particular model. I've successfully been able to unlock earlier models (e.g.: 5420, 5310, etc.). I've tried with more than 1 laptop of this model, and I'm having the same problem with all of them.
    Thanks!
    only flash this uc2
    1st boot, press F2, write service tag, disable Absolute, save (Apply changes), restart. 2nd boot press Alt+F to exit manufacturing mode
    Last edited by SMDFlea; 06-26-2024, 01:58 AM. Reason: edited unnecessary full quote
    • juanespty
      • Oct 2023
      • 3
      • Panama
      #322
      Originally posted by rex98
      only flash this uc2
      Thank you for the file. The problem is that I cannot write to the chip using a POGO probe.
      Today I ordered the necessary tools to de-solder/solder the chip. Apparently for this model the programming cannot be done with the chip in the motherboard.
      • volinakis
        • Jan 2021
        • 2874
        • N/A
        #323
        Please help me rebuild bios for Latitude 5430
        MB: LA-L591P
        ST: CYFLTT3
        I have image only on HDMI after bios update.
        Or please provide Intel Flash Tool v 16.1.25.1932
        Attached : combined bios (16Mb+32Mb) Bios Region and ME FW extracted from bios update.
        Thank you!
        • minhdigital
          • Nov 2022
          • 764
          • Vietnam
          #324
          MB: LA-L591P
          ST: CYFLTT3
          Thank you!
          Send to you, try
          • Syed Wasiq Hussain
            • Jul 2022
            • 13
            • Pakistan
            #325
            Originally posted by hoaca388
            Re: Dell Latitude 5430, LA-L591P Computrace setting unlock
            Try
            Working, thank you alotttttttttttt!
            • ameerrrr
              • Aug 2015
              • 42
              • syria
              #326
              BIOS Password latitude 5430
              tag 2V99FK3
              • peste
                • Dec 2016
                • 13581
                • ROMANIA
                #327
                tag 2V99FK3
                the original bios of the laptop, the motherboard model, etc.
                • dellfox
                  • May 2024
                  • 6
                  • Belgium
                  #328
                  I have Admin Password Locked, Computrace and Dell SafeBios enabled.
                  Can anyone help me to unlock these? Dump file attached.
                  Motherboard: HDB42 LA-L591P Rev:1.0(A00)
                  i5 1245U (so 12th gen)
                  Service Tag: 30RLTV3
                  Winbond W25Q256JVEN
                  Thanks in advance.
                  • volinakis
                    • Jan 2021
                    • 2874
                    • N/A
                    #329
                    Winbond W25Q256JVEN
                    Thanks in advance.
                    let it run for 2 mins, it will restart several times with no image. 1st boot, press F2, write service tag, disable Absolute, save (Apply changes), restart. 2nd boot press Alt+F to exit manufacturing mode.​
                    • dellfox
                      • May 2024
                      • 6
                      • Belgium
                      #330
                      Thanks volinakis
                      It worked!
                      Still have the Dell SafeBios "title" over the Dell logo on boot, but it seems normal for recent updated bios and not an option we can disable in BIOS.
                      Again, thanks, you've saved my computer!
                      • volinakis
                        • Jan 2021
                        • 2874
                        • N/A
                        #331
                        Thanks volinakis
                        It worked!
                        "Dell SafeBIOS is a collection of capabilities that mitigate the risk of BIOS and firmware tampering with integrated firmware attack detection. It consists of Dell unique IP, as well as partner technology. We combine these capabilities to help ensure devices are secure at the BIOS level, an area that traditionally lacks protection but is most certainly known by hackers as an area to exploit if vulnerable. Attacks at the BIOS level can be stealthy and create havoc. And when malware owns the BIOS, it owns the PC and access into the network.​"
                        If you backup 2nd bios chipset and post it here I can take a look how to disable it.
                        • dellfox
                          • May 2024
                          • 6
                          • Belgium
                          #332
                          volinakis
                          Do you mean that Dell Safebios can make network calls to their server(s)? If that's the case I would effectively prefer to get rid of it, as well as Intel Management Engine.
                          By 2nd bios chipset, you mean UC6 chip? Do you think you can remove SafeBios and/or IME?
                          It seems quoting messages doesn't work for me (it appears good in previsualization but not when posted, sorry).
                          • dellfox
                            • May 2024
                            • 6
                            • Belgium
                            #333
                            Is there someone able to analyze the UC6 chip to get rid of Dell SafeBios and/or Intel ME?
                            i5 1245U
                            Bin file attached.
                            Thank you.
                            • GB1999
                              • Mar 2023
                              • 73
                              • Malaysia
                              #334
                              HDB42 LA-L591P REV 1.0(A00)
                              service tag 6qy3fk3
                              please help me remove the bios lock. thanks in advance
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 12328
                                #335
                                service tag 6qy3fk3
                                XXX
                                ​https://www.badcaps.net/donate
                                • devp62
                                  • 57
                                  #336
                                  Hi Can some one pls remove admis password for me Dell Latitude 5430
                                  stag 90L1VQ3.
                                  Board la-l591p
                                  • rex98
                                    • Feb 2023
                                    • 1293
                                    #337
                                    stag 90L1VQ3.
                                    Board la-l591p
                                    • devp62
                                      • 57
                                      #338
                                      Thank you Rexer Anthony
                                      • devp62
                                        • 57
                                        #339
                                        Hi Rexer Anthony, I get a error when overwriting the bios and the weird thing is that my original bios dump is blank but the machine still powers up as it did before and suggestions? I have read both uc2 and uc6 uc6 has content in it but uc6 seems blank ?? error photo attached for info.
                                        • marc_ytos
                                          • Apr 2020
                                          • 155
                                          • cdmx
                                          #340
                                          Greetings, can you help me unlock my bios? My computer is a Dell Latitude 5430 with service tag H2NMSQ3 and motherboard la-l591p. Thank you very much in advance and a hug.
