Dell Latitude 5430, LA-L591P bios
  • hoaca388
    Badcaps
    • Jan 2022
    • 12328
    #341
    Originally posted by marc_ytos
    Greetings, can you help me unlock my bios? My computer is a Dell Latitude 5430 with service tag H2NMSQ3 and motherboard la-l591p. Thank you very much in advance and a hug.
    VVV
    • marc_ytos
      • Apr 2020
      • 155
      • cdmx
      #342
      Originally posted by hoaca388
      VVV
      Thank you very much the help now works thanks
      • santoslao
        • Apr 2017
        • 131
        • BZ
        #343
        Please help me rebuild bios for Latitude 5430
        The equipment is no longer turning on after an attempt to remove the bios password, I believe the file was corrupt because it doesn't turn on even with the original dump! It just turns on the power key led and turns off after a few seconds.
        MB: LA-L591P
        ST: DKCL6Z3
        Attached : bios (16Mb+32Mb)
        Attached : Bios Region and ME FW extracted from bios.
        Thank you!​
        • kalilinux25
          • Mar 2018
          • 2089
          • ZAMBOANGA SIBUGAY
          #344
          MB: LA-L591P
          ST: DKCL6Z3
          Thank you!​
          is the board labeled as HDB42 LA-L591P REV 1.0(A00) 2022-01-13 ???
          • santoslao
            • Apr 2017
            • 131
            • BZ
            #345
            Exactly!
            • dellfox
              • May 2024
              • 6
              • Belgium
              #346
              I've noticed few days ago that my 5430 has Intel ME disabled from factory as a yellow sticker says (3 ME disabled, with a QR code that I masked). This sticker is on the inner face of the bottom case of the laptop.
              So, for people who are interested to have ME disabled (those having same model as mine) or for a technical learning purpose, I attached the dump file of the UC6 chip of my laptop.
              Here are the specs of my laptop, please don't flash the file if you don't know what you are doing, I'm not responsible if you make a mistake :
              Motherboard: HDB42 LA-L591P Rev:1.0(A00)
              i5 1245U (so 12th gen) with touchscreen
              The main bios chip (UC2) : Winbond W25Q256JVEN
              The second bios chip with ME disabled and Dell Safebios​ (still active on my laptop) marked as UC6 on the motherboard is a Winbond 25R128JVSN.
              Best regards and thanks again to Volinakis to have submitted the good bin file to reinitialize my BIOS.
              • kalilinux25
                • Mar 2018
                • 2089
                • ZAMBOANGA SIBUGAY
                #347
                thanks for the contribution we need more people like you thanks
                • santoslao
                  • Apr 2017
                  • 131
                  • BZ
                  #348
                  MB: LA-L591P
                  ST: DKCL6Z3
                  Thank you!​
                  I still need this if anyone can help I would really appreciate it.
                  • kalilinux25
                    • Mar 2018
                    • 2089
                    • ZAMBOANGA SIBUGAY
                    #349
                    try this one
                    • santoslao
                      • Apr 2017
                      • 131
                      • BZ
                      #350
                      try this one
                      It doesn't work, I had already tried to insert another file into the machine, this file the machine only lights up red when the power button is pressed. This file contains a version 1.7.0 of the bios the bios file that I posted is in a version 1.13.1 and is corrupted as I mentioned, I
                      • santoslao
                        • Apr 2017
                        • 131
                        • BZ
                        #351
                        If someone could at least explain to me how I can rebuild it myself, I would be very grateful too. The machine has an ME with a version above the FIT that was used to build it. And when trying to open the file in mFIT it gives errors in both versions.
                        • santoslao
                          • Apr 2017
                          • 131
                          • BZ
                          #352
                          I would like to inform you that with a lot of persistence I managed to rebuild the machine's bios and now it is working again.
                          • F6 Solutions
                            • Jul 2024
                            • 9
                            • Cameroon
                            #353
                            Hello
                            Please need help to unlock bios Dell latitude 5430
                            i7 1265U 12th gen
                            UC2 Winbond W25Q256JVEN
                            UC6 Winbond 25R128JVSN.
                            Service Tag 5Z1SDK3-0001
                            Thanks​
                            • hoaca388
                              Badcaps
                              • Jan 2022
                              • 12328
                              #354
                              Originally posted by F6 Solutions
                              Hello
                              i7 1265U 12th gen
                              Thanks​
                              Post Winbond W25Q256JVEN chip.
                              • F6 Solutions
                                • Jul 2024
                                • 9
                                • Cameroon
                                #355
                                Ok
                                When I try to read chip on board having error
                                • santoslao
                                  • Apr 2017
                                  • 131
                                  • BZ
                                  #356
                                  Ok
                                  You need to remove the chip from the board, this equipment does not support reading with a soldered chip.
                                  • Dan20701
                                    • Sep 2020
                                    • 204
                                    #357
                                    Hello all, Can someone please remove the password for me, I don't have much luck when trying editing Dell bios files.
                                    Dell Latitude 5430
                                    Service Tag, F4MWST3
                                    Thanks so much.​
                                    • hoaca388
                                      Badcaps
                                      • Jan 2022
                                      • 12328
                                      #358
                                      Dell Latitude 5430
                                      Thanks so much.​
                                      Password removed.
                                      • Dan20701
                                        • Sep 2020
                                        • 204
                                        #359
                                        Thanks so much mate, much apricated. I will give an update when I get back to this one.
                                        • Dan20701
                                          • Sep 2020
                                          • 204
                                          #360
                                          100% perfected mate, Thanks again.
