Dell Latitude 5430, LA-L591P bios
  • its service
    • Feb 2021
    • 147
    • india
    #481
    Originally posted by peste
    both..
    Dell latitude 5430
    Part no : La-L591p rev 1.0
    ST no : 6hk96vk3
    both file attached sir
    • danito
      • Jun 2016
      • 1095
      #482
      Originally posted by its service
      Dell latitude 5430
      ST no : 6hk96vk3
      ST is wrong, it's too long
      • bhcomputadores
        • Jun 2017
        • 25
        • Brazil
        #483
        Hello! I tested some files from this post but was unsuccessful. The machine even stopped turning on after one. Can you try removing the administrator password from these files that I backed up before testing the ones from this forum?
        I thank you in advance!! dell latitude 5430 ST: 8BL2PT3 MB:HDB42 LA-L591P REV 1.0 A00 2022-01-13
        Last edited by bhcomputadores; 07-24-2025, 07:18 AM. Reason: I FORGOT TO PUT THE EQUIPMENT MODEL
      • bhcomputadores
        • Jun 2017
        • 25
        • Brazil
        #484
        CORRECTED SMDFlea Sorry!
          • 21869
          Read the dell bios password post https://www.badcaps.net/forum/troubl...23#post1622423 you might be able to unlockit yourself, it depends what the suffix is.
          • LBTT1121
            • Nov 2024
            • 920
            • Việt Nam
            #486
            try
            • bhcomputadores
              • Jun 2017
              • 25
              • Brazil
              #487
              Originally posted by LBTT1121
              try
              Muito obrigado! thanks a lot!😁
              • bhcomputadores
                • Jun 2017
                • 25
                • Brazil
                #488
                I followed the process described in the post you mentioned and it worked! Thank you!
                • marquitos550b
                  • Nov 2011
                  • 22
                  #489
                  Originally posted by volinakis
                  Re: Dell Latitude 5430, LA-L591P Computrace setting unlock
                  try. 1st boot press F2, write Service Tag, disable Absolute, save, restart. 2nd boot press alt+F to exit manufacturing mode.
                  Thank you !!!
                  • Bios White
                    Learn
                    • Dec 2024
                    • 84
                    • East Laos
                    #490
                    dell latitude 5430
                    ST: 8BL2PT3
                    Laptop no display, please build bios
                    many thank
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 12328
                      #491
                      Originally posted by Bios White
                      dell latitude 5430
                      ST: 8BL2PT3
                      many thank
                      Latitude 5430_ADL
                      Service Tag: 8BL2PT3
                      • dahnking
                        • Apr 2018
                        • 262
                        • kenya
                        #492
                        Try
                        Working, Thank you
                        • Bios White
                          Learn
                          • Dec 2024
                          • 84
                          • East Laos
                          #493
                          Latitude 5430_ADL
                          working 100% , thank you
                          • LANTEc
                            • ZAMBIA
                            #494
                            ST: 89JJKR3
                            *BIN compressed
                            • Edonhiran
                              • Jun 2025
                              • 5
                              #495
                              I have a Dell Latitude 5430 laptop that currently has a BIOS password set, and I need to remove it need help please.
                              Here are the device details:
                              • Model: Dell Latitude 5430
                              • Service Tag: 2H3YKR3
                              Thank you in advance!...
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 12328
                                #496
                                3.4. Dell
                                Dell laptops store the password in EC. However, some generators exist depending on the code suffix.
                                See: https://beta.bios-pw.org/ .If the website is offline try: https://web.archive.org/web/*/https://bios-pw.org/
                                Note: All passwords must be entered with a US QWERTY Keyboard,you can use a USB one.
                                Note: The 6FF1 suffix has a bug,use your service tag with the 1F5A or BF97 suffix instead,Example: 1234ABC-BF97 .
                                Note: The list of examples does not include some other suffix codes that do work,such as E7A8 .
                                Note: If the BF97 suffix does not work try it with the E7A8 suffix instead.
                                Note: There is no publicly available 8FC8 generator available at the moment.
                                The CTRL-ENTER-ENTER keystroke after the password only applied to laptops with a suffix (xxxxxxx-8FC8 for example), until Dell also required it in some laptops using System Disable 16-Hex algorithm, on which only the Password+ENTER was needed at first and then in some models you needed the CTRL-ENTER-ENTER to properly delete the system passwords, otherwise the password would remain SET upon the automatic system reboot if just doing Password+ENTER until the proper CTRL-ENTER-ENTER keystroke was performed in certain models.
                                8FC8 Patcher software: https://www.badcaps.net/forum/troubl...l-8fc8-patcher
                                • Edonhiran
                                  • Jun 2025
                                  • 5
                                  #497
                                  3.4. Dell
                                  I have tried to flash bios chip and I used one of bin file from this post above. . But it didn't work. unfortunately now laptop not responding and just power light for few seconds. Also mistakenly deleted original bios bin file. Please I need help to resolve this.
                                  Thank you
                                  • user392097
                                    • Jun 2023
                                    • 11
                                    • Georgia
                                    #498
                                    Hello. Please help me to restore the BIOS.
                                    After patching the dump with Badcaps/Rex_8FC8_Patcher to remove the password and flashing it back the laptop doesn't boot.
                                    Flashing original BIOS dump gives the same result. I think that the dump is defective.
                                    Dell Latitude 5430 12th gen
                                    HDB42 LA-L591P Rev:1.0(A00)
                                    Service Tag 1C7CWT3
                                    Winbond 25Q256JVEN
                                    Original dump is attached.
                                    • user392097
                                      • Jun 2023
                                      • 11
                                      • Georgia
                                      #499
                                      Service Tag 1C7CWT3
                                      Winbond 25Q256JVEN
                                      bump
                                      • Firshad
                                        • Jun 2025
                                        • 11
                                        • united arab emirates
                                        #500
                                        PLEASE CLEAR MEE
                                        LATITUDE 5430
                                        ST:3Z2CHR3
