Guest - Try our new boardview, Bios, & schematic search. Over 1.1 million files for download!
Dell Latitude 5430, LA-L591P bios
  • bibi019
    • Jun 2014
    • 59
    • algeria
    #461
    Hi all i need parcH unlocked bios file for
    dell latitude 5430 i5 12gen
    service tag 3RGVKN3- 8FC8
    yours
    • lapfix
      • Mar 2020
      • 2769
      • my workshop
      #462
      yours
      1st boot, press F2, write service tag, disable Absolute, save, restart. 2nd boot press Alt+F to exit manufacturing mode.
      Good luck.
      • markenero3
        • May 2023
        • 40
        • Philippines
        #463
        Good Day, everyone. Pls help me to unlock this one, I have a Dell Latitude 5430 with a BIOS lock and absolute enabled. Here is my BIOS. Thank you in advance
        SERVICE TAG: JBL2SV3​
        • doivaythoiem
          • Jun 2024
          • 141
          • Việt Nam
          #464
          Try and feeback
          • markenero3
            • May 2023
            • 40
            • Philippines
            #465
            Try and feeback
            Thank sir, it's already unlocked, but still I can't disable absolute
              • 23075
              try
              • markenero3
                • May 2023
                • 40
                • Philippines
                #467
                Originally posted by SMDFlea
                try
                Still I can't disable absolute
                • markenero3
                  • May 2023
                  • 40
                  • Philippines
                  #468
                  I still need help, please help me unlock the absolute and BIOS lock. I have attached two BIOS files: 16 MB and 32 MB. Thank you in advance 🙏
                  ST: JBL2SV3
                  • Stefan Steff
                    • Mar 2024
                    • 480
                    #469
                    ST: JBL2SV3
                    Try this combo:
                    • tarek gouadma
                      • Jun 2024
                      • 50
                      • Algeria
                      #470
                      Hi.can you help me?? It has admin password.
                      HDB42 LA-L592P
                      Dell Latitude 5430
                      ST: 2WYJJR3
                      Thanks in advance. Here is bios dump.​
                        • 23075
                        HDB42 LA-L592P
                        Dell Latitude 5430
                        ST: 2WYJJR3
                        Read the bios password guides, you can unlock it yourself https://www.badcaps.net/forum/troubl...23#post1622423
                        • mshone
                          • Jan 2014
                          • 61
                          • serbia
                          #472
                          Hi, dell latitude 5430, mobo LA-L591p, bios ...8FC8, i5 12th gen. On introducing screen, with dell logo is written "secured with dell safebios"
                          Programmer is xGecu PRO T76, newest software and programmer firmware. I use adapter to read bios chip winbond S25Q256JV (8x6mm) with great success in reading and unlocking with python aplication for previous model latitude 5420.
                          But...
                          Now, i try to read bios from UC2 winbond S25Q256JV (8x6mm) with same programmer and same adapter, and programmer is recognized chip as correct model, but as "device ID is 00 00 00 00 00" and when i reading bios all is 00 and FF. The same is when i try to read UC6 (winbond 25R128JV WSON8). Tried wit several adapters-all the same. Tried programmer on latitude 5420 (only to check programmer-all is ok with programmer). Checksum is 0000. I checked in forum, but did not find similar problem. Any suggestion or help?
                          • peste
                            peste commented
                            Editing a comment
                            post merged...next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
                        • peste
                          • 14716
                          • ROMANIA
                          #473
                          But...
                          check the contact between the adapter and the chip....if necessary, clean the chip pins with sandpaper...
                          • mshone
                            • Jan 2014
                            • 61
                            • serbia
                            #474
                            I am, several times. And i tried with same programmer and adapter on other laptop (latitude 5420) and all was ok. I know that is the same model, but is not same problem. This was a reason for new threah. Thanks for correcting me.
                            • mshone
                              • Jan 2014
                              • 61
                              • serbia
                              #475
                              Well, should write and what happends...Desoldered UC2 and UC6 and all was ok. Conclusion-is not bad contacts, but seems that soldered cannot be readed. Thanks.
                              • its service
                                • Feb 2021
                                • 150
                                • india
                                #476
                                Dell latitude 5430
                                Part no : La-L591p rev 1.0
                                ST no : 6hk96vk3
                                Problem : Dell logo not present, need to remove logo I'll attached the image can u anyone help me and which backup I'll attached main file or ec or
                                • peste
                                  • 14716
                                  • ROMANIA
                                  #477
                                  Originally posted by its service
                                  Dell latitude 5430
                                  ST no : 6hk96vk3
                                  post the contents of the bios chip even if it is corrupted..
                                  • its service
                                    • Feb 2021
                                    • 150
                                    • india
                                    #478
                                    Which one file sir main bios file or ec file can u plz tell me sir
                                    • peste
                                      • 14716
                                      • ROMANIA
                                      #479
                                      both..
                                      • its service
                                        • Feb 2021
                                        • 150
                                        • india
                                        #480
                                        both..
                                        OK sir I'll. Sent
                                        • Boardview and Schematic Bot
                                          DELL Latitude 5430 Notebook 5000 Specification for Upgrade or Repair
                                          This specification for the DELL Latitude 5430 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5430 boardview and 5430 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 5430...
                                          09-07-2024, 06:31 AM
                                        • diamon
                                          Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
                                          by diamon
                                          I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
                                          Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
                                          Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
                                          Pictures of these boards:
                                          Dell Latitude 5520 https://www.ebay.com/itm/256052956663
                                          Dell Latitude 5530 https://www.ebay.com/itm/125844181534
                                          Dell...
                                          02-28-2024, 12:51 PM
                                        • F R 2568
                                          Dell Latitude 5420 does not start (no post) need help to find the reason why
                                          by F R 2568
                                          Hello all,
                                          this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
                                          I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
                                          If the laptop is only connected to the AC adapter (battery removed):
                                          When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
                                          The power/battery...
                                          01-08-2025, 05:45 AM
                                        • dell_sadness
                                          Dell Latitude 3440 - Service tag ending in 0001 - Locked!
                                          by dell_sadness
                                          BIOS password locked Dell Latitude 3440 (Service tag B4HNJX3)
                                          Have extracted the BIN and want to know how to rebuild a clean BIOS
                                          I have come across the 8F8C patcher but not sure if that would work in my case as the service tag ends in 0001.
                                          I tried it and although the log states it patched several mentions of 8F8C in the BIN, I haven't flashed it yet in case such a patch wouldn't work.
                                          Have also tried to extract a clean BIN file from Dell's .exe BIOS updates using 'Dell PFS Extractor', but not confidently; Ended up with a 25MB file instead of the same 32MB...
                                          11-12-2025, 02:54 PM
