Eprom bios dell E5520
  • ludo28
    • Aug 2022
    • 37
    • france
    hello
    I am looking for where to find the bios eprom on a Dell E5520 motherboard?
  • hardware1
    • Sep 2021
    • 2949
    • N/A
    Re: Eprom bios dell E5520
    Originally posted by ludo28
    hello
    You can upload your corrupted file, and we will try to fix it for you.
    and mention what is the problem of your Device.
    all donations are welcome,
      • 22279
      hello
      There are 1 or 2 bios chips https://www.badcaps.net/forum/attach...0&d=1658397338
      • mayss
        • Nov 2016
        • 30
        • Polska
        This is orginal and clean file. Post and reply.
        • ludo28
          • Aug 2022
          • 37
          • france
          Originally posted by SMDFlea
          where can i find it on the motherboard
          • ludo28
            • Aug 2022
            • 37
            • france
            I looked and there are 2 biochips
            • ludo28
              • Aug 2022
              • 37
              • france
              hello
              Me it's a dell E5520 and not a 5420
              • ludo28
                • Aug 2022
                • 37
                • france
                I can't dump the bios (the 2 chips) is it because of the password?
                • ludo28
                  • Aug 2022
                  • 37
                  • france
                  I succeeded in dumping the bios of the U34 chip but the U33 chip was not possible.
                  is this normal?
                  if you can clean me the bios, there is a photo that I can't remove
                  • ludo28
                    • Aug 2022
                    • 37
                    • france
                    is this normal?
                    I successfully dumped the U33 chip
                    • zenius
                      by zenius
                      12-08-2024, 06:13 AM
                    • mikeybass
                      by mikeybass
                      04-23-2025, 04:30 PM
                    • capoplays
                      Help with BIOS update on Dell G15 5515 after chip replacement
                      by capoplays
                      Hey everyone,
                      I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
                      The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
                      When I check the BIOS using the F12 menu Flash...
                      10-24-2025, 06:53 AM
                    • Akhlz001
                      by Akhlz001
                      09-20-2025, 07:15 PM
                    • Sathsul
                      Dell Latitude 5431 issues with dumping bios
                      by Sathsul
                      So, i kinda spend significant ammount of the last couple of days trying to flash a new bios, and or unlocking the current bios password with little to no results.
                      The whole thing started with it being the 8fc8 bios, i found the tools to unlock that but i needed a bios dump. So i pursued that, im at a point where i dessoudered the chip, and succesfully soudered it to the ch341, dumped whatever was on it.
                      However, the tools supposed to unlock the 8fc8 say that there is no 8fc8 hex inside. And when i followed diffrent tutorials to just flash a new bios onto the chip i got stuck on the...
                      10-28-2025, 07:49 AM
