Need BIOS Asus Expertbook B1500C
  • Joandean14
    • Jul 2021
    • 23
    • Philiphines
    hi there
    anyone please help me remove the bios password
    i cannot even delete the bios on flashing
    is there any chance to get bios password only ?
    Thank you.
    heres the file
    • peste
      • Dec 2016
      • 12392
      • ROMANIA
      Originally posted by Joandean14
      hi there
      Thank you.
      heres the file
      post S/N, full name and model, motherboard model, etc.
      • Joandean14
        • Jul 2021
        • 23
        • Philiphines
        hello sir peste
        Here.
        B1500CEPE-BQ1118W
        SN:NANXCV04Z087410
        CN: BY9L
        • peste
          • Dec 2016
          • 12392
          • ROMANIA
          hello sir peste
          Here.
          B1500CEPE-BQ1118W
          SN:NANXCV04Z087410
          CN: BY9L
          try..
          • Joandean14
            • Jul 2021
            • 23
            • Philiphines
            Originally posted by peste
            try..
            is it okay to erase the status register in this bios ?
            thankyou.
            • razor_amd
              by razor_amd
              12-15-2020, 07:07 PM
            • angel148644
              Bios Asus ExpertBook B2402CBA
              by angel148644
              Good day friends, This laptop turn on and show a message "Please follow the steps below to recover your bios", try it to repair with Asus EZ Flash Utility & Usb, but didnt work. Remove bios and copy, then download bios version 308 from Asus web and use "AMI PFAT" to obtain Region Bios.
              Now the problem its, I cant open the original bios with CSME v16.0.15.1662, to replace region and Me region. Someone can help me whit this please. Thank you for your time.
              Me Region Version: 16.0.15.1735
              Logic board its B2402FBA MB REV: 2.0
              Laptop model...
              12-17-2024, 02:42 PM
            • lrouw84
              by lrouw84
              Hi there,
              01-28-2023, 01:31 PM
            • DynaxSC
              by DynaxSC
              06-14-2024, 03:49 PM
            • chudofermer
              Asus Ally rc71l bios
              by chudofermer
              Hello!
              Received Asus Ally rc71l with the wrong bios.
              Have the original package and all serial numbers.
              Can anyone help me understand what is wrong?
              Condition:
              Received with an original box with all serial numbers
              Due to the bios updating, something went wrong and I can not check in the bios. The recovery mode sometimes appears, usually was stopped on the logo.
              Got the flash dump, nothing found on DMI section
              No Windows key, just key ID on the box
              What is done:
              1. Flash the latest bios version with serial numbers...
              03-05-2025, 05:42 AM
