Bios Asus ExpertBook B2402CBA
  • angel148644
    • Dec 2013
    • 13
    • Guatemala
    Good day friends, This laptop turn on and show a message "Please follow the steps below to recover your bios", try it to repair with Asus EZ Flash Utility & Usb, but didnt work. Remove bios and copy, then download bios version 308 from Asus web and use "AMI PFAT" to obtain Region Bios.
    Now the problem its, I cant open the original bios with CSME v16.0.15.1662, to replace region and Me region. Someone can help me whit this please. Thank you for your time.
    Me Region Version: 16.0.15.1735
    Logic board its B2402FBA MB REV: 2.0
    Laptop model Asus B2402CBA
  • hoaca388
    Badcaps
    • Jan 2022
    • 12350
    Serial number ?
    • angel148644
      • Dec 2013
      • 13
      • Guatemala
      Serial Number its N7NXCV15M875297
      Model B2402CBA-EK0212W
      Thanks for your time.
      • angel148644
        • Dec 2013
        • 13
        • Guatemala
        Good day friends, Someone can help me whit this bios. Thanks for your time.
        • minhdigital
          • Nov 2022
          • 765
          • Vietnam
          Try
          • noname2024
            • Aug 2024
            • 295
            • CỎ MỸ XỊN
            working!
            • angel148644
              • Dec 2013
              • 13
              • Guatemala
              Thanks you for your time and help. I wlill tri it and let you know it.
              • pirati
                by pirati
                10-27-2025, 04:20 PM
              • mkdj
                by mkdj
                Dear all,
                10-19-2025, 04:41 AM
              • jbonavita
                by jbonavita
                Some issues
                Things I tried
                04-29-2025, 09:38 PM
              • kodox
                Asus ExpertBook B1400CB Bios Dump Needed
                by kodox
                need original bios dump, original bios has flashed by other technician before me.
                attached bios was read from the chip but no display and amperage fluctuating from 0.6A to 0.34 and back to 0.6A.
                unit info:
                Model: Asus ExpertBook B1400CBA-0711A1235U
                S/N: R6NXNZ006657238
                CN: 7F6F
                Mainboard Code: B1500CBA R2.1...
                08-16-2025, 12:20 PM
              • throwaway327
                by throwaway327
                Model No: RC72LA
                Serial No: SBNVKD001014459
                06-18-2025, 05:52 PM
