asus Zenbook Flip 13 UX363 bios backup
  • volinakis
    • Jan 2021
    • 2616
    • N/A
    #41
    Originally posted by jomerfx28
    charging flashing gone, when charger plug-in power kicks in - processor will continue to heat up- fan will not work, like POST not functioning well, i checked the fan on direct DC. it worked, the only changed is the charging light indicator gone.
    if im not mistaken - if the processor is gone, or need some reballing.
    bios is extracted from latest bios update and clean ME. You have to extract bios_region from bios update, then using proper Intel FIT version to your backup (you can find it using MEAnalyzer) replace Bios Region and ME Sub Partition with extracted bios and proper ME firmware and build new bios image. After that transfer DMI to new created bios image.
    Read this guide created by master SMDFlea, in addition to this guide you also have to replace Bios Region with bios_region extracted from bios update in decomposed image created by FIT.
    https://www.badcaps.net/forum/troubl...cleaning-guide
    • jomerfx28
      • May 2020
      • 31
      • n/a
      #42
      Thanks. So i extracted the Bios Region and ME Sub Partition from the original Bios i have to the file you have provided through the correct FIT version, i already did the Build Image, i am partly lost on the last instruction
      "After that transfer DMI to new created bios image." what's DMI. thanks
      • volinakis
        • Jan 2021
        • 2616
        • N/A
        #43
        serial, snid, win key, etc.
        • Kaasis
          • Feb 2021
          • 15
          • Latvia
          #44
          Hello.
          Please fix bios
          Doesn't boot
          I installed a different bios, but the battery does not charge and does not show a connected NVME disk
          Ori Asus UX363EA bios.rar
          • peste
            • Dec 2016
            • 12230
            • ROMANIA
            #45
            Originally posted by Kaasis
            Hello.
            Please fix bios
            Doesn't boot
            post the S/N, the motherboard model, the full name and model of the laptop,etc.
            • yaaqbeh
              • Dec 2013
              • 33
              • palestine
              #46
              hi
              i need fix bios
              not detect m.2 nvme
              s/n
              lbn0cx20n80348d
              • hoaca388
                Badcaps
                • Jan 2022
                • 11154
                • Viet Nam
                #47
                Originally posted by yaaqbeh
                hi
                i need fix bios
                not detect m.2 nvme
                s/n
                lbn0cx20n80348d
                UX363EA
                Mọi khoản quyên góp cho Badcaps đều được hoan nghênh . Trở thành người ủng hộ Badcaps >>>>> nhấp vào liên kết này để quyên góp <<<<< Cảm ơn tất cả những người ủng hộ . -------------------------------------------------------------------------------------------------------------------------------------------------------------
                • yaaqbeh
                  • Dec 2013
                  • 33
                  • palestine
                  #48
                  Originally posted by hoaca388
                  UX363EA
                  thanks but not work
                • minhdigital
                  • Nov 2022
                  • 718
                  • Vietnam
                  #49
                  thanks but not work
                  Send to you
                  • Jeanswieg
                    • Oct 2022
                    • 3
                    • South Africa
                    #50
                    Hi guys I have a similar issue. I updated the bios (version 326 note sure from which version) and now my laptop won't charge and battery is at 0% constantly, i thought it was the battery, but i bought a new one and same issue. I would appreciate some assistance in dumping my bios and sending to you for fix so i can flash again? Thanks in advance.
                    Asus Zenbook Flip 13 UX363EA
                    • peste
                      • Dec 2016
                      • 12230
                      • ROMANIA
                      #51
                      post S/N, full name and model, motherboard model,post the contents of the bios chip even if it is corrupted.. etc.
                      • Jeanswieg
                        • Oct 2022
                        • 3
                        • South Africa
                        #52
                        Thanks so much for the assistance, i will send you everything you need, i just need to know how to get the bios contents for you?
                        Asus Zenbook flip 13 i7-1165G7, 16GB RAM UX363EA
                        S/N: L9N0CX08B56039B
                        • peste
                          • Dec 2016
                          • 12230
                          • ROMANIA
                          #53
                          you need an SPI programmer...here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
                          • Jeanswieg
                            • Oct 2022
                            • 3
                            • South Africa
                            #54
                            Thank you, will get back to you as soon as possible. I have a black ch341a, do i need to convert it from 5v to 3.3v before flashing?
                            • peste
                              peste commented
                              Editing a comment
                              from 3.3v...to 1.8v...
                          • peste
                            • Dec 2016
                            • 12230
                            • ROMANIA
                            #55
                            I don't know..see what voltage the bios chip is powered at on pin 8
                            • R34P3R
                              • Nov 2015
                              • 6
                              • south africa
                              #56
                              Hi guys,
                              The batt is not charging after bios update. please help.
                              UX363EA 15971.zip
                              SN: 12M
                              L9N0CX08B56039B
                              MFD: 2020-09
                              • kodinabeel
                                • Sep 2014
                                • 62
                                • saudi arabia
                                #57
                                Originally posted by bilal767
                                Re: asus Zenbook Flip 13 UX363 bios backup
                                Thanks for this. Please check if I have found the right one. I have encircled one in the picture. Thanks
                                any one have this bios file? 1mb
                                • hoaca388
                                  Badcaps
                                  • Jan 2022
                                  • 11154
                                  • Viet Nam
                                  #58
                                  Originally posted by R34P3R
                                  Hi guys,
                                  UX363EA [ATTACH]n3569198[/ATTACH]
                                  SN: 12M
                                  L9N0CX08B56039B
                                  MFD: 2020-09
                                  UX363EA
                                  • kgpeace30
                                    • Apr 2025
                                    • Botswana
                                    #59
                                    The ux371ea is the ux363 bios. Even on the asus support site.
                                      ASUS ZenBook Zenbook 14 Flip OLED UN5401QA-KN144W Notebook Specification for Upgrade or Repair
                                      This specification for the ASUS ZenBook Zenbook 14 Flip OLED UN5401QA-KN144W Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Zenbook 14 Flip OLED UN5401QA-KN144W boardview and Zenbook 14 Flip OLED UN5401QA-KN144W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                      09-07-2024, 06:31 AM
                                      ASUS ZenBook S UX370UA Hybrid (2-in-1) Flip Specification for Upgrade or Repair
                                      This specification for the ASUS ZenBook S UX370UA Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the S UX370UA boardview and S UX370UA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                      09-06-2024, 06:24 AM
                                      ASUS ZenBook UX362FA-EL076R Hybrid (2-in-1) Flip 13 Specification for Upgrade or Repair
                                      This specification for the ASUS ZenBook UX362FA-EL076R Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the UX362FA-EL076R boardview and UX362FA-EL076R schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                      09-06-2024, 11:40 AM
                                      ASUS ZenBook UP5302ZA-XB71T-CA Hybrid (2-in-1) S 13 Flip OLED Specification for Upgrade or Repair
                                      This specification for the ASUS ZenBook UP5302ZA-XB71T-CA Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the UP5302ZA-XB71T-CA boardview and UP5302ZA-XB71T-CA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                      09-07-2024, 07:19 AM
                                      ASUS ZenBook UP5401ZA-DB71T-CA Hybrid (2-in-1) 14 Flip OLED Specification for Upgrade or Repair
                                      This specification for the ASUS ZenBook UP5401ZA-DB71T-CA Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the UP5401ZA-DB71T-CA boardview and UP5401ZA-DB71T-CA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                      09-07-2024, 07:12 AM
