Lenovo ThinkBook 14 G2 ITL FLV34 LA-K051P bios
  • volinakis
    • Jan 2021
    • 2734
    • N/A
    #81
    Originally posted by Pavel Kudryavtcev
    Hi
    Lenovo Thinkbook 14 G2 ITL
    MO: MPNXB13230E6
    MTM: 20VD00CSUA
    Factory ID: PRC4
    S/N: MP1ZHRPF
    After updating to firmware f8cn59ww, the fan stopped working and the sound card was not detected. On the support forum, the manufacturer sent me the previous firmware f8cn58ww and after this update, the screen stopped showing. HDMI connection does not work. I only have dumps of the firmware f8cn58ww, I will attach them to the message. I will also add the installation file.
    I also tried the firmware from post 19, it does not work.
    Please help me fix the firmware.
    Thank you!​
    Try
    • Pavel Kudryavtcev
      • Jan 2025
      • 3
      Originally posted by volinakis
      Try
      Unfortunately, it didn't work. But the symptoms are different, earlier the LEDs on the caps lock and escape were lit, now only the power button slowly blinks. As if there is no BIOS at all.
      • volinakis
        • Jan 2021
        • 2734
        • N/A
        #83
        check soldering
        • Pavel Kudryavtcev
          • Jan 2025
          • 3
          check soldering
          There really was a problem with soldering. I redid it, checked it with a microscope. The behavior when starting the laptop has changed as it was after the f8cn58ww update. The power button, esc and caps lights up, then everything goes out and lights up again, while caps goes out and nothing else happens. If there are any other options on how to fix this, please suggest.
          P.S. Please note that I previously updated Intel Management Engine 15.0 Firmware to version F8ME05WW.
          Thank you!​
          • -danger-
            • May 2020
            • 12
            • US
            #85
            Hello. can I post bios dump for password reset? ThinkBook 14 G2 ITL
            ​I can donate if needed )
            • peste
              • Dec 2016
              • 12852
              • ROMANIA
              #86
              post S/N, full name and model, motherboard model,post the original contents of the bios chip..etc.
              • elariz
                • Oct 2015
                • Азербайджан
                #87
                its clean me region
                working 100%
                • jj.ww
                  • Jan 2023
                  • 21
                  hello is it possible for somebody to help unlock bios password.
                  MODEL NAME :THINKBOOK 14 G2 ITL
                  FLV34 LA-K051P REV:1B
                  S/N MP1Y9VDW
                  MTM:20VD008UUK
                  • volinakis
                    • Jan 2021
                    • 2734
                    • N/A
                    #89
                    S/N MP1Y9VDW
                    MTM:20VD008UUK
                    try. Write only 16Mb chipset.
                    • jj.ww
                      • Jan 2023
                      • 21
                      hello. volinakis.
                      it worked thank you.
                      i need to do 3 more of these laptop. could i use the 16MB file and use golden key to just change the dmi stuff ?
                      or do i just need to post the 16mb files and system info ?
                      thanks again​
                      • jj.ww
                        • Jan 2023
                        • 21
                        hello can i have help unlocking bios and mdm possible absolute
                        S/N :MP1YCBD1
                        MTM:20VD008UUK​
                        • jj.ww
                          • Jan 2023
                          • 21
                          hello. please will anyone help or point me in right direction.
                          thanks.
                          • jj.ww
                            • Jan 2023
                            • 21
                            • Frank Walter
                              • Apr 2025
                              • 3
                              Could you fix my main bios and ec bios chip bins as well please?
                              FLV34 LA-K051P REV:1B​
                              S/N: MP1Y104Z
                              MTM: 20WE0009GE
                              • danito
                                • Jun 2016
                                • 950
                                • Romania
                                #95
                                S/N: MP1Y104Z
                                MTM: 20WE0009GE
                                What's the problem with this bios?
                                • Frank Walter
                                  • Apr 2025
                                  • 3
                                  The Power LED turns on white, the ESC + Shift LED turns on white and nothing happens. No Display no fan spinning and all leds keep white until i disconnect it from power.
                                  Shift LED turns off after 5-6 Seconds and if i kill it with 10s power button the next start the white power led keeps turning on and off every 5 seconds.
                                  Do you know anything thats wrong? Charing works and no burns, black components or other sings of failure.
                                  Thank you for the fast reply.
                                  • 147369258
                                    • Oct 2019
                                    • 6
                                    • iran
                                    #97
                                    Please help me. I received a ThinkBook model 14 G2ILT S/N:MP1YTF5G
                                    MTM:20VD0034US
                                    MO:MPNXB131170JV. I didn't have a backup BIOS. I programmed all three IC UC3-XM25QH128A-UC12-XM25QH64A-UT2-W25Q80. The laptop turned on, but it showed a blank image. The bigger problem is that it doesn't recognize the SSD drive. Is there a way to solve this problem? If you can send me the correct files, thank you.​
                                    • hoaca388
                                      Badcaps
                                      • Jan 2022
                                      • 11787
                                      #98
                                      MTM:20VD0034US
                                      ThinkBook 14 G2 ITL Laptop - Type 20VD
                                      UT2 is not bios chip
                                      • 147369258
                                        • Oct 2019
                                        • 6
                                        • iran
                                        #99
                                        Unfortunately, the laptop did not boot with these files. I probably found the backup files. I will upload them again. Please fix it. It does not boot with these either. Thanks.
                                        • Italyfan
                                          • Jun 2018
                                          • 27
                                          • viet nam
                                          #100
                                          Please help me build this file. It turn on but no display
                                          Lenovo Thinkbook 14s Yoga ITL, S/N: MP25W4T2
                                          Thanks!!
                                          • Wahaz
                                            by Wahaz
                                            10-30-2023, 08:42 PM
                                          • TecnicaNTT
                                            Lenovo Thinkbook 16P G2 ACH - BIOS Serial number missing
                                            by TecnicaNTT
                                            I got a Lenovo Thinkbook 16P G2 ACH on the bench with a botched BIOS (somehow my client blanked it). I restored the laptop and got it up and running with original BIOS from Lenovo Support website.
                                            My problem is now that the machine details are missing in the BIOS (Serial Number, MTM, etc.)
                                            I tried to write the details with the Lenovo Uone Tool but had now luck. It is giving me an error: "ERROR: Locate protocol with LenovoEeprom, Status=[e]. EEPROM fail when reading or writing data."
                                            I am now asking here for help if anyone knows how to do this in...
                                            09-20-2024, 08:10 AM
                                          • grimacelord
                                            Lenovo Legion T5-26AMR5 Desktop - Corrupt BIOS
                                            by grimacelord
                                            Hello there.
                                            I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
                                            History:
                                            1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
                                            I searched for this error online and discovered...
                                            03-15-2023, 03:29 PM
                                            Lenovo ThinkBook ThinkBook 14s Yoga ITL Notebook Specification for Upgrade or Repair
                                            This specification for the Lenovo ThinkBook ThinkBook 14s Yoga ITL Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ThinkBook 14s Yoga ITL boardview and ThinkBook 14s Yoga ITL schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-07-2024, 04:10 AM
