Lenovo ThinkBook 14 G2 ITL FLV34 LA-K051P bios
  • majster-pl
    Majster
    • Sep 2025
    • 34
    Check that, unfortunately it looks ok... I have picture form before and after - the both looks the same.
    It looks like I've accidentally damaged something else on the board πŸ˜₯
    When I connect charger the IC is getting hot (checked with thermal camera) not sure if anything else can be done.
    • m1ch43lzm
      • Mar 2019
      • 1374
      • Peru
      #122
      Make sure you haven't soldered the BIOS chip the wrong way, if it really got shorted, replace it with a new one (or one from a donor board with same specs) programmed with your BIOS backup
      You can use a W25Q128JV as a replacement
      Anything else we have to continue the discussion on the Troubleshooting laptops section
      • ruslan657
        • Mar 2016
        • 75
        • Azerbaijan
        #123
        please help need bios
        ThinkBook 14 G2 ITL
        s/n MP259DCG
        FLV34 LA-K051P Rev 1B
        • m1ch43lzm
          • Mar 2019
          • 1374
          • Peru
          #124
          Originally posted by majster-pl
          Any change someone can help me removing system password from attached bios dump please?
          Lenovo Thinkbook 14 G2 ITL
          S/N MP21DY74
          FLV34 LA-K051P Rev: 1B
          Thank you in advance πŸ™‚
          Try clean BIOS extracted from Lenovo website, flash both chips
          ThinkBook 14 G2 ITL Laptop - Type 20VD
          Bios ver F8CN53wW
          S/N MP21DY74
          MTM 20VD008RUK​
          First boot may take some minutes
          • m1ch43lzm
            • Mar 2019
            • 1374
            • Peru
            #125
            ThinkBook 14 G2 ITL
            s/n MP259DCG
            Bios ver F8CN53wW
            S/N MP259DCG​
            MTM 20VD0097RU​
            • Vibore
              • Oct 2021
              • 7
              • Portugal
              #126
              Please help. Bios for:
              Lenovo FLV34 LA-K051P REV1b LA-K05
              SN: MP1ZVGEC
              20VD000APG
              • peste
                • 14406
                • ROMANIA
                #127
                SN: MP1ZVGEC
                20VD000APG
                post full name and model, type...
                post the contents of the bios chip even if it is corrupted..
                • Vibore
                  • Oct 2021
                  • 7
                  • Portugal
                  #128
                  fault is exact this: https://www.youtube.com/watch?v=YSq0bv-dQUU Powers on and off.
                  ThinkBook 14 G2 ITL
                  s/n MP1ZVGEC
                  FLV34 LA-K051P REV 1b LA-K05
                  i will make a backup
                  thanks
                  • Vibore
                    • Oct 2021
                    • 7
                    • Portugal
                    #129
                    both chips return only ff. what can i do?
                    • Vibore
                      • Oct 2021
                      • 7
                      • Portugal
                      #130
                      edit:
                      it was a programmer problem.
                      got the backup
                      ThinkBook 14 G2 ITL
                      s/n MP1ZVGEC
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 12645
                        #131
                        edit:
                        got the backup
                        ThinkBook 14 G2 ITL
                        s/n MP1ZVGEC
                        ​https://www.badcaps.net/donate
                        • Vibore
                          • Oct 2021
                          • 7
                          • Portugal
                          #132
                          Thanks bro, but still the same. Maybe I should try a clean bios?
                          • Vibore
                            • Oct 2021
                            • 7
                            • Portugal
                            #133
                            Thanks, but that was toa nother user. but i tried it too, and stays the same. This mainboard as another memory, a winbond 25q80dvsig, close to charger port. Someone knows what it does, and have a backup?
                            • m1ch43lzm
                              • Mar 2019
                              • 1374
                              • Peru
                              #134
                              Your laptop is ThinkBook 14 Gen2 ITL not ThinkBook 14s Yoga ITL, even if board number is the same the BIOS is different for the Yoga model
                              Post 132 is the correct BIOS for your laptop, hoaca388 extracted it from Lenovo website
                              You can try post 124 or 125, it's an earlier BIOS version, that will change your S/N if it works
                              The W25Q80DV is likely USB-C PD controller firmware, if laptop gets 20V on USB-C meter it's fine
                              • twonk9098
                                • Aug 2018
                                • 76
                                #135
                                I have Thinkbook 14 G2 ITL. I have had a few issues with it and all was working for a while, until I upgraded the memory.
                                After upgrading, the screen no longer lights up or functions.
                                I have installed another bios from an earlier post and the laptop display now works however,
                                The battery charging is a little intermittant, I never had issues with the battery / charging until I changed out the bios.
                                Is someone able to repair my original bios please?
                                Both files attached.
                                Thank you
                                  • 22772
                                  Thank you
                                  post the laptop serial number
                                  read the forum rules..https://www.badcaps.net/forum/troubl...before-posting
                                  Badcaps relies on your donations to pay for hosting ( Currently AWS is $8000 alone) site advertising goes nowhere near to covering these costs. To keep everything that you and i rely on for free,​Please consider donating, thank you.
                                  • twonk9098
                                    • Aug 2018
                                    • 76
                                    #137
                                    Sorry, the laptop serial number is MP1YGF4K.
                                    I note though that using a previous bios uploaded in this thread for someone else, I replaced the 128mb and 64mb bios's and the serial number within the Bios has not changed. Is this right?
                                    Thank you
                                    • m1ch43lzm
                                      • Mar 2019
                                      • 1374
                                      • Peru
                                      #138
                                      Try, BIOS extracted from Lenovo website
                                      BIOS ver F8CN59WW
                                      S/N MP1YGF4K
                                      MTM 20VD000AUK
                                      DMI 20000-207FF (on 16MB file)
                                      ​Win key 92000-9203F (on 16MB file)
                                      • twonk9098
                                        • Aug 2018
                                        • 76
                                        #139
                                        Thank you, which file (8 or 16mb) do I replace the DMI / Win information?
                                        Many thanks
                                        • m1ch43lzm
                                          • Mar 2019
                                          • 1374
                                          • Peru
                                          #140
                                          8MB BIOS chip has ME region, the 16MB has the BIOS-UEFI region, I already added your DMI+Win key there
                                          • Wahaz
                                            by Wahaz
                                            10-30-2023, 08:42 PM
                                          • HumanDev228
                                            Lenovo ThinkBook 13s Gen 3 ACN – Need Help Fixing Corrupted BIOS (W74M12JW)
                                            by HumanDev228
                                            I’m working on a Lenovo ThinkBook 13s Gen 3 ACN (AMD Ryzen 5 5600U) with a Winbond W74M12JW 16MB BIOS chip
                                            Symptoms:
                                            • No display, fan spins, white LED blinking
                                            • Temporary boot after flashing another BIOS
                                            • Dies again after reboot
                                            • Current BIOS dump appears corrupted (mostly FF-filled, no valid UEFI structure)
                                            What I already tried:
                                            • External flash with CH341A + proper 1.8V supply
                                            • Flashed GMCN33WW-031F.bin (booted once, then failed again)
                                            • Reflashed original dump β†’ same issue
                                            • Power reset, battery disconnect
                                            • RAM reflow attempt (no change)
                                            12-08-2025, 05:25 PM
                                          • lucaszmn
                                            by lucaszmn
                                            Problem:
                                            Initial Findings:
                                            • I concluded that the
                                            08-12-2025, 03:01 PM
                                          • TecnicaNTT
                                            Lenovo Thinkbook 16P G2 ACH - BIOS Serial number missing
                                            by TecnicaNTT
                                            I got a Lenovo Thinkbook 16P G2 ACH on the bench with a botched BIOS (somehow my client blanked it). I restored the laptop and got it up and running with original BIOS from Lenovo Support website.
                                            My problem is now that the machine details are missing in the BIOS (Serial Number, MTM, etc.)
                                            I tried to write the details with the Lenovo Uone Tool but had now luck. It is giving me an error: "ERROR: Locate protocol with LenovoEeprom, Status=[e]. EEPROM fail when reading or writing data."
                                            I am now asking here for help if anyone knows how to do this in...
                                            09-20-2024, 08:10 AM
                                          • gestalt.exe
                                            Lenovo Legion Y540 – Need help repairing BIOS after bad downgrade
                                            by gestalt.exe
                                            My Lenovo Legion Y540 (i7-9750H, RTX 2060) bricked after I downgraded from BHCN44WW to BHCN21WW.
                                            Laptop stopped booting entirely.
                                            I used a CH341A programmer to dump the corrupted 16MB BIOS.
                                            i then attempted the following:
                                            1. Downloaded stock BIOS BHCN39WW from Lenovo
                                            2. Trimmed it to 16MB
                                            3. Extracted the BIOS region from the corrupted dump
                                            4. Extracted the BIOS region from the stock 39WW
                                            5. Replaced the corrupted BIOS region with the stock one (within hxd , opened the corrupted dump and replaced its region by the stock)
                                            6. Injected back my LDGB / DMI
                                            11-30-2025, 10:38 AM
