ASUS G531GV ROG bios dump
  • btomce
    • Nov 2020
    • 70
    • lt
    Looking for clear ME bios dump G531GV
    My is not work.
    In Attach
    1 My is not work.
    2 Update from site
  • cacla
    • Apr 2015
    • 442
    Re: ASUS G531GV ROG bios dump
    here
    • ongobongo
      • May 2023
      • 58
      Hi guys,
      i need help with a possible corrupted bios.
      I have an asus rog strix g531GV-AL022 which shows only black screen. As CPU/GPU get warm and keyboard animations work (and i don't have any shorts on the power rails) I suspect the bios to be corrupt.
      I already dumped the original BIOS with CH314. I then tried reflashing with several versions, first the original from the website (.307-file which is 2KB bigger than the dump which didn't work). I then removed the encapsulation by opening the .307-file with UEFITool NE and extracting the UEFI-image, which lead to the correct file size but ended in not working at all, laptop is not powering on at all with this.
      I also tried some bios versions I found here, but they don't work either.
      Attach you'll find both my original dump and the .307 version from the asus website.
      Details of the machine:
      Sn: K7NRCV034304297
      CN: KLK5
      Board is:
      G531GW r1.6
        SMDFlea commented
        Editing a comment
        Thread merged.There`s an asus service bios at post 2, copy your DMI from your backup to it.
    • hoaca388
      Badcaps
      • Jan 2022
      • 12085
      Originally posted by ongobongo
      Hi guys,
      Sn: K7NRCV034304297
      CN: KLK5
      Board is:
      G531GW r1.6
      zzz
      • razor_amd
        by razor_amd
        12-15-2020, 07:07 PM
      • DynaxSC
        by DynaxSC
        06-14-2024, 03:49 PM
      • Ahari
        by Ahari
        I...
        08-13-2025, 06:12 AM
      • kodox
        Asus ExpertBook B1400CB Bios Dump Needed
        by kodox
        need original bios dump, original bios has flashed by other technician before me.
        attached bios was read from the chip but no display and amperage fluctuating from 0.6A to 0.34 and back to 0.6A.
        unit info:
        Model: Asus ExpertBook B1400CBA-0711A1235U
        S/N: R6NXNZ006657238
        CN: 7F6F
        Mainboard Code: B1500CBA R2.1...
        08-16-2025, 12:20 PM
      • Habble7
        by Habble7
        Suspected Cause:
        Troubleshooting Attempts:
        05-22-2025, 07:28 AM
