Surface Go 1943 bios
Every donation made will go towards server fees and maintenance costs. -
Model:-Surface laptop go 1943Attached Files↵
https://www.badcaps.net/donateComment
Hi.
I'm dealing with a persistent boot issue on a Surface Laptop Go (Model 1943) after a motherboard replacement.
The original motherboard was burn to a crisp (CPU power rail burn a hole in the motherboard); so I got myselft a replacement but din't manage to get it working yet.
Situation:- Original SSD was BitLocker-encrypted.
- Motherboard was replaced with a (supposedly) known-good donor board.
- Device powers on, shows Windows logo, but gets stuck — no spinning dots, no activity.
- Cannot enter UEFI (Volume Up + Power does nothing).
- Cannot boot from USB (Volume Down + Power also hangs).
- Without an SSD present, the board doesn’t power on (normal for Surface?).
What I’ve tried:- Swapped in a brand-new blank SSD → same result.
- Wiped original SSD externally → same result.
- Created official Surface Recovery USB → no boot.
- Flashed BIOS from (unknown) donor board → no change.
- Swapped BIOS chip from the original board → still stuck.
- Tried multiple UEFI/boot key combos.
Cloud this be a ME firmware mismatch or missing?
Could the original BIOS be corrupted or have missing contents?
Attached I'm sending the BIOS dump from the new motherboard. If anyone could have a look at it and a possible fix that would be much appreciated.
Attached FilesComment
Hi, just to clarify — I didn’t actually ask for a BIOS password removal. My request was something completely different, which is why I created a new topic. I’m asking for a BIOS integrity check on a donor board, not for password removal. Thanks!Comment
The word password has been edited out of the thread title now, so your post is ok here. How many seconds does it stay on the logo for, do you see a slight flicker after 1-2 seconds with the logo carrying on for a few seconds moreComment
Does anybody know how I can recover a bad BIOS on a surface 1943?. What are the steps I need to do and does anyone have a UEFI/ BIOS file that I can flash.Comment
The bios chip must be unsoldered from the board before writing or reading..
do not use the clip, you may have errors..if you do not have anything to unsolder it with,
solder wires between the programmer and the bios chip..
you need an SPI programmer...here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHowDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
Cheers for the heads up on this, just one question, where can I get the UEFI/ BIOS file from to write it to the chip? Also where is the BIOS chip located and what is its markings?.
I am new to this particular make and model of device, and appreciate all the information I can get with regards to this.
Kind regards and thanks again
Austin.Comment
Apologies for the delay in getting back to you.
To answer your question: no, there is no flicker at all. The system boots instantly to the logo and just stays there, frozen. I've tested with three different BIOS files I currently have:- One of them behaves exactly the same — it powers on and gets stuck at the logo.
- The other two power on briefly (for a few seconds) and then shut off.
- The fan does eventually spin up once the board starts warming up.
I’ve checked all the main voltage rails and they appear to be within normal range. Visually, the board looks excellent — no signs of physical damage, corrosion, or missing components.
Appreciate any insights or suggestions.
Thanks again!Comment
Hello all, Could someone please remove the password for me.
Microsoft Surface Go 1943.
Serial Number, 004184404366Attached FilesComment
try patchedAttached FilesComment
Hello
Laptop: Microsoft Surface Go Gen 1
Model 1943
Motherboard: DA0Z91MBAE0 REV : E
S/N: 027476204366
The system is stuck on the Windows logo, and auto shutđown. Can't access to BIOS/UEFI when I press F4.
I have tried the method at BIOS guides, methods, resources and tools with no luck.
Suspect the BIOS/UEFI is corrupt, have seen this before and only fix is to reflash BIOS/UEFI.
Can you please assist with a new BIOS file.
PS: Thanks in advance, this community does a great job, keep it up :-)Comment
I have posted the existing BIOS, however I suspect it is corrupted, but you may be able to get some usable data from it.
ThanksComment
Channel: BIOS Requests ONLY!
by rrfg112aHi
The usual, eBay seller failed to mention the password lock on the BIOS
- Device information:
- Device name: BACKUP
- Serial number: 027853301557
- Surface model: Surface Book 3 Model 1900 i7
- SAM: 10.600.139.0
- UEFI: 23.101.140.0
- App version: 75.7170.133.0
- BIOS Version/Date: Microsoft Corporation 23.101.140 10/10/2024
- Touch driver: 4.0.211.139
- Wi-Fi driver: 23.160.0.4
- Edition: Windows 11 Pro
- OS build: 26100.4946
- Processor: Intel(R) Core(TM) i7-1065G7 CPU @ 1.30GHz
- Installed RAM: 32 GB
- Storage size: 353 GB free of 476 GB
- GPU: Intel(R) Iris(R) Plus Graphics NVIDIA
by traxformaniaHello,
I tried :
-I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries... -
by tlindiSublect line continuation: ... Jaguar IDS PC aka Panasonic
Ack
Ack
by NopslideHello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....-
- Loading...
