Surface Go 1943 bios
  • peste
    • 14027
    • ROMANIA
    Originally posted by ishfaq
    can someone help me to unlock this bios
    post S/N, full name and model, motherboard model, etc.
    • ishfaq
      • Sep 2016
      • india
      Model:-Surface laptop go 1943
      SN#020464513766
      DA0Z91MBAE0
      • hoaca388
        Badcaps
        • Jan 2022
        • 12506
        SN#020464513766
        DA0Z91MBAE0
        • ishfaq
          • Sep 2016
          • india
          hoaca388​#
          Thank You So Much Working Perfectly
          • gjlpereira
            • Sep 2018
            • 13
            • Portugal
            Hi.
            I'm dealing with a persistent boot issue on a Surface Laptop Go (Model 1943) after a motherboard replacement.
            The original motherboard was burn to a crisp (CPU power rail burn a hole in the motherboard); so I got myselft a replacement but din't manage to get it working yet.
            Situation:
            • Original SSD was BitLocker-encrypted.
            • Motherboard was replaced with a (supposedly) known-good donor board.
            • Device powers on, shows Windows logo, but gets stuck — no spinning dots, no activity.
            • Cannot enter UEFI (Volume Up + Power does nothing).
            • Cannot boot from USB (Volume Down + Power also hangs).
            • Without an SSD present, the board doesn’t power on (normal for Surface?).
            What I’ve tried:
            • Swapped in a brand-new blank SSD → same result.
            • Wiped original SSD externally → same result.
            • Created official Surface Recovery USB → no boot.
            • Flashed BIOS from (unknown) donor board → no change.
            • Swapped BIOS chip from the original board → still stuck.
            • Tried multiple UEFI/boot key combos.
            Has anyone dealt with a similar Surface firmware hang like this?
            Cloud this be a ME firmware mismatch or missing?
            Could the original BIOS be corrupted or have missing contents?
            Attached I'm sending the BIOS dump from the new motherboard. If anyone could have a look at it and a possible fix that would be much appreciated.
            • peste
              peste commented
              Editing a comment
              post merged...next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
          • gjlpereira
            • Sep 2018
            • 13
            • Portugal
            #26
            Hi, just to clarify — I didn’t actually ask for a BIOS password removal. My request was something completely different, which is why I created a new topic. I’m asking for a BIOS integrity check on a donor board, not for password removal. Thanks!
              • 22412
              The word password has been edited out of the thread title now, so your post is ok here. How many seconds does it stay on the logo for, do you see a slight flicker after 1-2 seconds with the logo carrying on for a few seconds more
              • AustinJames-Atkins
                • Jul 2025
                #28
                Does anybody know how I can recover a bad BIOS on a surface 1943?. What are the steps I need to do and does anyone have a UEFI/ BIOS file that I can flash.
                • peste
                  • 14027
                  • ROMANIA
                  #29
                  The bios chip must be unsoldered from the board before writing or reading..
                  do not use the clip, you may have errors..if you do not have anything to unsolder it with,
                  solder wires between the programmer and the bios chip..
                  you need an SPI programmer...here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
                    • Jul 2025
                    #30
                    Cheers for the heads up on this, just one question, where can I get the UEFI/ BIOS file from to write it to the chip? Also where is the BIOS chip located and what is its markings?.
                    I am new to this particular make and model of device, and appreciate all the information I can get with regards to this.
                    Kind regards and thanks again
                    Austin.
                    • gjlpereira
                      • Sep 2018
                      • 13
                      • Portugal
                      #31
                      Apologies for the delay in getting back to you.
                      To answer your question: no, there is no flicker at all. The system boots instantly to the logo and just stays there, frozen. I've tested with three different BIOS files I currently have:
                      • One of them behaves exactly the same — it powers on and gets stuck at the logo.
                      • The other two power on briefly (for a few seconds) and then shut off.
                      • The fan does eventually spin up once the board starts warming up.
                      I’ve checked all the main voltage rails and they appear to be within normal range. Visually, the board looks excellent — no signs of physical damage, corrosion, or missing components.
                      Appreciate any insights or suggestions.
                      Thanks again!
                      • Mrnixdorf
                        • Sep 2016
                        • 136
                        • Morocco
                        #32
                        Hello all, Could someone please remove the password for me.
                        Microsoft Surface Go 1943.
                        Serial Number, 004184404366
                        • Maxpower3
                          Bad Veteran
                          • Feb 2018
                          • 1393
                          • France
                          #33
                          try patched
                          • Mrnixdorf
                            • Sep 2016
                            • 136
                            • Morocco
                            #34
                            Thank You So Much
                            • AgentOrange
                              • Aug 2025
                              • New Zealand
                              #35
                              Hello
                              Laptop: Microsoft Surface Go Gen 1
                              Model 1943
                              Motherboard: DA0Z91MBAE0 REV : E
                              S/N: 027476204366
                              The system is stuck on the Windows logo, and auto shutđown. Can't access to BIOS/UEFI when I press F4.
                              I have tried the method at BIOS guides, methods, resources and tools with no luck.
                              Suspect the BIOS/UEFI is corrupt, have seen this before and only fix is to reflash BIOS/UEFI.
                              Can you please assist with a new BIOS file.
                              PS: Thanks in advance, this community does a great job, keep it up :-)
                                • 22412
                                Originally posted by AgentOrange
                                Hello
                                Model 1943
                                S/N: 027476204366
                                Post your bios backup.
                                • AgentOrange
                                  • Aug 2025
                                  • New Zealand
                                  #37
                                  I have posted the existing BIOS, however I suspect it is corrupted, but you may be able to get some usable data from it.
                                  • peste
                                    • 14027
                                    • ROMANIA
                                    #38
                                    Where did you post it???
                                    post the bios here, not on other sites..
                                    • AgentOrange
                                      • Aug 2025
                                      • New Zealand
                                      #39
                                      Sorry, first time using the site. Still finding my way around.
                                      • zenius
                                        by zenius
                                        12-08-2024, 06:13 AM
                                      • rrfg112a
                                        Password recovery for the Surface Book 3 BIOS
                                        by rrfg112a
                                        Hi
                                        The usual, eBay seller failed to mention the password lock on the BIOS
                                        • Device information:
                                        • Device name: BACKUP
                                        • Serial number: 027853301557
                                        • Surface model: Surface Book 3 Model 1900 i7
                                        • SAM: 10.600.139.0
                                        • UEFI: 23.101.140.0
                                        • App version: 75.7170.133.0
                                        • BIOS Version/Date: Microsoft Corporation 23.101.140 10/10/2024
                                        • Touch driver: 4.0.211.139
                                        • Wi-Fi driver: 23.160.0.4
                                        • Edition: Windows 11 Pro
                                        • OS build: 26100.4946
                                        • Processor: Intel(R) Core(TM) i7-1065G7 CPU @ 1.30GHz
                                        • Installed RAM: 32 GB
                                        • Storage size: 353 GB free of 476 GB
                                        • GPU: Intel(R) Iris(R) Plus Graphics NVIDIA
                                        08-28-2025, 02:31 PM
                                      • traxformania
                                        TONGFANG "GM7TG7P" Bios Password Problem?
                                        by traxformania
                                        I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
                                        But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
                                        I'm trying to reset my bios without success.
                                        I tried :
                                        -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                        11-15-2023, 07:32 AM
                                      • tlindi
                                        Toughbook CF-18KHH65LE (Customer Special Configuration) Supervisor Password needed remove HDD locking and BIOS Access ...
                                        by tlindi
                                        Sublect line continuation: ... Jaguar IDS PC aka Panasonic
                                        >Read BIOS guides, methods, resources and tools
                                        Ack
                                        >Try the method at BIOS guides, methods, resources and tools before requesting help
                                        Ack
                                        >Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
                                        python ./main.py "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.BIN" --output-dir "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.txt"
                                        01-30-2025, 04:26 AM
                                      • Nopslide
                                        HP Omen 15-dh0052nf power-on & bios password
                                        by Nopslide
                                        Hello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
                                        My Omen 15-dh0052nf purchased second-hand was configured with the bios password upon purchase (very simple password :P ).
                                        Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....
                                        04-01-2024, 04:27 PM
